Loading...
Pages: 1 2 [3] 4   Go Down
Author Topic: Standalone Mega2560 boot time  (Read 1753 times)
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Did you put the pull-up resistors on them?
Logged
Offline Offline
Newbie
View Profile
Is this really necessary ? See the pictures, SNR > 200.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
We are running out of other options, that's why I suggest it.
Logged
Offline Offline
Newbie
View Profile
Hey I have the same exact issue with my mega2560. But mine is a genuine arduino I bought. It works perfectly but if I open serial monitor it take about 10 secs to start running again. BUT if I open the serial monitor I can press the reset on the mega and it will start right away?
« Last Edit: February 02, 2013, 10:49:12 am by PavelK » Logged
Offline Offline
Newbie
View Profile
PavelK, this exactly the same problem for me. I'm glad to know it's not a problem with my board  smiley !
On my board, if I reset the board while serial monitor is open, it starts immediately. You can try.
« Last Edit: February 03, 2013, 11:09:48 am by gabidanpremier » Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
See reply #30.
Logged
Offline Offline
Newbie
View Profile
See reply #30.
I don't understand why I need the phillip resistors one either Tx or Rx pins. I will try that. Also I'm kinda new to arduinos. How do I edit the fuses?
Btw my brother had a mega2560 and has same problem. It's not really a big problem just wondering why it does that.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
Cautiously. If you change the wrong things you may brick the processor. Make sure you understand what you are doing. Preferably key in your existing fuse values into a calculator, and then just change one bit.
http://www.engbedded.com/fusecalc
If you have an external programmer you can change them with avrdude (like an USBtinyISP programmer for example).
Logged
Offline Offline
Newbie
View Profile
PavelK, if you've never changed the fuses settings on your Mega2560, I don't think there is a reason why you would do it now.
If you just want to solve the 10 sec issue, you wont solve anything by playing with the fuses settings.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I agree. I don't know of any "wait 10 seconds before doing anything" fuse.
Logged
Offline Offline
Newbie
View Profile
So what will solve the problem?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I got an idea from another thread, where the serial port was interfering with the clock.
Try changing the low fuse to indicate a "full swing oscillator with fast rising power" (low fuse: 0xC6).
Logged
Offline Offline
Newbie
View Profile
I tried your suggestion, but the 9.5 seconds delay is still there.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
I would put a digital volt meter on the reset pin (and ground) and see what voltage you read there during this 9.5 second nothing happening time.
Lefty
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Reply #21 appears to indicate that reset goes low only briefly.
However apart from the presence of the capacitor which is charged when RTS goes low, I can't see any reason why the two different reset methods should behave differently.
Logged
Pages: 1 2 [3] 4   Go Up
Print
Jump to:
