Loading...
Pages: 1 [2]   Go Down
Author Topic: Button Sequence question  (Read 413 times)
Offline Offline
Newbie
View Profile
Not familiar with edge detection, do you mean just a state change detection?  If I used that, I would still need a slight delay on it, right?  I appreciate all the help, I'm an artist not an engineer, sometimes it's like reading chinese!  F.Y.I., the end goal is to build a box with a lid that looks like a Nintendo controller, and the box can only be opened by entering the Konami code, should be pretty awesome.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Yes.
Quote
Maybe. Maybe not. It depends on what you do after you detect a switch press.
Quote
You probably want a small delay, then. About 10 milliseconds.
Logged
Offline Offline
Full Member
View Profile
Edge detection is close to what it sounds like - it's looking for the "edge" of a change. The change may be high to low, or low to high.
Basically, if the current state is Low, we are looking for a High, and vis versa.
In your case, for a single button, assuming a button press will drive the port High, and you do not want a repeat key function
Wait for a change to High, you can then pause for a few mS, to allow your button to settle (all electrical contacts tend to bounce. For high speed electronics, this bounce appears very slow and can look like several open/close events, so we wait for a small amount of time for the bounce to stop)
You then look at the port for a change to zero to occur (finger off), no need to denounce if you are off to do something else.
We now have a full button press.
Logged
For whom does the clock pulse? It pulses for you!
Offline Offline
Newbie
View Profile
Awesome, thanks a ton
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
