Topic: Timing Problem with Lanc & pulsein (Read 3506 times) previous topic - next topic
makru83
Hi Duane,
yes, that's the Code I am using since Yesterday which works great. Look at my Reply #8
The Arduino Mega still uses Pin 2 & 3 + extra Int Pins on 18-21
See -> http://arduino.cc/en/Reference/AttachInterrupt
But it is still driving me nuts that I am not getting your great Example to work, because I want to use the Code with an Arduino Mini 328, and might need more than 2 Channels,
but for now I am all good.
Thanks,
mario
DuaneB
   So its the multi channel code that you are having trouble with ?
   At one time there was a bug in the pinchangeint library which stopped it working on some pins, which version are you using ?
   I will dig out a Mega tomorrow and get the code up and running just to make sure I haven't done anything daft my side - I use 328 based UNOs most of the time.
Duane B
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
makru83
I am using the latest Verion 2.19 beta of the PinChangeInt library.
I will get my 328 Micro Boards sometime this week, so currently I am stuck with the mega.
