Heres the code..
please can you put in your change..
I see that "BYTE refreshrate =1 is used as a reference throughout.. would be good if I could make it 0.5 i.e 500 microseconds
many thanks for any help.
//POV Wand Arduino code
//by Amanda Ghassaei
//instructables.com/amandaghassaei
//April 2012
//for use with arduino uno or duemilanove with atmel328
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
//in most of this code I have used the arduino portpin assignments to send data to pins, you can read more about how that works here: http://www.arduino.cc/en/Reference/PortManipulation
//I've also included (and commented) the standard arduino library commands that perform the same functions and the port commands in case you are interested
#include <avr/pgmspace.h>//need to store letter arrays in flash memory- or else we run out of space, more info here: http://arduino.cc/en/Reference/PROGMEM
THIS NEXT SECTION IS WHAT YOU'LL WANT TO EDIT TO CREATE YOUR OWN MESSAGES
// setup
String povtext = " HELLO ";//PUT YOUR MESSAGE HERE!!- must be in all caps, spaces are fine, no punctuation
[b]byte refreshrate = 1;[/b]//delay time for pixels to refresh in milliseconds- experiment with different values
//LOTS OF BOOLEAN HERE..
//// if (letterArray[15*12+t]) {
//// digitalWrite(A4, HIGH);
//// else {
//// digitalWrite(A4, LOW);
//// if (letterArray[16*12+t]) {
//// digitalWrite(A3, HIGH);
//// else {
//// digitalWrite(A3, LOW);
//// if (letterArray[17*12+t]) {
//// digitalWrite(A2, HIGH);
//// else {
//// digitalWrite(A2, LOW);
//// if (letterArray[18*12+t]) {
//// digitalWrite(A1, HIGH);
//// else {
//// digitalWrite(A1, LOW);
//// if (letterArray[19*12+t]) {
//// digitalWrite(A0, HIGH);
//// else {
//// digitalWrite(A0, LOW);
//// delay(refreshrate);//delay after each column of data is displayed
//// }//go to next time step
//port/pin assignments- set all pins to output- more info here: http://www.arduino.cc/en/Reference/PortManipulation
DDRB = 0xFF;//port b- digital pins 8-13
DDRC = 0xFF;//port c- anlog pins 0-5
DDRD = 0xFF;//port d- digital pins 0-7
//the three lines above are the same as setting all pins as outputs using arduino library:
// pinMode(A0, OUTPUT);
// pinMode(A1, OUTPUT);
// pinMode(A2, OUTPUT);
// pinMode(A3, OUTPUT);
// pinMode(A4, OUTPUT);
// pinMode(A5, OUTPUT);
// for (int pin=0; pin<14; pin++){
// pinMode(pin, OUTPUT);
//run intialization so we know device is working- leds should light up in order from top of wand to bottom
for (byte j=0; j<20; j++){ //for each time step
for (byte i=0; i<6; i++){ //for first six rows of data
data1 = data1 << 1;//bitwise shift left
data1 |= load[(i*20+j)];//add next value from dataset
for (byte i=6; i<14; i++){ //for next eight rows of data
data2 = data2 << 1;//bitwise shift left
data2 |= load[(i*20+j)];//add next value from dataset
for (byte i=14; i<20; i++){ //for next six rows of data
data3 = data3 << 1;//bitwise shift left
data3 |= load[(i*20+j)];//add next value from dataset
PORTB = data1;
PORTD = data2;
PORTC = data3;
delay(100);
////SAME AS ABOVE LOOP, BUT USING ARDUINO LIBRARY:
// //turn on each LED one by one using arduino library commands
// for (int pin= 13; pin>=0; pin--){//turn on each digital pin sequentially for 100ms
// digitalWrite(pin, HIGH);
// delay(100);
// digitalWrite(pin,LOW);
// //the following lines turn on each analog pin individually
// digitalWrite(A5, HIGH);
// delay(100);
// digitalWrite(A5,LOW);
// delay(100);
// digitalWrite(A4,LOW);
// delay(100);
// digitalWrite(A3,LOW);
// delay(100);
// digitalWrite(A2,LOW);
// delay(100);
// digitalWrite(A1,LOW);
// delay(100);
// digitalWrite(A0,LOW);
//clear data storage
data1 = 0;
data2 = 0;
data3 = 0;
//clear ports- set all arduino pins to 0Volts
PORTB = data1;
PORTD = data2;
PORTC = data3;
//space at beginning of text
PORTB = 0;
PORTD = 0;
PORTC = 0;
[b] delay(refreshrate*3);[/b]
for (n=0; n<dimtext; n++) {//go through each character of povtext and call function sendToWand to display letter
if (povtext.charAt(n)=='A') {
sendToWand(letterA);
else if (povtext.charAt(n)=='B') {
sendToWand(letterB);
else if (povtext.charAt(n)=='C') {
sendToWand(letterC);
else if (povtext.charAt(n)=='D') {
sendToWand(letterD);
else if (povtext.charAt(n)=='E') {
sendToWand(letterE);
else if (povtext.charAt(n)=='F') {
sendToWand(letterF);
else if (povtext.charAt(n)=='G') {
sendToWand(letterG);
else if (povtext.charAt(n)=='H') {
sendToWand(letterH);
else if (povtext.charAt(n)=='I') {
sendToWand(letterI);
else if (povtext.charAt(n)=='J') {
sendToWand(letterJ);
else if (povtext.charAt(n)=='K') {
sendToWand(letterK);
else if (povtext.charAt(n)=='L') {
sendToWand(letterL);
else if (povtext.charAt(n)=='M') {
sendToWandMW(letterM);
else if (povtext.charAt(n)=='N') {
sendToWand(letterN);
else if (povtext.charAt(n)=='O') {
sendToWand(letterO);
else if (povtext.charAt(n)=='P') {
sendToWand(letterP);
else if (povtext.charAt(n)=='Q') {
sendToWand(letterQ);
else if (povtext.charAt(n)=='R') {
sendToWand(letterR);
else if (povtext.charAt(n)=='S') {
sendToWand(letterS);
else if (povtext.charAt(n)=='T') {
sendToWand(letterT);
else if (povtext.charAt(n)=='U') {
sendToWand(letterU);
else if (povtext.charAt(n)=='V') {
sendToWand(letterV);
else if (povtext.charAt(n)=='W') {
sendToWandMW(letterW);
else if (povtext.charAt(n)=='X') {
sendToWand(letterX);
else if (povtext.charAt(n)=='Y') {
sendToWand(letterY);
else if (povtext.charAt(n)=='Z') {
sendToWand(letterZ);
else if (povtext.charAt(n)==' ') {
PORTB = 0;
PORTD = 0;
PORTC = 0;
delay(refreshrate*3);//off for 3 pixels
//space between each character
PORTB = 0;
PORTD = 0;
PORTC = 0;
[b] delay(refreshrate);[/b]
//space at end of text
PORTB = 0;
PORTD = 0;
PORTC = 0;
[b]delay(refreshrate*3);[/b]
