Topic: smd regulator for running a single 328 ic? (Read 2061 times) previous topic - next topic
jonisonvespaa
Jan 25, 2013, 12:41 pm Last Edit: Jan 25, 2013, 12:53 pm by jonisonvespa Reason: 1
hi
ive got a requirement to add a clock to a 328, so i need a battery backup for it if the power goes out just wondering what is the most common surface mount 100ma regulator i could use / most popular one. or maby is there a more suitable one that i could use for such a small current?
i did measure a single 328 running think it was about 15ma if i remember
my first choice would be a 78L05L just wondering if this is a common regulator
thank you
michinyon
Your question is unclear,  are you trying to power the microcontroller,  or the real time clock,  or charge up the battery ?
fungus
hi
thank you
What are your requirements for dropout voltage, etc.?
jonisonvespaa
#3
Jan 25, 2013, 01:02 pm Last Edit: Jan 25, 2013, 01:23 pm by jonisonvespa Reason: 1
mmm maby i have to think about this a bit more, ok drop off voltage not a problem as the battery backup will be a 12v.
im just trying to power the microcontroller, for when the power goes off.
i have 2 328's in the same circuit i would like to isolate 1 and run it using using a rechargeable battery
dc42
What is powering the circuit the rest of the time? You need to design it so that there is an orderly handover of power from the PSU to the battery. The usual solution is to feed the voltage regulator from the PSU through a diode and from the battery via another diode.
retrolefty
No need to have battery power for the 328p just to maintain time/date information. Do what most do and add a simple I2C RTC module that has it's own battery back-up protection.
https://www.adafruit.com/products/264
oric_dan
The other thing is, the 78L05L v.regs have a 5mA or so quiescent [bias] current, so not great
for low-power apps. Better choice would be something like an LP2950.
fungus
I've just been using some TI LM2936Qs, they seem to have the characteristics you're looking for.
dhenry
That's about right. I usually use 20ma as the practical upper limit.
As to regulators, if you are only power the mcu, you may think if a) you need a regulator; and b) you need a beefy one.
A 78L05 would be a good choice here, or the 1117s - they are much cheaper.
jonisonvespaa
#9
Jan 27, 2013, 11:48 am Last Edit: Jan 27, 2013, 11:56 am by jonisonvespa Reason: 1
thanks for the input, i think i will use a   ti  LM2936MP-5.0/NOPB
my only concern is the max regulation 50ma,  is a bit close to the currents ive measured of a running 328 ie 20ma not leaving much margin for error
my 328 will be idle as power to the circuit will be turned off
will this be ok?
JoshD
Have you tried entering your requirements on webench and checking out TI's suggestions?
http://www.ti.com/ww/en/analog/webench/power.shtml
Just tell 'em your voltage/current requirements and optimize for price/footprint/efficiency.  Requires registering at TI I think, but it's well worth it.
jonisonvespaa
dhenry
That can be a huge plus and a life-saver sometimes.
oric_dan
I just happened to tabulate 9 TO-92 v.regs today for a project I'm working on. Here is the list
versus current spec [not exhaustive - just the datasheets I had on file, BTW].
50 ma: LM2936
78 mA: Seiko-817
100 ma: 78Lxx, LP2950, LM2931, Seiko-812, Toko-TK711xx
250 mA: MCP1702, L4931
Note - some of these parts have "unusual" pinouts. There are also a lot of smt v.regs that I
wasn't interested in here.
Thermal resistance for TO-92 is 200 degC/W, so you have to be a little careful about over
heating at the higher currents. Eg, with Pd = Vdrop * Iload = 0.5W, and you limit Vdrop to
0.5W/.25A = 2V, it'll still burn your finger.
jonisonvespaa
ok
LM2931 wins, looks exactly what i need many thanks for the help.
