Topic: DHT11 too high values (Read 6359 times) previous topic - next topic
joyce973
Hello, I am a newbie on Arduino matters.
I connected a DHT11 hum/temp sensor to my Arduino Leonardo as shown here:
http://www.ladyada.net/wiki/tutorials/learn/sensors/dht.html
using the suggested code, and it seems to work fine.
But, the data I received in the log are quite strange: values are too high (about 600° C temp / 1200% humidity).
How could it be possible?
thanks
A
RIDDICK
the dog ate the sensor?  :D
are all readings wrong?
or just <10%?
r u sure u connected the wires right?
joyce973
I just followed the scheme in the URL. Maybe is there some difference with the Leonardo board?
Riva
Did you connect to same pins as described in the tutorial and select correct device in there example code as it defaults to DHT22 and not DHT11
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
robtillaart
The humidity of this sensor is discussed here in the past and its accuracy is not always high.
Sometimes recalibration helps, see datasheet, but not always.
Rob Tillaart
joyce973
Riva, you are right! It was declared as DHT22.... Sorry, I'm still a beginner..
thank you
A
Riva
Glad you got it working okay and it's not a faulty device.
rachmitah
​hi, i have a problem, why the result of my sensor DHT11 in serial monitor is -999.0? i already connected correctly
how i do solve this? please help
robtillaart
Check the code of the library.
#define DHTLIB_INVALID_VALUE    -999
so the -999 is an indication that something went wrong.
please print the returnvalue of the DHT.read() function
best is to check the wiring and the pins at least twice :)
Rob Tillaart
