Topic: Problem between SoftwareSerial.h and serLCD.h (Read 939 times) previous topic - next topic
hkwmon
Code: [Select]
#include <serLCD.h>
#include <SoftwareSerial.h>
#include <Arduino.h>
#define COMMA 0x2C  // zum GPS-Daten in String trennen
SoftwareSerial GPS (2,0); // Pin 2  Eingang vom GPS TX-1
serLCD lcd(3);                // Pin 3  Ausgang zu Serlcd RX
char gps_string[55]; //  Zeichen vom GPS-Empfänger
char d_string[40];    //   Data String 33 Zeichen
char p_string[55];    //   Position String 49 Zeichen
char z =0;              // Zähler für die Anzahl empfangenen Zeichen
char c=0;               // Speicher für NewSoftSerial Zeichen hinterlegt
char _state = 0;      // Zähler für erhaltene GPS-String
char *s;                 // Adresse vom Lat/Lon_String zum Umwandeln in float
char *pChar;          // Adresse für die Bildung vom Lat/Lon_String
unsigned char j, k;  // Zähler für die Bildung vom Lat/Lon_String
float _decimal(char* s);// convert degree-decimal value of latitude terms
char lat_string[10];
char lon_string[10];
float _lat,_lat1;
float _lon, _lon1;
float _degs;
boolean feedgps();
  Serial.begin(57600);
  GPS.begin(4800);  //Set data rate from GPS Receiver
  delay(100);
  //This initialize the display to blank with the backlight on
  lcd.clear();
  delay(100);
  lcd.print(" Globalposition ");
  lcd.setCursor(2, 1);
  lcd.print(" Willy Klemenz");
  delay(5000);
  lcd.clear();
void loop()   // run over and over again
   boolean newdata= false;
   if (feedgps())
     newdata = true;
   if (newdata)
          Serial.println("receive data");
          Serial.println(d_string);
          Serial.println(p_string);
          daten();
          Serial.println(lat_string);
          Serial.println(lon_string);
          lcd.clear();
          lcd.setCursor(1,1);
          lcd.print(lat_string);
If I want display also data from GPS on the LCD screen then Serial Monitor show me:
    receive data
    GPGLL,4730.3712,N,00924.9408,E,170110.00,A,A*62
    ,A,A*62
    2
If I turn off the display commands in loop
           //lcd.clear();
          //lcd.setCursor(1,1);
          //lcd.print(lat_string);
the  Serial-Monitor shows me correct data:
  receive data
  GPZDA,165245.00,21,01,2013,,*65
  GPGLL,4730.3732,N,00924.9421,E,165240.00,A,A*69
  4730.3732
  00924.9421
Maybe someone knows where can be the problem?
Willy
cmiyc
Shouldn't there be a lcd.begin() somewhere?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
PaulS
You commented out three lines. Which ONE actually causes the problem?
PaulS
Quote
Already with the first  lcd.clear();
How long does it take to clear the LCD? Perhaps you are missing serial data from the GPS while that is happening.
How are you displaying data on the Serial Monitor, when the hardware serial pins are being used to talk to the LCD?
