Topic: decode RF signal (Read 2527 times) previous topic - next topic
derrij
It is possible receive and decode signal from remote switch remote control if known this about RF signal:
RF Code:
0: (-800, +400)
1: (+400, -800)
guidance code: (-6000, +800)
code sender: guidance code+20 address code+4 data code.
johncc
Probably.  Er, no, let's just say "maybe".
What is it?  Do you have a link to more information than what you've posted?
Cheers,
John
retrolefty
First you need to know the RF frequency the remote switch is using and then the modulation method it is using to send the data.
So no, not with as little you know so far.
Lefty
derrij
#3
Jan 27, 2013, 08:23 pm Last Edit: Jan 28, 2013, 09:22 am by derrij Reason: 1
RF frequency is 433Mhz
it is possible captured and then retranslate this signal?
andriej
Yes, I'm using "remoteswitch" library for this.
I didnt write it, it wourk out of the box for some devices.
derrij
i was trying to use remoteswitch library, but for this device it not working. i think because signals length are different from remoteswitch library.
