Topic: Arduino project for motorhome (Read 2143 times) previous topic - next topic
squalo
hello  :D
from the natio of the Arduino a request for help for a project.
On my motorhome I would like to make a touch screen control panel for controlling the heating (on - off, 3-level fan, gas valve control, outside temperature and internal, thermostat) and for the control of external openings, and the values ??of battery .
A project that could have further developments.
Which Arduino is best suited for my project and what touch screen (7 "?)
If I want to make a good looking menu, with other sub-menu, which Arduino can give me this chance?
thanks
PeterH
The moment you say 'touch screen' it makes me think this is not going to be an Arduino problem. Particularly if you want it to look attractive, I think your best bet would be to use a touch screen tablet as your main controller, just using an Arduino if necessary to interface to external hardware.
I only provide help via the forum - please do not contact me for private consultancy.
laadams85
You could possibly look into using this
http://playground.arduino.cc/SmartGPU/SmartGPU
It looks really cool but also really difficult to program a nice looking UI
squalo
@ PeterH then a program Android and bluetooth transmission to a receiver module with Arduino?
@ laadams I saw this screen, but it costs a lot, compared to a tablet
thanks
Graynomad
avenue33 (one of our members) has a library for 4D Systems LCD but they only go to 4.3"
I'm in the process of doing the same for my motorhome using an RS-485 network of custom-designed Arduinos. At this point I haven't thought too much about the UI but my gut feeling is that these days a WiFi/BT link to a tablet is the best way to go.
_____
Rob
mirkougolini
Hello everyone,
I'm a Italian motorhome owner who made a device to remotely control the Truma combi.
I used BASCOM AVR with ATM32 But I planing to port all the project to Arduino Leonardo.
You can find information on my personal Blog
http://e-domotics.blogspot.it/2013/07/dispositivo-mrc.html
in simple terms the device can be used for control completely the Truma combi by a IR remote control, By SMS and Bluetooth.
I also made ??a Android application which allows better control of the boiler.
Let me know what you think about the project.
It took me 4-5 years to develop and I would like to receive some comments (both positive or negative)
Sincerely
Mirko Ugolini
Graynomad
I give up, what's a "Truma combi"?
______
Rob
DaAwesomeP
Truma Combi is a liquid gas heater/boiler system.
Some resources and ideas:
  • Here is a thermostat project that had a link on the Arduino Playground: http://arduinothermostat.blogspot.co.uk/
  • Here is a page on the Arduino Playground that shows different libraries and resources for interfacing with Environmental Hardware (Temperature, Humidity, etc.): http://playground.arduino.cc//Main/InterfacingWithHardware#envtop
  • Controlling a Gas Valve with unprofessional hardware, products, and precautions or not having it inspected by a professional can be very dangerous.
  • If the external opening are controlled by regular light switches, it would be possible to use relays and switches to open/close and detect the current state of the openings.
  • If you have the Ethernet Shield, you could have a web server running (http://arduino.cc/en/Tutorial/WebServer) and then control it easily from a computer, tablet, or phone on the same network. Wifi routers (and non-wireless network switches) don't need an internet connection to work (if your motor-home doesn't have one like 3G or 4G) . If you do want an internet connection, just search for a 4G modem or router.
Didi I break it yet? :D
aaron361068
Hi just saw this and am working on a similar project
my jeep has a lot of extra features plus some things that i had to cheaply replace (like the windshield wipers broke and it would be expensive to replace the switch system)
anyway my project just uses a small lcd screen and two buttons to navigate through a menu. not as cool as a touch screen but you might be able to barrow some of my code or use my idea. cost is pretty low. just lcd, relay, arduino mega and two buttons.
its is not complete yet because while i was doing the final touches on the project i think i fried my arduino and am waiting for a new one. hahaha. im a newbie i know.
anyways here is my code seems to work although maybe overly complicated, i dont know im not that good.
