Palermo
Offline
Full Member
« Reply #15 on: January 24, 2013, 07:00:18 pm » |
If you do nothing special... #include <assert.h>
void setup( void ) { assert( false ); }
void loop( void ) { }
abort is called if the assertion fails. stderr does not come into the picture. That's all clear to me. That's how I already used it after you suggested it to me. But ... that way, it does no more than calling abort(), right? Why should I even bother with calling assert() then? What's the point if it does'nt add anything new to the picture?
Logged
Offline
Sr. Member
« Reply #16 on: January 24, 2013, 07:07:58 pm » |
You can disable it with the #define. Just a few posts up you said that was a good thing. 8^)
Logged
Temple, Texas
Offline
Sr. Member
« Reply #17 on: January 24, 2013, 07:17:06 pm » |
But now that it has been brought up, *is* there any way to redirect stderr to Serial, and then enable with #define __ASSERT_USE_STDERR , like int std c++ you could do
std::cerr.rdbuf(myOStream.rdbuf());
Logged
UK
Offline
Tesla Member
« Reply #18 on: January 24, 2013, 07:37:18 pm » |
But now that it has been brought up, *is* there any way to redirect stderr to Serial, Yes, there is. You can associate stdin, stdout and stderr with the hardware Serial if you want (or any other device) by writing put and get functions for the device and then associating these functions with each stream by calls to fdevopen().
Logged
Offline
God Member
« Reply #19 on: January 24, 2013, 07:55:53 pm » |
That's the most interesting piece of information I have seen all week.
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #20 on: January 24, 2013, 08:40:20 pm » |
Why should I even bother with calling assert() then? Welcome to "Design by Contract" ... http://en.wikipedia.org/wiki/Design_by_contract ... I highly recommend Bertrand Meyer's book.
Logged
Global Moderator
Melbourne, Australia
Online
Shannon Member
Lua rocks!
« Reply #21 on: January 24, 2013, 08:42:09 pm » |
What does actually abort() do in Arduino?
From stdlib.h: /** The abort() function causes abnormal program termination to occur. This realization disables interrupts and jumps to _exit() function with argument equal to 1. In the limited AVR environment, execution is effectively halted by entering an infinite loop. */ extern void abort(void) __ATTR_NORETURN__;
A simple error handler could be: if (somethingBadHappens) { Serial.println (F("Bad thing XYZ happened.")); Serial.flush (); exit (1); }
The flush call will ensure the message appears before you go into the infinite loop. The F macro saves wasting valuable RAM on the message.
Logged
Global Moderator
Online
Shannon Member
Lua rocks!
« Reply #23 on: January 24, 2013, 08:49:11 pm » |
Actually I got bitten in one of my libraries because exit() isn't always implemented. This might be neater: if (somethingBadHappens) { Serial.println (F("Bad thing XYZ happened.")); Serial.flush (); noInterrupts (); while (true) { } // give up }
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #24 on: January 24, 2013, 08:53:05 pm » |
This should get you started... #define __ASSERT_USE_STDERR #include <assert.h>
extern void __assert( const char *__func, const char *__file, int __lineno, const char *__sexp ) { // Put your stuff here. // __func is the function name (setup) // __file is the module name (the name of your sketch) // __lineno is the source code line number of the assert // __sexp is the assert expression (as a C string)
Serial.print( F( "ASSERT FAILURE: " ) ); Serial.print( __file ); Serial.print( F( ": " ) ); Serial.print( __func ); Serial.print( F( ": #" ) ); Serial.print( __lineno ); Serial.println(); Serial.flush (); noInterrupts (); while (true) { } // give up }
Bear in mind that each assert puts up to three string constants in SRAM. A better version would keep the string constants in Flash.
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
I only know some basic electricity....
« Reply #25 on: January 24, 2013, 11:17:31 pm » |
Silly me, I thought I'd need an underlying OS to abort to! But then when I write code, I expect users to make the occasional error... since 1980.
Logged
Examples can be found at Learning in the Main Site and at the Playground
Global Moderator
Online
Shannon Member
Lua rocks!
« Reply #26 on: January 25, 2013, 12:09:38 am » |
Look on the bright side. Users expect programmers to make the occasional error, too.
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #27 on: January 25, 2013, 12:24:25 am » |
Users expect programmers to make the occasional error, too. And I never disappoint them.
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
« Reply #28 on: January 25, 2013, 01:14:54 am » |
From the OLD (it was old in 85) Programmer's Joke Sheet:
Users should not complain about the code they get. They are lucky to get anything at all.
1980 is when I started writing programs for engineers. Error handling became a must!
Logged
Palermo
Offline
Full Member
« Reply #29 on: January 25, 2013, 12:10:40 pm » |
Priceless!!!
Logged
