Topic: problem rc receiver signal (Read 7536 times) previous topic - next topic
KeithRB
Then you need something like (14330 < val) || (val < 14340))
or (abs (val-14335) < 5)
mustang493
johncc
This thread is a comedy of errors :)
mustang493
Guys, Arrch this worked.
int rcpin =7;
int motpin = 13;
const int THRESHOLD = 5;
  pinMode(rcpin, INPUT);
  pinMode(motpin, OUTPUT);
int val;
  val = pulseIn(rcpin, INPUT);
  Serial.println(val);
// if ((val > 14535) && (val < 14335))
//if ( 14335 < val || val > 14535)
if ( (val > 14435 - THRESHOLD) && (val < 14435 + THRESHOLD) )
    digitalWrite(motpin, LOW);
  else {
    digitalWrite(motpin, HIGH);
mustang493
trying to understand why it worked and not the previous code.  could it have something to do with the values continually moving slightly.
KeithRB
exactly. All the other code required the servo to read *exactly* 14335.
Again, run the code yourself!
mustang493
sorry guys i can't get my head round this..  i thought if i use val > 14335 it would work for any value greater than 14335 regardless of wether the value moves slightly.
P18F4550
shouldn't this be
pulseIn(rcpin, LOW);
I think INPUT is defined as 0 anyway but just to clarify the code shouldn't it be LOW?
johncc
I never saw any code of the OPs of the form ( (14335 ? val) ?? (val ? 14335)), other than your reply to OP which I thought was a typo and Arrch's misreading of it.  Did OP edit his 14335/14535s in the original post?
Agreed
mustang493
Guys thanks for all your help on this, it's late here in the UK so calling it a day.  i'll run the code and try and get a better understanding. fantastic forum and thanks for helping me out.
Cheers
johncc
Hard to get your head around because you've gotten a lot of ideas, and some from every one of us has been wrong in one way or the other :)
You could probably understand better if you broke it up like this?
  if (val > 15555){
     // joystick is FORWARD
  else if (val < 14444) {
     // joystick is REARWARD
  else {
     // joystick is NEUTRAL
I changed the numbers so we would quit misreading 14335/14535 :)
PaulS
Actually, this is a perfect illustration of why magic numbers are a bad idea.
#define LOW_VAL 14335
#define HIGH_VAL 14535
if(val < LOW_VAL)
else if(val > HIGH_VAL)
means you correct an error/erroneous value in one place, and the logic is far easier to see.
johncc
if ( 14335 < val || val < 14535) {
Can be simplified to
if ( val != 14335) {
So you want the LED to be off at that value, and on otherwise? Seems a bit loft to expect it to be EXACTLY that value.
Actually I think that code simplifies to
if (val < 14535) {
Which is still in error, but not that error :)
johncc
Absolutely!
