Topic: Getting URL string values? (Read 978 times) previous topic - next topic
cazwecan
I'm using the Ethernet shield + Arduino UNO and working with the example from: "Pin Control Over the Internet - Arduino + Ethernet" http://bildr.org/2011/06/arduino-ethernet-pin-control/#
In this example I'm simply passing a URL to the Aruino
My question/issue is when i change the URL from "http://myip/?234" to "http://myip/?Hello"
The numbers in the URL work for me. But when I change them to text. All I get with my Serial.print of the URL is 'G' no matter what I pass in the URL. I'm missing something - most likely something dumb on my part.
Here's the code that I'm working with - I've thinned it down but any other code needed please let me know.
Also if someone knows of another HTML - Arduino sample please let me know. I want to use a HTML Form Post when I've gotten over this hump.
Code: [Select]
void checkForClient(){
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    boolean sentHeader = false;
    while (client.connected()) {
      if (client.available()) {
        if(!sentHeader){
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println();
          sentHeader = true;
        char c = client.read();
        if(reading && c == ' ') reading = false;
        if(c == '?') reading = true; //found the ?, begin reading the info
        if(reading){
          Serial.print(c); //print out values after ? in URL
        if (c == '\n' && currentLineIsBlank)  break;
        if (c == '\n') {
        }else if (c != '\r') {
          currentLineIsBlank = false;
    delay(1); // give the web browser time to receive the data
    client.stop(); // close the connection:
Thank you in advance
nickgammon
I think your problem is the URL format. It is generally in the format: ?name=value
You just have ?name
Code: [Select]
Try:
Code: [Select]
"http://myip/?var=Hello"
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
PaulS
Code: [Select]
The reading flag controls writing. That makes no sense.
zoomkat
Simple server code that will send what is sent to the server to the serial monitor for viewing.
Code: [Select]
//zoomkat 4-1-12
//simple button GET for servo and pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html, or use ' instead of "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  myservo.write(90); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  //enable serial data print
  Serial.println("server servo/pin 5 test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          client.println("<a href=\"/?on\">ON</a>");
          client.println("<a href=\"/?off\">OFF</a>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            myservo.write(40);
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            myservo.write(140);
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
cazwecan
Zoomkat - that did the ticket for me! Thank you.
