Loading...
Pages: [1]   Go Down
Author Topic: I need one of these help  (Read 173 times)
Offline Offline
Newbie
View Profile
Looking for this kinda of controller ( http://www.servocity.com/html/heavy_duty_linear_servo__115__.html) . I have the linear acuator but the company will not sell the controller by itself ($300 bucks).
 Any one know where I can get one or how to make one?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
For $299, you can probably can make one yourself. Get a linear actuator like below with an internal pot, an h-bridge off of ebay to drive the actuator motor, and the internals of an inexpensive servo to drive the h-bridge. There is a similar setup on youtube if you do some searching.
http://www.firgelliauto.com/default.php?cPath=109&osCsid=bb2d15944a399aa562c01e2db59afbba
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
That thing probably has nothing more than a reversible motor [red and black wires], and a
limit switch on each end [green, white, and yellow wires inside the box, with one being the
common]. The controller is basically little more than a DPDT switch.
Hook up a battery, and run the motor untill the arm is fully out or fully in. Check the limit
switch wires with an ohmmeter.
Logged
Kitchen-Sink Arduino-compatible boards
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
No, they are true linear actuators using an internal pot for feedback signal to the controller to allow moving the actuator to any desired position using the same servo pulse timing as standard R/C servos, 1000usec to 2000usec pulse width.
http://www.firgelliauto.com/product_info.php?cPath=109&products_id=162&osCsid=324282d880549d03428fb5bc0cdf43fc
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
