UK
« Reply #15 on: January 25, 2013, 07:35:18 pm » |
Each transfer sends 8 bits, so 2 x transfer does 16 bits.
I see - but your example sends a 0 byte, then the address byte, should that not occur in the opposite order? Then, it's followed by another two 0 bytes?
« Last Edit: January 25, 2013, 07:37:55 pm by jtw11 »
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #16 on: January 25, 2013, 07:54:26 pm » |
It agrees with the diagram on the previous page. Take a look at the SI (bottom left) part. There are 4 x 8-bit bytes there, with the MSB first (most significant). So sending a zero first fills up the most significant bits with zero, followed by the register address. Then we fire off two more zeroes which do the transfer which lets the device reply.
« Last Edit: January 25, 2013, 07:56:19 pm by Nick Gammon »
UK
« Reply #17 on: January 25, 2013, 08:20:21 pm » |
There are four bytes? I've read the diagram as two bytes, due to the presence of the bit 14 and bit 13 labels on the same diagram? However, I don't see what ADR0 & ADR1 refer to? Does a 16 bit data frame not include the address? Does the fact that reading and writing from/to the same register uses a different address play a part here? I've got a BASIC code that interfaces with this chip, however the notes are a rough German to English translation, and I know nothing yet of BASIC. I'll post it up in the morning, it's late this side of the planet :-)
Shannon Member
Lua rocks!
« Reply #18 on: January 25, 2013, 08:44:25 pm » |
OK, I misread that bit.  Still that clearly shows you send a byte and get one back afterwards. So: SPI.transfer(0x48); // command byte result = SPI.transfer(0);
Shannon Member
Lua rocks!
« Reply #19 on: January 25, 2013, 08:45:45 pm » |
If there's any more confusion, post all your code, not just a couple of lines. You need to set SS low before those two transfers.
UK
« Reply #20 on: January 26, 2013, 07:02:10 am » |
Okay, so here's my full code - sorry, I'm still using binary at the moment. The device isn't connected to the O2 sensor yet, so I'm expecting a fault code on the serial monitor. /* This code segment is written to test functionality of the CJ125 O2 interface hardware It is not intended to be used as working code, ONLY for hardware testing purposes as there are multiple routes into a never ending such as a fault flag print for example Notes: - use PID gains of Kp = 80, Ki = 25 for LSU 4.2 - DIAG_REG = 0x78 = 01111000 - IDENT_REG = 0x48 = 01001000 - INIT_REG1 RD = 0x6C = 01101100 - INIT_REG1 WR = 0x56 = 01010110 - INIT_REG2 RD = 0x7E = 01111110 - INIT_REG2 WR = 0x5A = 01011010 TODO */
#include <PID_v1.h> #include <SPI.h> #include <EEPROM.h> #include <EEPROMAnything.h>
// define constants that won't change, such as assigning names to pin numbers
const int UR_pin = A0; const int UA_pin = A1; const int heater_pin = 3; const byte chip_select = 10;
// define sampling timers
unsigned long fault_current_millis = 0; unsigned long fault_previous_millis = 0; unsigned long fault_interval_millis = 2000; unsigned long pumpprint_current_millis = 0; unsigned long pumpprint_previous_millis = 0; unsigned long pumpprint_interval_millis = 100;
// define variables that will change
double UR_c = 0; double UA_c = 0; double UR_m = 0; double UA_m = 0; double heater_duty = 0; int cold_threshold = 990; double IP = 0; boolean fault = false; boolean cold_start = false; byte ident_reg_contents = B00000000; byte diag_reg_contents = B00000000;
PID heater_PID(&UR_m, &heater_duty, &UR_c, 80, 25, 0, DIRECT);
void setup() { Serial.begin(9600);
// assign pinModes - only outputs need to be set, defaults are input pinMode(chip_select, OUTPUT); digitalWrite(chip_select, HIGH); // set CS high, as CS is active low pinMode(heater_pin, OUTPUT);
// initialise SPI bus SPI.begin(); SPI.setBitOrder(MSBFIRST); // sets SPI data transfer to MSB first SPI.setDataMode(SPI_MODE1); // sets SPI mode to MODE1 SPI.setClockDivider(SPI_CLOCK_DIV8); // sets shared clock rate to 16Mhz / 8 = 2Mhz
/*read calibration values from EEPROM to allow heater PID and pump current calculations to function without recalibration or from hot start */ UR_c = EEPROM_readAnything(0, UR_c); UA_c = EEPROM_readAnything(8, UA_c);
// select chip digitalWrite(chip_select, LOW);
// identify CJ125 SPI.transfer(B01001000); ident_reg_contents = SPI.transfer(B00000000); if (ident_reg_contents != B00000000) { Serial.println(""); Serial.println("SPI comms successful!"); Serial.println(""); Serial.print("CJ125 Device ID - "); Serial.print(ident_reg_contents); } else Serial.println("SPI comms failed!"); Serial.print(ident_reg_contents); // enable diagnostics and set reference pump current SPI.transfer(B01011010); SPI.transfer(B00010010);
