Topic: analogWrite low for ground (Read 1 time) previous topic - next topic
suicidalacorn
sorry if this is in the wrong place, this seemed to fit it best.
if i use analogWrite function to write a pin (non pwm) to low, that makes it a ground. i know it works because i have tried it. but...will this do any type of damage to the arduino?
PeterH
It'll be fine, as long as you don't ask it to sink more than about 20mA.
suicidalacorn
ok. thank you!
GoForSmoke
Why use analogWrite to a non-pwm pin at all?
Write the pin LOW and set it to OUTPUT.
And here's the fun part. You can switch modes and states in no time flat on the same pin. It's not set in stone, it's made to be versatile and fast.
Some of the neatest code does that. There's a sketch that uses 2 pins, 1 led and 1 resistor to read the ambient light level with the led then change to pulse the led to make light at controlled brightness so it's not too bright or too dim.. many times a second. Just to read light with a led uses mode and state switching.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
