Topic: Where to start? (Read 1 time) previous topic - next topic
dfargo5133
What is the best way to layout a project like this? I am not asking for somebody to write the code for me just how you start a complex project
It is a modelrailroad diamond interlocked crossing. For example if a train enters the "plant" at say detector 1 the program should check to see that none of the other detectors have a tain over them. Then turn Signal 1 green, as soon as the train is over detector 2 it should turn signal 1 red again. etc... etc... etc...
Thanks
Dan
michinyon
The first thing I would do,   is decide whether I am going to implement a solution for one, fixed, specific track topology,   or alternatively,  implement some kind of generic object oriented design which I could apply to any model railroad network.
The next thing I would do,  is consider very carefully what actions I want to take when any of the sensors changes its input state.
The next thing I would do after that,  is try and write down all the "states"  that the system can be in,   and consider what events
happen when transitioning from one state to another,   and then try to check whether all contingencies of train maloperation and/or
sensor maloperation  are covered.   Because a railway signalling system has to be fail-safe.
ash901226
you mean interlocking?
Urm interesting.
you could start chart all the possibly outcome that you might expect.
then some flowchart or flow diagram
you need to design each signal to be independent of each other but at the same time work coherently (in parallel)
then convert your chart to become your program..
once you have the chart i could help you change that into a program.
HazardsMind
There are a few ways to do this, the first would be to set a condition so that only one signal is green when needed. You also need to take into consideration if four trains are by some chance on detectors 1,4,5 and 8, to decide which train came first, and allow that train to move.
But to answer your first problem, with the detectors turning on and off when a train passes over them, I would use a Set/reset latch. Of course checking the other detectors as well, but I would first try to get that to work.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
PeterH
In the initial state you wait for the outer detector for any of the lines to be triggered. When you detect a trigger, set that the signal for that line green, wait for the train to trigger the inner detector and then set the signal red again.
For flexibility I'd implement this junction as a state machine (the state variable would indicate which line (if any) is currently green), and I'd use a non-blocking state machine to 'wait' for the detection triggers rather than blocking until the expected event arrived; this would make it possible for the same processor to control multiple junctions or carry out other activities at the same time. But for a crude proof of concept, a blocking approach would probably only take a dozen lines of code.
wildbill
I'd suggest for the inner detector that you wait for it to be triggered, then wait until it's not detecting before releasing other trains. Indeed to be really safe, I'd prefer the second detector to be on the far side of the crossing, not before it.
Henry_Best
Me too. Given the indeterminate speed and length of the trains, there must be a detection of the crossing having been cleared. Then he'll have to consider a following train or a train coming from the opposite direction before allowing any crossing movements on the other railroad.
Before the outer detector can set the signal to green, he'll have to check that the crossing is clear and that no train on the other railroad is about to cross.
Coding wouldn't be too difficult, just loads of If statements
