Loading...
Pages: [1]   Go Down
Author Topic: How to send via GSM the GPGGA line in GPS Shield using MCU with 2 h/w uart?  (Read 251 times)
Offline Offline
Newbie
View Profile
 HELP!! smiley-confuse
these r my boards:
GPS Shield             http://www.e-gizmo.com/KIT/gps%20shield.html
GSMGPRS Shield    http://www.e-gizmo.com/KIT/gsm%20shield.html
Gizduino+(Arduino) microcontroller with 2 h/w uart  http://www.e-gizmo.com/KIT/gizduino+%20164,324,644.html
« Last Edit: January 21, 2013, 09:33:12 am by IceScream » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Real links are more useful that text.
Where is your code to read from the GPS?
Where is your code that illustrates that you can send anything via the GSM shield? What do you want to send to?
Logged
Offline Offline
Newbie
View Profile
I used this code for GSM and microcontroller only,, and it works:
  GSM Send Sketch for Arduino
  Initializes GSM Module and sends an SMS to recipient
  The circuit:
  *Arduino pin 0 (RX) - GSM Module (TX)
  *Arduino pin 1 (TX) - GSM Module (RX)
  Created 2010
  by Meann Zabanal
  Modified
  by John for GSM Shield testing
char Rx_data[50];
unsigned char Rx_index = 0;
int i = 0;
char msg[160];
int sig;
  initGSM();
  send_msg("***********, "Hello");
  //none
void send_msg(char *number, char *msg)
  char at_cmgs_cmd[30] = {'\0'};
  char msg1[160] = {'\0'};
  char ctl_z = 0x1A;
  sprintf(msg1, "%s%c", msg, ctl_z);
  sprintf(at_cmgs_cmd, "AT+CMGS=\"%s\"\r\n",number);
  sendGSM(at_cmgs_cmd);
  delay(100);
  delay(100);
  delay(100);
  sendGSM(msg1);
  delay(100);
void sendGSM(char *string){
  Serial.write(string);
  delay(90);
void clearString(char *strArray) {
  int j;
  for (j = 100; j > 0; j--)
    strArray[j] = 0x00;
void send_cmd(char *at_cmd, char clr){
  char *stat = '\0';
  while(!stat){
    sendGSM(at_cmd);
    delay(90);
    readSerialString(Rx_data);
    stat = strstr(Rx_data, "OK");
  if (clr){
    clearString(Rx_data);
    delay(200);
    stat = '\0';
void initGSM(){
  send_cmd("AT\r\n",1);
//  send_cmd("ATE0\r\n",1); // Turn off automatic echo of the GSM Module
  send_cmd("AT+CMGF=1\r\n",1);         // Set message format to text mode
  //Sucess
  Serial.println("Success");
void readSerialString (char *strArray) {
  if(!Serial.available()) {
    return;
  while(Serial.available()) {
    strArray = Serial.read();
    i++;
//----------------------------------------------------AND This is my code for GPS Shield and MCU(works)-------------------------------
void loop() // run over and over
    while(!(Serial.available())){}
      Serial.write(Serial.read());
my problem is how to combine their code when i'm using 2 hardware uarts?? smiley-sad
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
The GPS shield you are using allows you to select pins 0 and 1 or pins 2 and 3 for the serial port.
The GSM shield you are using allows the same selection.
That the Gizduino may have more than one hardware serial port is irrelevant as far as those two shields are concerned. Unless you do some pin bending.
You'll need to use SoftwareSerial to talk to one of the devices.
Logged
Offline Offline
Newbie
View Profile
yes sir... i bend pins Rx = 0 and Tx = 1 on my GPS Shield and wired them on my MCU lower pins Rx = 2  and Tx = 3...
my Gsm Module that is connected on pins Rx = 0 and Tx = 1 is parallelled in the middle of my microcontroller and my GPS shield sir smiley
Logged
Offline Offline
Newbie
View Profile
How to call gps and gsm in arduino using 2 uart sir?
Serial.begin(9600); // gsm module?
Serial1.begin(9600); //gsp shield?
is this ok?
Logged
Pages: [1]   Go Up
Print
Jump to:
