Pages: [1] 2   Go Down
Author Topic: digitalWrite - alarmRepeat  (Read 501 times)
I use timealarms to control led light (42w). I use 17 alarm.Repeat per day.
In test mode(1minute) everything works fine, but in 24h cycle it stops working correctly.
To avoid power failure problems is after every hour alarm.Repeat digitalWrite(HIGH) or LOW for relays.
I think this is problem.
#include <DS1307RTC.h>
#include <Time.h>
#include <TimeAlarms.h>  // accepts 23 alarmRepeat
#include <Wire.h>
const int MW = 6;        //leds power supply (relay on / off)
const int W = 9;        //white led (relay ON /off)
const int BLUE = 10;         //blue led PWM module (PWM or withoutPWM 100%)
LiquidCrystal_I2C lcd(0x27,16,2);
 //setTime(9,29,55,12,30,12);      // TEST
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
    if(timeStatus()!= timeSet)
       Serial.println("Unable to sync with the RTC");
        Serial.println("RTC has set the system time");
  lcd.init(); // initialize the lcd
  lcd.backlight();
  lcd.setCursor(0, 1);
  lcd.print("RESTART");
  pinMode (MW, OUTPUT);
  pinMode (W, OUTPUT);
  pinMode (BLUE, OUTPUT);
  digitalWrite(MW, HIGH);      //power supply OFF
  digitalWrite(W, HIGH);      //white leds OFF
  // ***** TEST ****
  Alarm.alarmRepeat(9,30,00, H06M30);
  Alarm.alarmRepeat(9,30,05, H07M30);
  Alarm.alarmRepeat(9,30,10, H08M30);
  Alarm.alarmRepeat(9,30,15, H10M30);
  Alarm.alarmRepeat(9,30,20, H10M30);
  Alarm.alarmRepeat(9,30,25, H11M30);
  Alarm.alarmRepeat(9,30,30, H12M30);
  Alarm.alarmRepeat(9,30,35, H13M30);
  Alarm.alarmRepeat(9,30,40, H14M30);
  Alarm.alarmRepeat(9,30,44, H15M30);
  Alarm.alarmRepeat(9,30,50, H16M30);
  Alarm.alarmRepeat(9,30,55, H17M30);
  Alarm.alarmRepeat(9,31,05, H18M30);
  Alarm.alarmRepeat(9,31,10, H19M30);
  Alarm.alarmRepeat(9,31,15, H20M30);
  Alarm.alarmRepeat(9,31,20, H21M30);
  Alarm.alarmRepeat(9,31,25, H22M30);
  Alarm.alarmRepeat(9,31,30, H23M30);
  ///LED control times
  Alarm.alarmRepeat(6,30,00, H06M30);
  Alarm.alarmRepeat(7,30,05, H07M30);
  Alarm.alarmRepeat(8,30,10, H08M30);
  Alarm.alarmRepeat(9,30,15, H09M30);
  Alarm.alarmRepeat(10,30,20, H10M30);
  Alarm.alarmRepeat(11,30,25, H11M30);
  Alarm.alarmRepeat(12,30,30, H12M30);
  Alarm.alarmRepeat(13,30,35, H13M30);
  Alarm.alarmRepeat(14,30,40, H14M30);
  Alarm.alarmRepeat(15,30,44, H15M30);
  Alarm.alarmRepeat(16,30,50, H16M30);
  Alarm.alarmRepeat(17,30,55, H17M30);
  Alarm.alarmRepeat(18,31,05, H18M30);
  Alarm.alarmRepeat(19,31,10, H19M30);
  Alarm.alarmRepeat(20,31,15, H20M30);
  Alarm.alarmRepeat(21,31,20, H21M30);
  Alarm.alarmRepeat(22,31,25, H22M30);
  Alarm.alarmRepeat(23,31,30, H23M30);
  digitalClockDisplay();
  Alarm.delay(1000);
void H06M30() {
  Serial.println("BLUE 33% WHITE 00% POWER ON");
  lcd.print("B33% W00% P ON ");
  analogWrite(BLUE, 84);        // blue leds 33%
  digitalWrite(MW, LOW);        // power supply ON
  digitalWrite(W, HIGH);        // white leds OFF
 void H07M30() {
  lcd.print("B33% W00% M ON ");
void H08M30() {
  Serial.println("BLUE 66% WHITE 00% POWER ON");
  lcd.print("B66% W00% M ON ");
  analogWrite(BLUE, 168);
void H09M30() {
  Serial.println("BLUE 100% WHITE OFF POWER ON");
  lcd.print("B100% W00% M ON ");
  analogWrite(BLUE, 255);
void H10M30() {
void H11M30() {
  Serial.println("BLUE 100% WHITE ON POWER ON ");
  lcd.print("B100% W100% M ON ");
  digitalWrite(W, LOW);                // white leds on
void H12M30() {
  Serial.println("BLUE 100% WHITE ON POWER ON");
void H13M30() {
void H14M30() {
void H15M30() {
void H16M30() {
void H17M30() {
void H18M30() {
void H19M30() {
void H20M30() {
  Serial.println("BLUE 66% WHITE OFF POWER ON");
void H21M30() {
  Serial.println("BLUE 33% WHITE OFF POWER ON");
void H22M30() {
  lcd.print("BS33% W00% M ON ");
void H23M30() {
  Serial.println("BLUE OFF WHITE OFF POWER OFF");
  lcd.print("....GOOD BYE....");
  digitalWrite(BLUE, LOW);       // blue OFF
  digitalWrite(MW, HIGH);        // power supply OFF
void digitalClockDisplay()
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.println();
  lcd.setCursor(0, 0);
  lcd.print(hour());
  LCDprintDigits(minute());
  LCDprintDigits(second());
void printDigits(int digits)
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void LCDprintDigits(int LCDdigits)
  lcd.print(":");
  if(LCDdigits < 10)
    Serial.print('0');
  lcd.print(LCDdigits);
« Last Edit: January 25, 2013, 03:41:31 pm by oringo » Logged
Temple, Texas
oringo,
I'm pretty sure someone here can help you, maybe even me!
But to do that we need to see your whole sketch.  Be sure and post it between code tags ( the # button above the test edit box).
The code you posted was "way" not enough to tell what your problem is.
Cheers,
John
I add whole sketch.
East Anglia (UK)
May all of your blinks be without delay
Unless you have changed this line in TimeAlarms.h the maximum number of alarms that can be active is 6
#define dtNBR_ALARMS 6   // max is 255
Have you changed it ?
I have modified it up to 40.
"Time.h"
#define dtNBR_ALARMS 40
East Anglia (UK)
Incidentally, you have an insane number of functions in that code all doing basically the same thing.  There are a number of ways to reduce the number of functions but the easiest to understand would be to have one function and to call it with parameters.
void showState(char serial.Message, char lcdMessage, int blueValue, int MWValue, int WValue)
  Serial.println(serial.Message);
  lcd.print(lcd.Message);
  analogWrite(BLUE, blueValue);
  digitalWrite(MW, MWValue);
  digitalWrite(W, WValue);
Then at 18:30 call it like this :
showState("BLUE 100% WHITE ON POWER ON","B100% W100% M ON ",255,0,0);
and at 19:30 like this :
showState("BLUE 100% WHITE OFF POWER ON","B100% W00% M ON ",255,0,255);
You could have the function construct the text shown based on the values sent to remove the need to send the text explicitly and save space
Thank you! idea is good and simple. smiley
I add your sketch and i get error
invalid conversion from "const char*" to "char"
I am beginner.
What i must add more to sketch?
Temple, Texas
Do you mean that the it works properly throughout the first day but then the next day at 6:30 am it doesn't work?
For the "const char *" error I think for now you can just change
from this:
to this:
void showState(const char* serialMessage, const char* lcdMessage, int blueValue, int MWValue, int WValue)
(there are some other issues but try this first)
John
« Last Edit: January 26, 2013, 09:18:30 am by johncc » Logged
East Anglia (UK)
Sorry, my fault for doing things in a hurry.
The function declaration should be
void showState(char* serialMessage, char* lcdMessage, int blueValue, int MWValue, int WValue)
  Serial.println(serialMessage);
  lcd.print(lcdMessage);
Milton Keynes UK
void showState(const char* serial.Message, const char* lcdMessage, int blueValue, int MWValue, int WValue)
That doesn't look right to me.
Temple, Texas
Ok, but I'm blaming UKHeliBob for that one smiley
edited/fixed, thanks
East Anglia (UK)
I will gladly take the blame as it was originally wrong in more ways than one.
Is it right now though I ask myself (and others) ?
Milton Keynes UK
The argument types don't exactly match the signatures for analogWrite() and digitalWrite(), but I don't suppose we're too concerned about type safety here.
Temple, Texas
I hear that, I still keep wanting digitalWrite to be digitalWrite(int, bool), but Mr. Nick has convinced me to "get over it" smiley
Cheers,
John
24 hours is ok, but 48 hours then it like stops and keeps old values. Short test it works correctly.
Thank you! New sketch looks nice and still is simple.
#include <Time.h>
#include <Wire.h>
  lcd.backlight();
  // ***** TEST ****
  Alarm.delay(1000);
void showState(char* serialMessage,char* lcdMessage,int blueValue,int MWValue,int WValue)
void H06M30() {
 showState("BLUE 33% WHITE OFF POWER ON","B33% WOFF M ON ", 85,0,1);
 void H07M30() {
  showState("BLUE 33% WHITE OFF POWER ON","B66% WOFF M ON ", 85,0,1);
void H08M30() {
showState("BLUE 66% WHITE OFF POWER ON","B66% WOFF M ON ", 170,0,1);
void H09M30() {
showState("BLUE 66% WHITE OFF POWER ON","B66% WOFF M ON ",170,0,1);
void H10M30() {
void H11M30() {
void H12M30() {
void H13M30() {
void H14M30() {
void H15M30() {
void H16M30() {
void H17M30() {
void H18M30() {
void H19M30() {
showState("BLUE 100% WHITE OFF POWER ON","B100% W OFF M ON ",255,0,1);
void H20M30() {
showState("BLUE 66% WHITE OFF POWER ON","B100% W OFF M ON ",170,0,1);
void H21M30() {
showState("BLUE 66% WHITE OFF POWER ON","B66% W OFF M ON ",170,0,1);
void H22M30() {
showState("BLUE 33% WHITE OFF POWER ON","B66% W OFF M ON ",85,0,1);
void H23M30() {
showState("BLUE OFF WHITE OFF POWER OFF","....GOOD BYE....",0,1,1);
  Serial.println();
  lcd.print(hour());
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  lcd.print(":");
  if(LCDdigits < 10)
    Serial.print('0');
[/quote]
Pages: [1] 2   Go Up
