Topic: Wave Shield can't open file (Read 2707 times) previous topic - next topic
Zarainia
Greetings,
I am using the wave shield with an arduino uno to play a .wav file (which I converted earlier from .mp3). The file plays fine on my computer, but won't open at all with the arduino. The message that shows up on the serial port is "couldn't open file CARILLONS.WAV". It comes from the code
Code: [Select]
  if (!f.open(root, name)) {
    putstring("Couldn't open file "); Serial.print(name); return;
I think that the code just comes from it couldn't open the file. Some other similar files play fine using it, just not this one.
Zarainia
I tried converting it again (I use the same settings for each file, and the others all worked), etc., and it still doesn't work...
majenko
"CARILLONS.WAV" has a 9.3 format filename, not 8.3   It will be being munged into something else like CARRIL~1.WAV.
Either rename it to something in 8.3 or find out its proper 8.3 format equivalent.
Zarainia
How do you figure out if something is 8.3 or not?
Zarainia
