Rhode Island - USA
Offline
Full Member
« Reply #15 on: January 25, 2013, 09:11:51 am » |
is there a way to control each led in the matrix individually or a better way to display what we want it to display vs bit patterns?
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #16 on: January 25, 2013, 09:15:33 am » |
I only said they "might" be better in PROGMEM - I don't know what else you have in mind to do with this device. If you were going to build some kind of message matrix with multiple devices, it might be better to save RAM for user-specified messages.
However, there is nothing magical about PROGMEM, it is just another memory space on the processor, and there are lots of tutorials and threads on the topic.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Rhode Island - USA
Offline
Full Member
« Reply #17 on: January 25, 2013, 09:15:56 am » |
Never underestimate a 13 year old when it comes to computer technology ...
Did you start wih easier stuff like the LED blinker and reading an analog input? I find it is good to get the basics right and build on that.
yeah, we got tired of making leds blink, so i go on ebay and get random stuff (such as this) and then go from there.. we did a few digit leds, still trying to get the 3 digit and 2 digits to work.. but in time i guess. we played around with a sensor (4 pin).. we want to get into multiplexing - building cubes and dancing images.. he wants to build a torrent (or whatever he calls it).. i have a project i am working on with crossroads. we have a couple of lcd's yet to play with.. but yeah, multiplexing and the such is what we want to accomplish the most,
« Last Edit: January 25, 2013, 09:58:58 am by Ruffsta »
Logged
Rhode Island - USA
Offline
Full Member
« Reply #18 on: January 25, 2013, 09:18:24 am » |
we just want it to display different things.. .nothing special at this time.. i have more max7219's if ever needed.. i stocked up on those  i mean, it's a red dot 8x8 matrix.. nothing we really can use it for or need it for.. was just something to mess and learn with..
« Last Edit: January 25, 2013, 09:23:47 am by Ruffsta »
Logged
Rhode Island - USA
Offline
Full Member
« Reply #19 on: January 25, 2013, 09:59:13 am » |
« Last Edit: January 25, 2013, 04:10:00 pm by Ruffsta »
Logged
Rhode Island - USA
Offline
Full Member
« Reply #20 on: January 25, 2013, 04:17:59 pm » |
k, getting back on subject here... is there another way to control each dot individually other than bit patterns?
thanks
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #21 on: January 25, 2013, 04:46:14 pm » |
is there another way to control each dot individually other than bit patterns? No you have to do it through bit patterns. Why is that a problem?
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #22 on: January 25, 2013, 04:53:55 pm » |
There's a MAX7219 on the board, yes? It has 8 registers you write to, 1 for each column of data, at addresses 0x01 thru 0x08. You want a single LED on, you write to the register for that column with the data you want. I use SPI to control MAX7219s vs the shiftout/bit bang discussed so far, hardware transfer vs a software transfer. an example would be: digitalWrite(SSpin, LOW); // SSpin is generally D10 SPI.transfer(register0); // declared earlier in code as 'byte register0 = 0x01; SPI.transfer(data_to_write); // control in your code = 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 for the 8 LEDs one at a time digitalWrite(SSpin, HIGH);
if you made an array of the register numbers and the data: byte registerAddress[] = {1,2,3,4,5,6,7,8;}; // registerAddress[0] = 1, [1] = 2, etc. up to [7] = 8 byte data_to_write [8]; // data_to_write [0] = data for registerAddress[0], ... data_to_write [7] = data for registerAddress[7]
then you put the above in a loop and just call it when your code changed something: if (dataChanged_flag ==1){ // flag is set when the code makes a change to data_to_write[0] thru data_to_write[7] dataChanged_flag = 0; // clear the flag for (x =0; x<8; x=x+1){ digitalWrite(SSpin, LOW); // SSpin is generally D10 SPI.transfer(registerAddress[x]); // send Register address 1 to 8 SPI.transfer(data_to_write[x]); // send data for associated register digitalWrite(SSpin, HIGH); }
Logged
Offline
Brattain Member
« Reply #23 on: January 25, 2013, 05:51:43 pm » |
If you have a problem seeing how numbers, bit patterns and the display all tie up together, read this:- http://www.thebox.myzen.co.uk/Workshop/LED_Matrix.html
Logged
Sydney
Offline
God Member
Big things come in large packages
« Reply #24 on: January 25, 2013, 06:41:55 pm » |
I have the same unit you got and also wired up a marix from individual LEDs (which made me appreciate the made up matrix even more!). Not sure if it will help you or not, but ...
When I was trying to understand what/how the MAX72XX chips do their stuff I wrote a library and a bunch of test code that did 'funky' (ie, useless but interesting at the time) things on the matrix, including addressing individual points on it..
If you are interested in the code for my library and the test/example can be found at the location in my signature block.
Logged
Rhode Island - USA
Offline
Full Member
« Reply #25 on: January 25, 2013, 06:54:02 pm » |
is there another way to control each dot individually other than bit patterns? No you have to do it through bit patterns. Why is that a problem? yes, i don't get it.. like: unsigned char disp1[38][8]={ {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0 0x3C what does the "C" stand for? why are there multiples of 0x42? 64 dots.. only putting in 8 bits of info? i'll look at the link you provided shortly.. and ty crossroads - i'll get to that shortly too..
Logged
New Jersey
Offline
Edison Member
« Reply #26 on: January 25, 2013, 07:03:40 pm » |
0x3C what does the "C" stand for? That's hexadecimal notation (q.v.) Each one of those is eight bits and there are eight of them in your array. That gives you individual control of sixty four bits. There are multiple 0x42s because the pattern being drawn has rows that are the same. Try making the first byte 0x01 (or indeed 1) and all the others 0. Hopefully a single LED will be lit. replace the 1 with 2, then 4 then 8, then 7. See what is happening?
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #27 on: January 25, 2013, 07:06:36 pm » |
0x3C what does the "C" stand for? C is the hexadecimal value of the decimal value 12. In hex (base 16), digits go 0123456789ABCDEF (16 of them) why are there multiples of 0x42? Because the bit pattern 01000010 repeats vertically. 64 dots.. only putting in 8 bits of info? Don't understand the question. 64 bits is eight bytes
Logged
Global Moderator
Offline
Brattain Member
« Reply #28 on: January 25, 2013, 07:07:44 pm » |
Think of your matrix like this: 10101010 10101010 10101010 10101010 10101010 10101010 10101010 10101010
So you have 8 columns, and 8 rows. In this example, Columns 0,2,4,6 are all 1's. Those represent "on" LEDs. The columns with 0's are 'off' LEDs. Each column is controlled by 1 register, 1-2-3-4-5-6-7-8. The top LED in each column is bit 7 of a register, the bottom LED is bit 0.
If you wanted the lower left LED to be on, you would send B00000001 to register 1. In HEX, that would be 0x01. If you wanted every other LED on starting from the bottom, you would send B01010101, or HEX 0x55. If you wanted 2 of the LEDs on, say at B01000010, you could send 0x42.
So for your example: 0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C, with each byte arranged vertically: 0x3C = 0011 1100 0x42 = 0100 0010
00000000 01111110 10000001 10000001 10000001 10000001 01111110 00000000
So that would make a 0, or a square, however you want to reference it.
Logged
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #29 on: January 25, 2013, 07:08:01 pm » |
been looking for tutorials on this - (i just finished soldering it altogether and i want to use it),but none really to be found..
http://gammon.com.au/forum/?id=11516
Logged
