« on: January 23, 2013, 03:07:48 pm » |
Why won't this code work. There's an error and it says val was not declared in scope.
Here's the code:
int val = 0;
void loop () { val = analogRead(0);
Serial.print(val);
UK
« Reply #1 on: January 23, 2013, 03:11:43 pm » |
Scope. The variable is defined inside setup, so can't be seen in any other function.
Pittsburgh, PA, USA
I only know some basic electricity....
« Reply #2 on: January 23, 2013, 03:13:50 pm » |
Try moving the line inside setup() to above setup(). Then val will be global scope.
Examples can be found at Learning in the Main Site and at the Playground
« Reply #3 on: January 23, 2013, 03:20:11 pm » |
Thanks ! But I am trying to make a LDR tell my computer the light level through the serial port. And it won't display the light level when I click serial monitor. What do I do to make it work?
« Last Edit: January 23, 2013, 03:23:30 pm by Robotbuilder9999 »
« Reply #4 on: January 23, 2013, 03:22:21 pm » |
Heres the code for you guys to look at so you can help me:
int val = 0;
void setup() { }
Serial.print(val);
« Reply #5 on: January 23, 2013, 03:22:42 pm » |
Also, the way you have loop you will read (and print!) val hundreds or thousands of times a second. For this toy application include a delay(1000) statement to read only once per second.
« Reply #6 on: January 23, 2013, 03:24:22 pm » |
What light are you trying to display? Is it attached to the Arduino? How do you have the LDR hooked up? LDR's do not provide voltage of their own, you need to hook it up to a voltage through a resistor.
« Reply #7 on: January 23, 2013, 03:28:22 pm » |
I have LDR connected to a 5V port on the arduino and the other leg on the LDR connected to ground and analog in put port "A0".
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #8 on: January 23, 2013, 03:43:51 pm » |
I found this reply (by robtillaart) about that: To connect an LDR correctly it must be part of a voltage divider +5V <----> [ LDR ] <-----> [A0] <------> [Resistor] <-----> GND The value of resistor must be in the same order as the LDR when in the dark. (a 10 K will work probably too)
Shannon Member
Lua rocks!
« Reply #9 on: January 23, 2013, 03:44:48 pm » |
... the other leg on the LDR connected to ground and analog in put port "A0".
If A0 is connected to Gnd, clearly it will always read zero.
« Reply #10 on: January 23, 2013, 03:47:33 pm » |
I believe inside setup you need: Serial.begin(baud) Put int val; inside your loop.
Arduino Uno; Mega328