const int pushButtonPin = 50;  //button that will swithch between modes, like windsheld wippers, and rearlight
const int selector = 51;   // button that will change the settings of each modewindshieldpower
int pressCount = 0;
int selectCount = 0;
int windshieldpower = 38;  // i want this to be able have to ability to be on / off / and intermittently on so that
int frontlightspower = 50;
int rearlightpower = 36;
int radiopower = 40;
int flashlightpower = 42;
int hampower = 44;
int antennauppower = 46; //antenna up and down is seperate because the factory motor has a seperate wire for moving up and moving down
int antennadownpower = 48;
int acc = 30;
int prevState = LOW; //part of debounce/counter for the mode button
int currState;
int prevState2 = LOW; //part of dedbounce/ coutner for the selector button
int currState2;
#include <Wire.h>
#include <LiquidCrystal.h>   // include LCD library
#define LCD_BACKLIGHT_OFF()     digitalWrite( LCD_BACKLIGHT_PIN, LOW )
#define LCD_BACKLIGHT_ON()      digitalWrite( LCD_BACKLIGHT_PIN, HIGH )
#define LCD_BACKLIGHT(state)    { if( state ){digitalWrite( LCD_BACKLIGHT_PIN, HIGH );}else{digitalWrite( LCD_BACKLIGHT_PIN, LOW );} }
byte buttonJustPressed  = false;         //this will be true after a ReadButtons() call if triggered
byte buttonJustReleased = false;         //this will be true after a ReadButtons() call if triggered
LiquidCrystal lcd( 8, 9, 4, 5, 6, 7 );
int lastpresscount = 0;
int lastselectcount =0;
int windshieldmode = 0;
int frontlightsmode = 0;
int rearlightmode = 0;
int radiomode = 0;
int flashlightmode = 0;
int hammode = 0;
int antennamode = 0;
int windshieldonoff1 = LOW;
int windshieldonoff2 = LOW;
int windshieldstatus=LOW ;
int rearlighton = LOW;
long int delaytimer = 0;
long int rearlightwait = 0;
int rearlightoff = LOW;
int rearlighttemp = LOW;
int radiooff = LOW;
int radioon = LOW;
int radioacc = LOW;
int antennaup = LOW;
int antennadown = LOW;
long int antennadelay = 0;
long int delaytimer2 = 0;
long int delaytimer3 = 0;
int accmode = LOW;
long int timer = 0;
long previousMillis = 0;
 pinMode(22,OUTPUT);
 digitalWrite(22,HIGH);
 lcd.begin( 16, 2 );
 lcd.setCursor( 1, 0 );
 lcd.print( "SCOUT CONTROL" );
 lcd.setCursor( 5, 1 );
 lcd.print( "Ready" );
 pinMode(pushButtonPin, INPUT);
 digitalRead(pushButtonPin);
 // digitalWrite(pushButtonPin, OUTPUT);
 pinMode(selector, INPUT);
 digitalRead(selector);
 //digitalWrite(selector, OUTPUT);
 pinMode(acc,INPUT);
 digitalRead(acc);
 pinMode(windshieldpower, OUTPUT);
 pinMode(frontlightspower, OUTPUT);
 pinMode(rearlightpower, OUTPUT);
 pinMode(radiopower , OUTPUT);
 pinMode(flashlightpower , OUTPUT);
 pinMode(hampower , OUTPUT);
 pinMode(antennauppower, OUTPUT);
 pinMode(antennadownpower, OUTPUT);
 unsigned long currentMillis = millis();
 timer = currentMillis - previousMillis;
 if(currentMillis - previousMillis > 10000) {
   previousMillis = currentMillis;
 currState = digitalRead(pushButtonPin);
 if (currState != prevState)
   if (currState == HIGH)
     pressCount++;
   delay(1);
 prevState = currState;
 currState2 = digitalRead(selector);
 if (currState2 != prevState2)
   if (currState2 == HIGH)
     selectCount++;
   delay(1);
 prevState2 = currState2;
 if(pressCount > 9)
   pressCount = 0;
 if(pressCount != lastpresscount)
   if(pressCount == 1)
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("windsheild");
     lcd.setCursor(0,1);
     lcd.print("Mode:");
     selectCount = windshieldmode;
   if(pressCount == 2)
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("frontlights");
     lcd.setCursor(0,1);
     lcd.print("Mode:");
     selectCount = frontlightsmode;
   if(pressCount == 3)
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("rearlight");
     lcd.setCursor(0,1);
     lcd.print("Mode:");
     selectCount = rearlightmode;
   if(pressCount == 4)
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("radio");
     lcd.setCursor(0,1);
     lcd.print("Mode:");
     selectCount = radiomode;
   if(pressCount == 5)
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("flashlight");
     lcd.setCursor(0,1);
     lcd.print("Mode:");
     selectCount = flashlightmode;
   if(pressCount == 6)
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("HAM");
     lcd.setCursor(0,1);
     lcd.print("Mode:");
     selectCount = hammode;
   if(pressCount == 7){
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("Antenna");
     lcd.setCursor(0,1);
     lcd.print("Mode:");
     selectCount = antennamode;
   if(pressCount == 0)
