Topic: any tutorials on this? (Read 10931 times) previous topic - next topic
Ruffsta
Jan 24, 2013, 11:53 pm Last Edit: Jan 24, 2013, 11:56 pm by Ruffsta Reason: 1
been looking for tutorials on this - (i just finished soldering it altogether and i want to use it),but none really to be found..
thanks in advance
Formerly known as "INSIGNIA", you showed me respect and gave me karma points.. but you won't do the same for me now under a different name?
Ruffsta
k,, ty.. but also looking how to hook up the outer pins to the arduino..
pYro_65
Never used one but from the code, I saw this:
Code: [Select]
int dataIn = 2;
int load = 3;
int clock = 4;
and on the left of your picture are the connections:
DIN
CS
CLK
so I think they match up like this:
Code: [Select]
int dataIn = 2; //DIN
int load = 3; //CS
int clock = 4; //CLK
Forum Mod anyone?
https://arduino.land/Moduino/
Ruffsta
but there are 10 pins.. only 3 to make this work?
wildbill
Looks that way. Check out the link to the tutorial in the code that pyro_65 linked to. It'll be 5 of course though since you'll need vcc and ground.
marco_c
#6
Jan 25, 2013, 01:28 am Last Edit: Jan 25, 2013, 01:31 am by marco_c Reason: 1
3 are already mentioned. The other 2 are Gnd and Vcc, not much imagination required here.
The other 5 pins are the same and they are the output side (DOUT is the opposite of DIN). These modules can be daisy chained. If you wanted to add the second or more modules you connect the 'output' of one board to the 'input' of another.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
Ruffsta
#7
Jan 25, 2013, 01:12 pm Last Edit: Jan 25, 2013, 02:07 pm by Ruffsta Reason: 1
k, ty
code doesn't work..
Code: [Select]
int dataIn = 2;
int load = 3;
int clock = 4;
int maxInUse = 1;    //change this variable to set how many MAX7219's you'll use
int e = 0;           // just a varialble
                    // define max7219 registers
byte max7219_reg_noop        = 0x00;
byte max7219_reg_digit0      = 0x01;
byte max7219_reg_digit1      = 0x02;
byte max7219_reg_digit2      = 0x03;
byte max7219_reg_digit3      = 0x04;
byte max7219_reg_digit4      = 0x05;
byte max7219_reg_digit5      = 0x06;
byte max7219_reg_digit6      = 0x07;
byte max7219_reg_digit7      = 0x08;
byte max7219_reg_decodeMode  = 0x09;
byte max7219_reg_intensity   = 0x0a;
byte max7219_reg_scanLimit   = 0x0b;
byte max7219_reg_shutdown    = 0x0c;
byte max7219_reg_displayTest = 0x0f;
void putByte(byte data) {
 byte i = 8;
 byte mask;
 while(i > 0) {
   mask = 0x01 << (i - 1);      // get bitmask
   digitalWrite( clock, LOW);   // tick
   if (data & mask){            // choose bit
     digitalWrite(dataIn, HIGH);// send 1
   }else{
     digitalWrite(dataIn, LOW); // send 0
   digitalWrite(clock, HIGH);   // tock
   --i;                         // move to lesser bit
void maxSingle( byte reg, byte col) {
//maxSingle is the "easy"  function to use for a     //single max7219
 digitalWrite(load, LOW);       // begin
 putByte(reg);                  // specify register
 putByte(col);//((data & 0x01) * 256) + data >> 1); // put data
 digitalWrite(load, LOW);       // and load da shit
 digitalWrite(load,HIGH);
void maxAll (byte reg, byte col) {    // initialize  all  MAX7219's in the system
 int c = 0;
 for ( c =1; c<= maxInUse; c++) {
void maxOne(byte maxNr, byte reg, byte col) {
//maxOne is for adressing different MAX7219's,
//whilele having a couple of them cascaded
 int c = 0;
 for ( c = maxInUse; c > maxNr; c--) {
   putByte(0);    // means no operation
 for ( c =maxNr-1; c >= 1; c--) {
void setup () {
 pinMode(dataIn, OUTPUT);
 pinMode(clock,  OUTPUT);
 pinMode(load,   OUTPUT);
 beginSerial(9600); //------------------------------------first error, this is not defined
 digitalWrite(13, HIGH);
//initiation of the max 7219
 maxAll(max7219_reg_scanLimit, 0x07);
 maxAll(max7219_reg_decodeMode, 0x00);  // using an led matrix (not digits)
 maxAll(max7219_reg_shutdown, 0x01);    // not in shutdown mode
 maxAll(max7219_reg_displayTest, 0x00); // no display test
  for (e=1; e<=8; e++) {    // empty registers, turn all LEDs off
   maxAll(e,0);
 maxAll(max7219_reg_intensity, 0x0f & 0x0f);    // the first 0x0f is the value you can set
                                                 // range: 0x00 to 0x0f
void loop () {
 //if you use just one MAX7219 it should look like this
  maxSingle(1,1);                       //  + - - - - - - -
  maxSingle(2,2);                       //  - + - - - - - -
  maxSingle(3,4);                       //  - - + - - - - -
  maxSingle(4,8);                       //  - - - + - - - -
  maxSingle(5,16);                      //  - - - - + - - -
  maxSingle(6,32);                      //  - - - - - + - -
  maxSingle(7,64);                      //  - - - - - - + -
  maxSingle(8,128);                     //  - - - - - - - +
 delay(2000);
AWOL
Time to get your scope out.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Ruffsta
let me use yours so i can see what you see..
