Author Topic: [Solved] 74HC595 problems  (Read 451 times)
Belgium
Hi
I was trying to get my LED matrix working again today, and stumbled upon a problem. I have two 74HC595 cascaded. The first one (to which I send the data) is the colum driver, the 2nd one is the row driver.
Usually when you run this code:
int latchPin = 8; //9->8
int dataPin = 11; //8->11
int clockPin = 12; //10->12
byte col = 0b10000000;
byte row = 0b10000000;
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin, clockPin, LSBFIRST, row);
  shiftOut(dataPin, clockPin, MSBFIRST, col);
  digitalWrite(latchPin, HIGH);
The LED is constantly lit, right?
Since when you sent the data and pulled latchPin up, the register remembers its bits and keeps outputting them constantly, right?
Well, I don't see it. It keeps flickering every second.
It never lights up constantly, I really have no clue what I am doing wrong, I have checked the schematics over 10 times, and can't see any mistake.
Note the everything works actually, I can address every row and colum as I should be able to, but somehow the outputs of the shift registers don't have continuous outputs... Is it possible that I broke something?
Nick
« Last Edit: January 29, 2013, 09:42:20 am by Steen » Logged
Cape Town South Africa
A newbie with loads of posts, and still so much to learn !
How are you driving the LEDs  the 595s ?
« Last Edit: January 23, 2013, 10:26:07 pm by Boffin1 » Logged
We live in the era of the smart phones and stupid people.
Boston area, metrowest
Show your schematic.
Probably needs a 0.1uF cap on the Vcc pin of each part - and nowhere else.
Hi Crossroads,
and nowhere else.
Can we not get that example with the cap on the latch line corrected ?
http://arduino.cc/en/Tutorial/ShiftOut
When pigs fly apparently...
 smiley
Belgium
It's solved, There seemed to be a faulty cable, I just reconnected it and it works now smiley
The cable was one connected to GND, so that might be a reasonable explanation.
Eugene, Oregon
Hi Crossroads,
and nowhere else.
Pretty please? sigh could we also put some decoupling caps on the TLC5940 Tutorial too? how about a simple explanation of why you need them, what is the proper size, and how you determine the size.
Is that really too much to ask for? I suppose it probably is.
How dare you? Providing an example where the fault is not decoupling caps?
smiley