// read diagnoses registers SPI.transfer(B01111000); diag_reg_contents = SPI.transfer(B00000000);
// is there a fault? set fault boolean and print to serial if (diag_reg_contents != B11111111) { fault = true; }
// deselect chip digitalWrite(chip_select, HIGH);
// check probe temperature, set cold start boolean UR_m = analogRead(UR_pin); if (UR_m >= cold_threshold) { cold_start = true; }
// enable heater PID, define sample time and set output limits heater_PID.SetMode(AUTOMATIC); heater_PID.SetSampleTime(100); heater_PID.SetOutputLimits(0, 255); }
void probe_warmup() { // heat up probe (assumes 20degC cold start, ramps from 8v effective duty at 0.4v/s to 100% duty. ~ 15sec) Serial.println("Probe Heating"); for (heater_duty = 145; heater_duty <= 255; heater_duty++) { analogWrite(heater_pin, heater_duty); delay(138); } Serial.println("Probe Heat Complete"); // set cold start flag to false cold_start = false; }
void loop() { if (fault == false && cold_start == true) { // enter calibration mode SPI.transfer(B01010110); // INIT_REG1 WR SPI.transfer(B00010100); // sets RA & LA to 1
// sample calibration values of UR & UA UR_c = analogRead(UR_pin); UR_c = map(UR_c, 0, 5, 0, 255); UA_c = analogRead(UA_pin); UA_c = map(UA_c, 0, 5, 0, 255);
// save UR_c & UA_c to EEPROM (flash in actual board, EEPROM for test) EEPROM_writeAnything(0, UR_c); EEPROM_writeAnything(8, UA_c);
// warm up probe probe_warmup();
// enter measurement mode - LA bit controls pump current offset cal, PA controls whether pump current can flow SPI.transfer(B01010110); // INIT_REG1 WR SPI.transfer(B00000000); // sets RA & LA to 0 } else if (fault == false) { // run loop code here to update heater PID and calculate pump current periodically UR_m = analogRead(UR_pin); UR_m = map(UR_m, 0, 5, 0, 255); heater_PID.Compute(); analogWrite(3, heater_duty);
UA_m = analogRead(UA_pin); UA_m = map(UA_m, 0, 5, 0, 255); unsigned long pumpprint_current_millis = millis(); if (pumpprint_current_millis - pumpprint_previous_millis > pumpprint_interval_millis) { pumpprint_previous_millis = pumpprint_current_millis;
IP = (UA_m - UA_c) / (8 * 61.9); // check this will actually conform BODMAS style
Serial.print("Pump Current = "); Serial.print(IP); Serial.println(""); } } else { // print fault flag to serial every 2 sec unsigned long fault_current_millis = millis(); if (fault_current_millis - fault_previous_millis > fault_interval_millis) { fault_previous_millis = fault_current_millis; Serial.println(""); Serial.print("Fault Code = "); Serial.print(diag_reg_contents); } } } ...and here's what I get on the serial monitor. SPI comms successful!
CJ125 Device ID - 9999 Fault Code = 0 Fault Code = 0
So, it looks like it is working, sort of - however, is looks like there is a problem printing binary bytes to the serial monitor? Do I have to do some conversion here? I am expecting the identity to be 01100xxx, where xxx are unknown to me yet. I'm also expecting an 8 bit number for the diagnosis register.
« Last Edit: January 26, 2013, 08:23:39 am by jtw11 »
UK
« Reply #21 on: January 26, 2013, 09:22:52 am » |
You have a couple of bugs here: if (ident_reg_contents != B00000000) { Serial.println(""); Serial.println("SPI comms successful!"); Serial.println(""); Serial.print("CJ125 Device ID - "); Serial.print(ident_reg_contents); } else Serial.println("SPI comms failed!"); Serial.print(ident_reg_contents);
Firstly, you don't print a newline after printing the device ID. CHange that call to println(). Secondly, the else clause only applies to the immediately-following statement. Your code is actually the same as this: if (ident_reg_contents != B00000000) { Serial.println(""); Serial.println("SPI comms successful!"); Serial.println(""); Serial.print("CJ125 Device ID - "); Serial.print(ident_reg_contents); } else { Serial.println("SPI comms failed!"); } Serial.print(ident_reg_contents);
In other words, you print the device ID twice and because you haven't included a newline they are merged and appear to be a single number. The clue that this isn't the case is that the value 9999 is too big to be stored in a byte. I recommend that you get in the habit of always following if, else, for, while and so on with a compound statement i.e. { and } even when there is only a single statement there. The existence of these bugs is further hidden by the code you use to print the fault code, which prints a blank line before outputting the fault code rather than after. I recommend you output the newline at the point you finish writing the line out, not at the start of the next line. The actual ID being printed is 99, which is binary 01100011.