Ruffsta
this code works.. just need to switch pins on the arduino to 8,9 and 10
Code: [Select]
unsigned char i;
unsigned char j;
/*port definition*/
int Max7219_pinCLK = 10;
int Max7219_pinCS = 9;
int Max7219_pinDIN = 8;
unsigned char disp1[38][8]={
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
{0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
{0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
{0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
{0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
{0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
{0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
{0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A
{0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B
{0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C
{0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C},//E
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40},//F
{0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C},//G
{0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44},//H
{0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C},//I
{0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30},//J
{0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24},//K
{0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C},//L
{0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81},//M
{0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//O
{0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20},//P
{0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D},//Q
{0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21},//R
{0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C},//S
{0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8},//T
{0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U
{0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18},//V
{0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0},//W
{0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X
{0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},//Y
{0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},//Z
{0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//Chinese character
{0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//Chinese character
void Write_Max7219_byte(unsigned char DATA)
            unsigned char i;
    digitalWrite(Max7219_pinCS,LOW);
    for(i=8;i>=1;i--)
             digitalWrite(Max7219_pinCLK,LOW);
             digitalWrite(Max7219_pinDIN,DATA&0x80);//Obtain the MSB of the data
             DATA = DATA<<1;
             digitalWrite(Max7219_pinCLK,HIGH);
void Write_Max7219(unsigned char address,unsigned char dat)
        Write_Max7219_byte(address);           //
        Write_Max7219_byte(dat);               //
        digitalWrite(Max7219_pinCS,HIGH);
void Init_MAX7219(void)
Write_Max7219(0x09, 0x00);       //decode: BCD
Write_Max7219(0x0a, 0x03);       //Brightness
Write_Max7219(0x0b, 0x07);       //
Write_Max7219(0x0c, 0x01);       //
Write_Max7219(0x0f, 0x00);       //
  pinMode(Max7219_pinCLK,OUTPUT);
  pinMode(Max7219_pinCS,OUTPUT);
  pinMode(Max7219_pinDIN,OUTPUT);
  delay(50);
  Init_MAX7219();
   for(j=0;j<38;j++)
   for(i=1;i<9;i++)
    Write_Max7219(i,disp1[j][i-1]);
Ruffsta
#11
Jan 25, 2013, 02:46 pm Last Edit: Jan 25, 2013, 02:47 pm by AWOL Reason: 1
k, what i don't get in this code.. is:
Code: [Select]
trying to make sense of it..
you can the code here: http://www.linksprite.com/download/showdownload.php?lang=en&id=223
or
here (takes you to the same exact same place): http://www.linksprite.com/upload/file/1347631413.txt
Moderator edit: Tags corrected
AWOL
#12
Jan 25, 2013, 02:49 pm Last Edit: Jan 25, 2013, 02:52 pm by AWOL Reason: 1
Quote
They're bit patterns, for your dot-matrix display.
Eight bytes per character, each byte with eight bits.
At the moment, they're consuming precious RAM - they might be better placed in PROGMEM.
Ruffsta
#13
Jan 25, 2013, 03:01 pm Last Edit: Jan 25, 2013, 03:03 pm by Ruffsta Reason: 1
again, i'm new.. so.. i'm at a loss here..
Quote
sorry, but i don't know how to do that yet or how to modify the code to do such..
i just got this for him and he soldered it all up - (since i have soldered for years, i taught him how to and he does exceptionally well).. so the coding is not what we are used to.
i thought getting this thing - (the arduino and such), for my son was going to be fun.. something we could do together as a father/son time thing, but in the end - it's more confusing than anything. starting to wonder why i even bothered getting him this even tho he's into building and coding stuff, but i think this may be just too much for him at 13 - i know it is for me at 39...
marco_c
Never underestimate a 13 year old when it comes to computer technology ...
Did you start wih easier stuff like the LED blinker and reading an analog input? I find it is good to get the basics right and build on that.
