Topic: Send data over USB from iPad to Arduino (Read 8239 times) previous topic - next topic
prismspecs
I've seen a short youtube video of someone doing what I want, but no explanation was given. I would like a text input box on the iPad which would send that string data to the Arduino. Any ideas?
Quick5pnt0
Ethernet shield configured as a server that serves a webpage with a text box on it?
cmiyc
http://www.makershed.com/Redpark_TTL_Cable_for_iOS_p/msrp03.htm
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
prismspecs
I appreciate the heads up but the $50 connection seems steep to me. This guy did it without the aid of special equipment: http://www.youtube.com/watch?v=NU8uDrhBFvE
cmiyc
prismspecs
I don't mind jailbreaking an iPad, I just have no clue where to start. I'm a little surprised there isn't much info out there about this.
cmiyc
Search google for "ipad camera connection kit usb jailbreak"
KeithRB
You might not need to jailbreak, but you will need a Mac, Xcode and $99 to put your program on the iPad by joing the Apple Developer program. Check out the Apple developer forums:
https://discussions.apple.com/community/developer_forums
PeterH
This sounds far simpler and safer than trying to establish hardware connections to the iPad.
Quick5pnt0
I just thought about it but there is another solution but you'll still need an ethernet shield. There is an app called Arduino Manager in the app store that allows you to control various elements on your Arduino through your ipad. In the description for the app it says there is a way to send text commands to the board which should allow you to do what is shown in the video above.
BTW You can do it the way the video shows but it is much harder to accomplish because you'll need to be able to create your own IOS app.
be80be
The iPad Camera Connection kit let's use USB to serial adapters.
HHNET
James,
This dedicated cable is very cool.
Thanks.
Harry
Quick5pnt0
#12
Jan 24, 2013, 04:27 am Last Edit: Jan 24, 2013, 04:30 am by Quick5pnt0 Reason: 1
True but you still need an app to do something with that connection. I'm not trying to discourage the OP from taking that route if he really wants but more than likely if he is asking these questions he probably isn't familiar with programming IOS apps and probably doesn't realize how tough it will be.
be80be
Have you seen this https://itunes.apple.com/us/app/get-console/id412067943?mt=8&ls=1
