Loading...
Pages: [1]   Go Down
Author Topic: Can I set digitalWrite other than analog and digital pins?  (Read 179 times)
Offline Offline
Newbie
View Profile
I want to set the pinMode to a specific pin like in the pin 29 of atmega32. Can I do that?
« Last Edit: March 04, 2013, 06:49:33 pm by jepoy12 » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
ATmega32 ??   Do you mean ATmega328 or ATmega32U4 ?
Basically pinMode works with pins that are defined via the pins_arduino.h file for the relevant variant.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Don't understand what you are asking.
But the pin mode can be set as an input r output for any pin on the arduino
Logged
Offline Offline
Newbie
View Profile
Sorry Im not good at explaining. its Atmega328
heres what Im planing.
Code:
int reset= 29;                 // pin no. of atmega328 which is the reset
  pinMode(reset, OUTPUT);      // set reset as output
  digitalWrite(reset, low);   // use it when I want to reset the atmega328
I think digitalWrite is for analog and digital only.
« Last Edit: March 04, 2013, 06:48:46 pm by jepoy12 » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Code:
You can't do what you are trying to do. The reset pin on a 328P can be set with fuse settings to be either the hardware reset signal for the chip or a general purpose I/O pin, it can't be used for both purposes. If fuses are set to use the reset pin as an I/O you lose the ability to program the chip via bootloader or ISP method so that pin is always used as a hardware reset pin only for any arduino IDE compatible board, and you have no program control over it.
If you want to be able to reset the chip while it's running your sketch, read up on using the watch dog time (WDT), it's easy to do and is the only correct method to perform a chip reset without using external components.
Lefty
Logged
Offline Offline
Newbie
View Profile
Thank you sir.
Logged
Pages: [1]   Go Up
Print
Jump to:
