Topic: Serial Monitor interupt (Read 1 time) previous topic - next topic
badben
I am currently playing with an i2c accelerometer/gyro (MPU6050) to build a balancing robot.
Rather than keep changing variables in the code and then recompiling and uploading I would like some form of interrupt so that when a command is sent via the serial monitor it changes a variable.
I'm not even sure that an interrupt is what I need to be honest.
So for example, the basic program structure is something like this
Code: [Select]
//update sensors
//calculate motor speed
//run motors
There are different sensitivity settings for the MPU6050.  I want to be change the sensitivity of the accelerometer or gyro using the serial monitor.
Can anybody help or suggest a better way.
Thanks?
