Topic: High Speed Input Accuracy (Read 824 times) previous topic - next topic
shardbearer
Jan 26, 2013, 02:50 am Last Edit: Jan 26, 2013, 02:53 am by shardbearer Reason: 1
I have a project that I'm working on where I need to measure the amount of time between two inputs. Normal times would be around 4000 microseconds, going as low as 200 microseconds. I wrote two versions of the code, both of which work fine, but the question is, which one is more accurate? One uses loops that repeat if statements so I get the maximum polling frequency, the other uses interrupts.
BTW, both use the internal pull up resistors, so the logic is reversed.
Code: [Select]
const byte sensor1Pin = 2; // PIND, 2
const byte sensor2Pin = 3; // PIND, 3
unsigned long time1 = 0;
unsigned long time2 = 0;
 pinMode(sensor1Pin, INPUT);
 pinMode(sensor2Pin, INPUT);
 digitalWrite(sensor1Pin, HIGH);
 digitalWrite(sensor2Pin, HIGH);
 if (!bitRead(PIND, 2)) {
   time1 = micros();
   while (1) {
     if (!bitRead(PIND, 3)) {
       time2 = micros();
       Serial.println(time2-time1);
Code: [Select]
volatile unsigned long time1 = 0;
volatile unsigned long time2 = 0;
 attachInterrupt(0, sense1, FALLING);
 attachInterrupt(1, sense2, FALLING);
void loop() {}
void sense1() {
 time1 = micros();
void sense2() {
 time2 = micros();
 if (time1 != 0) {
 time1 = 0;
Which one has better accuracy? The one without interrupts seems like it would be much less prone to bouncing bugs.
Osgeld
interrupts stop everything when a condition is met, to deal with that condition. with a loop you have to wait until it rolls back around to deal with the condition, which may or may not be in the same state as it was when it changed
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
johnwasser
Try this:
Code: [Select]
  while (bitRead(PIND, 2)) ;  // Wait for pin to go LOW
  time1 = micros();
  while (bitRead(PIND, 3)) ;  // Wait for pin to go LOW
  time2 = micros();
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Magician
Most accurate would be solution based on hardware ICP - input capture. Interrupt needs time to proceeds, even "while" have some overhead - jump code.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
