Loading...
Pages: [1]   Go Down
Author Topic: Help: Interrupts and arrays/pointers  (Read 176 times)
Offline Offline
Full Member
View Profile
Hello,
     I am not sure if I am approaching this correctly.  Basically I have a buffer array that I want populated by an interrupt.  I made the buffer a global pointer and thus do not pass it to the interrupt.  Is this the preferred method?  I've read that variables changed by interrupts should be made volatile, but I can't seem to get it to work ("volatile float* buff;" is not accepted).
Please see the function "ITR1" in the code below.  Thanks!
Code:
// sbi is to set a bit
// cbi is to clear a bit
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
int buffSize=60;
int TOP=50; // this sets OCR1A for the CTC counter
float* buff;
volatile uint8_t low, high;
// Read a Samp and store it in the buff
// This is called at a fixed Samprate via the Interrupt
// Each time a Samp is made, this routine is called
void ITR1() {
  while (bit_is_set(ADCSRA, ADSC));
  low  = ADCL;
  high = ADCH;
  // I know this is wasteful, I'm converting it to a
  // circular buffer soon
  for (int i= 0 ; i < buffSize - 1 ; i++){
    buff[i] = buff[i+1];
  buff[buffSize - 1] = (high<<8) | low;
//Interrupt Service Routine (ISR)
ISR(TIMER1_COMPA_vect) {
  sbi(ADCSRA, ADSC);
  ITR1();
// This gets called at startup
void setupIntr(){
  // initialize Timer1
  cli();          // disable global interrupts
  TCCR1A = 0;     // set entire TCCR1A register to 0
  TCCR1B = 0;     // same for TCCR1B
  // set compare match register to desired timer count:
  // also known as the TOP
  OCR1A = TOP;
  TCCR1B  |= (1 << CS12);
  // turn on CTC mode:
  TCCR1B |= (1 << WGM12);
  // enable timer compare interrupt:
  TIMSK1 |= (1 << OCIE1A);
  // page 264
  ADMUX |= (1 << REFS0); //set reference voltage
  // ADCSRA: page 265
  // ADEN: Enable ADC
  sbi(ADCSRA, ADEN);
  // ADATE: ADC auto trigger enable
  cbi(ADCSRA, ADATE);
  // ADMUX page 264
  // select ADC1 channel
  cbi(ADMUX, MUX3);
  cbi(ADMUX, MUX2);
  cbi(ADMUX, MUX1);
  cbi(ADMUX, MUX0);
  // Quiet ADC inputs
  // Check page 266 of the ATmega328p datasheet
  // for more information.
  sbi(DIDR0,ADC5D);
  sbi(DIDR0,ADC4D);
  sbi(DIDR0,ADC3D);
  sbi(DIDR0,ADC2D);
  sbi(DIDR0,ADC1D);
  sbi(DIDR0,ADC0D);
  // start the conversion
  sbi(ADCSRA, ADSC);
  //setup Interrupt routine
  setupIntr();
  Serial.begin(57600);
  buff = (float *) malloc(sizeof(float)* buffSize);
  sei();//enable interrupts
  TIMSK1=0;
  for(int index=0; index < buffSize; index++) {
    Serial.write("buff[");
    Serial.print(index);
    Serial.write("]=");
    Serial.println(buff[index]);
Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
The buffer should be int not float.
You are not changing the address pointer so no need to make that a volatile.
Change this to
Code:
float* buff;
Code:
int buff[buufSize];
and drop the line with the malloc completely.
Mark
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
this probably has no place in interrupt context.
Please sort out your circular buffer and repost.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Full Member
View Profile
Change this to
Code:
float* buff;
Code:
int buff[buufSize];
Mark
Why should buff be made int*?  If I need the contents of buff to be float couldn't I leave it as is?  Or is it too wasteful since the output of the ADC can be fit in int variables.
Good point about the malloc.
Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
The output of the ADC in an int. If you need to convert it do it out side the ISR.
Mark
Logged
Offline Offline
Full Member
View Profile
Mark
Makes sense, thanks for the explanation.
Logged
Pages: [1]   Go Up
Print
Jump to:
