Topic: Standalone Mega2560 boot time (Read 9913 times) previous topic - next topic
nickgammon
Did you put the pull-up resistors on them?
More info:
gabidanpremier
Is this really necessary ? See the pictures, SNR > 200.
nickgammon
We are running out of other options, that's why I suggest it.
More info:
PavelK
#33
Feb 02, 2013, 03:38 pm Last Edit: Feb 02, 2013, 04:49 pm by PavelK Reason: 1
Hey I have the same exact issue with my mega2560. But mine is a genuine arduino I bought. It works perfectly but if I open serial monitor it take about 10 secs to start running again. BUT if I open the serial monitor I can press the reset on the mega and it will start right away?
gabidanpremier
#34
Feb 03, 2013, 04:40 pm Last Edit: Feb 03, 2013, 05:09 pm by gabidanpremier Reason: 1
PavelK, this exactly the same problem for me. I'm glad to know it's not a problem with my board  :) !
On my board, if I reset the board while serial monitor is open, it starts immediately. You can try.
nickgammon
More info:
PavelK
See reply #30.
I don't understand why I need the phillip resistors one either Tx or Rx pins. I will try that. Also I'm kinda new to arduinos. How do I edit the fuses?
Btw my brother had a mega2560 and has same problem. It's not really a big problem just wondering why it does that.
nickgammon
Cautiously. If you change the wrong things you may brick the processor. Make sure you understand what you are doing. Preferably key in your existing fuse values into a calculator, and then just change one bit.
http://www.engbedded.com/fusecalc
If you have an external programmer you can change them with avrdude (like an USBtinyISP programmer for example).
More info:
gabidanpremier
PavelK, if you've never changed the fuses settings on your Mega2560, I don't think there is a reason why you would do it now.
If you just want to solve the 10 sec issue, you wont solve anything by playing with the fuses settings.
nickgammon
I agree. I don't know of any "wait 10 seconds before doing anything" fuse.
More info:
PavelK
So what will solve the problem?
nickgammon
I got an idea from another thread, where the serial port was interfering with the clock.
Try changing the low fuse to indicate a "full swing oscillator with fast rising power" (low fuse: 0xC6).
More info:
gabidanpremier
I tried your suggestion, but the 9.5 seconds delay is still there.
retrolefty
I would put a digital volt meter on the reset pin (and ground) and see what voltage you read there during this 9.5 second nothing happening time.
Lefty
nickgammon
Reply #21 appears to indicate that reset goes low only briefly.
However apart from the presence of the capacitor which is charged when RTS goes low, I can't see any reason why the two different reset methods should behave differently.
More info:
