Loading...
Pages: 1 [2]   Go Down
Author Topic: problem rc receiver signal  (Read 358 times)
Offline Offline
Sr. Member
View Profile
Then you need something like (14330 < val) || (val < 14340))
or (abs (val-14335) < 5)
Logged
Offline Offline
Newbie
View Profile
Arrch i'll give that a go
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
This thread is a comedy of errors smiley
Logged
Offline Offline
Newbie
View Profile
Guys, Arrch this worked.
Code:
int rcpin =7;
int motpin = 13;
const int THRESHOLD = 5;
  pinMode(rcpin, INPUT);
  pinMode(motpin, OUTPUT);
int val;
  val = pulseIn(rcpin, INPUT);
  Serial.println(val);
 // if ((val > 14535) && (val < 14335))
 //if ( 14335 < val || val > 14535)
 if ( (val > 14435 - THRESHOLD) && (val < 14435 + THRESHOLD) )
    digitalWrite(motpin, LOW);
  else {
    digitalWrite(motpin, HIGH);
Logged
Offline Offline
Newbie
View Profile
trying to understand why it worked and not the previous code.  could it have something to do with the values continually moving slightly.
Logged
Offline Offline
Sr. Member
View Profile
exactly. All the other code required the servo to read *exactly* 14335.
Again, run the code yourself!
Logged
Offline Offline
Newbie
View Profile
sorry guys i can't get my head round this..  i thought if i use val > 14335 it would work for any value greater than 14335 regardless of wether the value moves slightly.
Logged
0
Offline Offline
Sr. Member
what?
View Profile
Code:
shouldn't this be
Code:
pulseIn(rcpin, LOW);
I think INPUT is defined as 0 anyway but just to clarify the code shouldn't it be LOW?
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
I never saw any code of the OPs of the form ( (14335 ? val) ?? (val ? 14335)), other than your reply to OP which I thought was a typo and Arrch's misreading of it.  Did OP edit his 14335/14535s in the original post?
Quote
Agreed
Logged
Offline Offline
Newbie
View Profile
Guys thanks for all your help on this, it's late here in the UK so calling it a day.  i'll run the code and try and get a better understanding. fantastic forum and thanks for helping me out.
Cheers
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
Hard to get your head around because you've gotten a lot of ideas, and some from every one of us has been wrong in one way or the other smiley
You could probably understand better if you broke it up like this?
Code:
  if (val > 15555){
     // joystick is FORWARD
  else if (val < 14444) {
     // joystick is REARWARD
  else {
     // joystick is NEUTRAL
I changed the numbers so we would quit misreading 14335/14535 smiley
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Actually, this is a perfect illustration of why magic numbers are a bad idea.
Code:
#define LOW_VAL 14335
#define HIGH_VAL 14535
if(val < LOW_VAL)
else if(val > HIGH_VAL)
means you correct an error/erroneous value in one place, and the logic is far easier to see.
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
Code:
if ( 14335 < val || val < 14535) {
Can be simplified to
Code:
if ( val != 14335) {
So you want the LED to be off at that value, and on otherwise? Seems a bit loft to expect it to be EXACTLY that value.
Actually I think that code simplifies to
Code:
if (val < 14535) {
Which is still in error, but not that error smiley
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
Absolutely!
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