UK
« Reply #22 on: January 26, 2013, 10:26:03 am » |
Peter You're an absolute star! Thank you! (and of course, Nick Gammon & his tutorial page!) I've made the changes you recommend and successfully printed the following on the serial monitor; SPI comms successful!
However, is there a way to - instead of displaying a decimal 99, to display the binary value in the serial monitor instead?
Seattle, WA USA
Seattle, WA USA
« Reply #23 on: January 26, 2013, 10:48:26 am » |
is there a way to - instead of displaying a decimal 99, to display the binary value in the serial monitor instead? The Serial::print() method accepts an optional second argument - HEX, OCT, BIN, DEC, etc. The names should give you a clue as to the purpose of the second argument.
UK
« Reply #24 on: January 29, 2013, 06:22:05 am » |
Ha, I'd be worried if I couldn't work out those second arguments! So, I've changed my code to include the binary arguments, but don't quite understand the prints I'm getting back out. /* This code segment is written to test functionality of the CJ125 O2 interface hardware It is not intended to be used as working code, ONLY for hardware testing purposes as there are multiple routes into a never ending such as a fault flag print for example Notes: - use PID gains of Kp = 80, Ki = 25 for LSU 4.2 - DIAG_REG = 0x78 = 01111000 - IDENT_REG = 0x48 = 01001000 - INIT_REG1 RD = 0x6C = 01101100 - INIT_REG1 WR = 0x56 = 01010110 - INIT_REG2 RD = 0x7E = 01111110 - INIT_REG2 WR = 0x5A = 01011010 TODO */
// identify CJ125 SPI.transfer(B01001000); ident_reg_contents = SPI.transfer(B00000000); if (ident_reg_contents != B00000000) { Serial.println(""); Serial.println(""); Serial.println("SPI comms successful!"); Serial.print("CJ125 Device ID - "); Serial.println(ident_reg_contents, BIN); } else { Serial.println("SPI comms failed!"); Serial.print(ident_reg_contents, BIN); } // enable diagnostics and set reference pump current SPI.transfer(B01011010); SPI.transfer(B00010010);
Serial.print("Pump Current = "); Serial.print(IP); Serial.println(""); } } else { // print fault flag to serial every 2 sec unsigned long fault_current_millis = millis(); if (fault_current_millis - fault_previous_millis > fault_interval_millis) { fault_previous_millis = fault_current_millis; Serial.println(""); Serial.print("Fault Code = "); Serial.print(diag_reg_contents, BIN); } } } Prints SPI comms successful! CJ125 Device ID - 1100011
Fault Code = 0 Fault Code = 0 Fault Code = 0
The device ID is coming out with 7 bits, not the full 8? ...and as for the fault code, I'm expecting 00000000, not 0?
« Last Edit: January 29, 2013, 06:24:20 am by jtw11 »
Shannon Member
Lua rocks!
« Reply #25 on: January 29, 2013, 03:24:45 pm » |
It doesn't add leading zeroes.
You could write your own function which does.
UK
« Reply #26 on: January 29, 2013, 04:49:41 pm » |
Ah, I see. That would explain then why the fault code which I was expected to be 00000000 simply prints as 0. I shall get to work on editing the print function to print the whole byte. Thanks!
Seattle, WA USA
Seattle, WA USA
« Reply #27 on: January 30, 2013, 07:17:41 am » |
I shall get to work on editing the print function to print the whole byte. It IS printing the whole byte. The whole byte is 0. If you want to print 0 as "00000000", that is your business, but the Print class is not the place to do that!
UK
« Reply #28 on: January 30, 2013, 05:14:51 pm » |
I shall get to work on editing the print function to print the whole byte. Really, I should have typed - "...to print all bits in the byte". But, why the practice of omitting leading zeros? I see no point in it, as the whole byte has to sent over serial regardless...
Shannon Member
Lua rocks!
« Reply #29 on: January 30, 2013, 05:17:56 pm » |
But, why the practice of omitting leading zeros? Er, why do you type: 42 instead of: 00000000000042