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("Scout Control");
 Serial.println();
aaron361068
sorry my code was so long the website wouldnt allow it so here is the second half
  if(pressCount != lastpresscount || selectCount != lastselectcount )
    if(pressCount == 1)
      if(selectCount == 1)
        lcd.setCursor(7,1);
        lcd.print("OFF");
        windshieldstatus=LOW;
      if(selectCount == 2)
        lcd.setCursor(7,1);
        lcd.print("IN1");
        windshieldonoff1 = HIGH;
      if(selectCount == 3)
        lcd.setCursor(7,1);
        lcd.print("IN2");
        windshieldonoff2 = HIGH;
      if(selectCount == 4)
        lcd.setCursor(7,1);
        lcd.print(" ON");
        windshieldstatus = HIGH;
      if(selectCount > 4)
        selectCount = 0;
      windshieldmode = selectCount;
    if(pressCount == 2)
      if(selectCount == 1){
        lcd.setCursor(7,1);
        lcd.print("OFF");
        digitalWrite(frontlightspower ,LOW);
        lcd.setCursor(7,1);
        lcd.print(" ON");
        digitalWrite(frontlightspower ,HIGH);
      if(selectCount > 2)
        selectCount = 0;
      frontlightsmode = selectCount;
    if(pressCount == 3)
        lcd.setCursor(7,1);
        lcd.print("OFF");
        rearlightoff=HIGH;
        rearlighton=LOW;
        rearlighttemp=LOW;
        lcd.setCursor(7,1);
        lcd.print("TMP");
        rearlighttemp = HIGH;
        rearlighton=LOW;
        rearlightoff=LOW;
        lcd.setCursor(7,1);
        lcd.print(" ON");
        rearlighton = HIGH ;
        rearlightoff=LOW;
        rearlighttemp=LOW;
      if(selectCount > 3)
        selectCount = 0;
      rearlightmode = selectCount;
    if(pressCount == 4)
        lcd.setCursor(7,1);
        lcd.print("OFF");
        radiooff = HIGH ;
        radioon = LOW;
        radioacc = LOW;
        lcd.setCursor(7,1);
        lcd.print("ACC");
        radioacc = HIGH;
        radioon= LOW;
        radiooff= LOW;
        lcd.setCursor(7,1);
        lcd.print(" ON");
        radioon = HIGH;
        radiooff= LOW;
        radioacc = LOW;
        radioon = LOW;
      if(selectCount > 3)
        selectCount = 0;
      radiomode = selectCount;
    if(pressCount == 5)
        lcd.setCursor(7,1);
        lcd.print("OFF");
        digitalWrite(flashlightpower ,LOW);
        lcd.setCursor(7,1);
        lcd.print(" ON");
        digitalWrite(flashlightpower ,HIGH);
      if(selectCount > 2)
        selectCount = 0;
      flashlightmode = selectCount;
    if(pressCount == 6)
        lcd.setCursor(7,1);
        lcd.print("OFF");
        digitalWrite(hampower ,LOW);
        lcd.setCursor(7,1);
        lcd.print(" ON");
        digitalWrite(hampower ,HIGH);
      if(selectCount > 2)
        selectCount = 0;
      hammode = selectCount;
    if(pressCount == 7)
        lcd.setCursor(7,1);
        lcd.print("DWN");
        antennadown = HIGH;
        antennaup= LOW;
        lcd.setCursor(7,1);
        lcd.print(" UP");
        antennaup= HIGH;
        antennadown= LOW;
      if(selectCount > 2)
        selectCount = 0;
      antennamode = selectCount;
  //windsheildfuntion...............................................
  if(windshieldonoff1 == HIGH)
    if(timer < 7000)
    if(timer > 7000)
  if(windshieldonoff2 == HIGH)
    if(timer < 4000)
    if(timer > 4000)
  digitalWrite(windshieldpower,windshieldstatus);
  // Rear light function.......................................
  if(rearlighton==HIGH)
    digitalWrite(rearlightpower,HIGH);
  if(rearlighttemp == HIGH)
    delaytimer = currentMillis;
  if(rearlightwait > 180000 && rearlighton== LOW)
    digitalWrite(rearlightpower, LOW);
  if (rearlightoff==HIGH)
    digitalWrite(rearlightpower,LOW);
  rearlightwait= currentMillis - delaytimer;
  //radio funtion.................................
  if (radioacc == HIGH && accmode == HIGH)
    digitalWrite(radiopower, HIGH);
  if (radioacc == HIGH && accmode == LOW)
    digitalWrite(radiopower, LOW);
  if (radioon == HIGH)
  if (radiooff == HIGH)
  //antenna function...............................
  if(antennaup == HIGH)
    digitalWrite(antennauppower,HIGH);
    digitalWrite(antennadownpower, LOW);
    delaytimer2 = millis();
    antennaup = LOW;
  if(antennadown == HIGH)
    digitalWrite(antennadownpower, HIGH);
    digitalWrite(antennauppower,LOW);
    antennadown = LOW;
  if(antennadelay > 10800000 && antennadelay < 10805000)
    delay(9000);
  if(antennadelay > 9000)
  antennadelay=currentMillis-delaytimer2;
  accmode=digitalRead(acc);
  lastselectcount = selectCount;
  lastpresscount = pressCount;
