Topic: Why won't this work? (Read 870 times) previous topic - next topic
Robotbuilder9999
Why won't this code work.
There's an error and it says val was not declared in scope.
Here's the code:
int val = 0;
void loop () {
val = analogRead(0);
Serial.print(val);
AWOL
Scope.
The variable is defined inside setup, so can't be seen in any other function.
GoForSmoke
Try moving the line inside setup() to above setup(). Then val will be global scope.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
Robotbuilder9999
#3
Jan 23, 2013, 09:20 pm Last Edit: Jan 23, 2013, 09:23 pm by Robotbuilder9999 Reason: 1
Thanks !  But I am trying to make a LDR tell my computer the light level through the serial port.  And it won't display the light level when I click serial monitor.  What do I do to make it work?
Robotbuilder9999
Heres the code for you guys to look at so you can help me:
int val = 0;
void loop () {
Serial.print(val);
KeithRB
Also, the way you have loop you will read (and print!) val hundreds or thousands of times a second. For this toy application include a delay(1000) statement to read only once per second.
KeithRB
What light are you trying to display? Is it attached to the Arduino? How do you have the LDR hooked up? LDR's do not provide voltage of their own, you need to hook it up to a voltage through a resistor.
Robotbuilder9999
I have LDR connected to a 5V port on the arduino and the other leg on the LDR connected to ground and analog in put port "A0".
Nick Gammon
I found this reply (by robtillaart) about that:
To connect an LDR correctly it must be part of a voltage divider
+5V <----> [ LDR ] <-----> [A0]  <------> [Resistor] <-----> GND
The value of resistor must be in the same order as the LDR when in the dark. (a 10 K will work probably too)
More info:
Nick Gammon
... the other leg on the LDR connected to ground and analog in put port "A0".
If A0 is connected to Gnd, clearly it will always read zero.
More info:
jerseyguy1996
I believe inside setup you need:
Serial.begin(baud)
Put
int val;
inside your loop.
Arduino Uno;
Mega328
