Topic: My ITDB02 keeps being blank (Read 2453 times) previous topic - next topic
Dizplai
I've bought a Arduino Uno, the
http://www.exp-tech.de/Shields/ITDB02-Arduino-Shield-V2-0--Arduino-kompatibel-.html
and the
http://www.exp-tech.de/Displays/3-2--TFT-LCD-Screen-Module--ITDB02-3-2S.html.
After uploading an unmodified copy of the UTFT_Textrotation_Demo the screen is backlighted but keeps being blank.
The adaptor shield is set to 5V operation voltage.
The Uno works, because a message printed with Serial.println() appears in the Serial Monitor.
What am I doing wrong?
Docedison
Post your sketch... very hard to guess with no information about what you have done or not ne.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
Dizplai
Code: [Select]
// UTFT_Textrotation_Demo (C)2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the textrotation-functions.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
// Uncomment the next line for Arduino 2009/Uno
UTFT myGLCD(ITDB32S,19,18,17,16);   // Remember to change the model parameter to suit your display module!
// Uncomment the next line for Arduino Mega
//UTFT myGLCD(ITDB32S,38,39,40,41);   // Remember to change the model parameter to suit your display module!
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(BigFont);
    myGLCD.print("Text rotation", 0, 0);
    myGLCD.setColor(0, 0, 255);
    myGLCD.print("0 degrees", 0, 16, 0);
    myGLCD.print("90 degrees", 319, 0, 90);
    myGLCD.print("180 degrees", 319, 239, 180);
    myGLCD.print("270 degrees", 0, 239, 270);
    myGLCD.setFont(SevenSegNumFont);
    myGLCD.setColor(0, 255, 0);
    myGLCD.print("45", 90, 100, 45);
    myGLCD.print("90", 200, 50, 90);
    myGLCD.print("180", 300, 200, 180);
  while (true) {};
doc_norway
You are not doing anything wrong. You have just bought hardware that is incompatible.
Your shield only supports 8bit display modules, and the display modules is a 16bit module.
You will never be able to get it working without extensive modifications to the shield.
/Henning
Dizplai
Thanks for your answer!
Is there a shield that support 16bits?
doc_norway
If you are not afraid of a little soldering you can use this: http://imall.iteadstudio.com/prototyping/kits/im120717002.html
You can probably find something similar already soldered on eBay or something as well. The main thing is that you should be looking for a pre-v2.0 shield.
These usually have jumpers to select between 8bit and 16bit modules.
Just be aware that a 16bit display module will use all the available I/O on the Uno just for the display. You will not be able to use the touch screen or the SD card slot.
/Henning
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
