Author Topic: LedControl performance for simple game design . . . new library?  (Read 410 times)
I was excited about finishing a small project -- using an IR remote with mouse pad to control a LED on a 16 x 16 blue Led Matrix, see following video
http://player.youku.com/player.php/sid/XNTA2ODAwNDQ0/v.swf
I am thinking about making a simple game (not sure what yet, any ideas would be greatly appreciated) that uses this mouse pad as human input. However, after looking at LedControl CPP file, I am worried about the performance.
So I am contemplating an idea to write a buffer based LedMatrix lib that works like a video card -- when screen needs to be manipulated, it is done in memory, after all operations, the content of memory is dumped to device to make it faster, particularly scrolling, line drawing, circles, and rectangles.
Or there is a such thing already and I just don't know it.
Search for "mjkzz" on eBay :-)
I have just finished V0.07 of a fast buffer based led matrix library. Please check out this thread.
http://arduino.cc/forum/index.php/topic,147544.0.html
So far it is pretty fast with both sprite drawing and scrolling. Video will be posted soon.
Sprite drawing demostration.
http://player.youku.com/player.php/sid/XNTEyNTYzMDQw/v.swf
Valencia, Spain
Can it go past the edge of the matrix?
Yes, I programmed it to stop at the edge. Anything outside the specified boundary will be clipped so there is no waste of CPU.
Sorry, I did not post code here, but here it is:
// Written by Peter Y Lin, a.k.a MJKZZ
// Do whatever you want to do with this code but use this code at your own risk
#include <avr/io.h>
#include <avr/interrupt.h>
#include "LedMatrix.h"
#define TICK_IR_BREAK 5000
#define TICK_IR_ONE_MIN 400
#define TICK_IR_ONE_MAX 600
#define MAX_IR_PULSE 24
#define MAX_IR_DATA 8
#define MAX_IR_REPEAT 1
#define PIN_IR 2
#define IR_CODE_UP 0xC500
#define IR_CODE_DOWN 0xC480
#define IR_CODE_LEFT 0xC560
#define IR_CODE_RIGHT 0xC460
#define IR_CODE_UPLEFT 0xC562
#define IR_CODE_UPRIGHT 0xC462
#define IR_CODE_DOWNLEFT 0xC566
#define IR_CODE_DOWNRIGHT 0xC466
#define IR_CODE_UPARROW 0xC590
#define IR_CODE_DOWNARROW 0xC4D0
#define IR_CODE_LEFTARROW 0xC430
#define IR_CODE_RIGHTARROW 0xC420
volatile unsigned int g_tkPulse = 0;
volatile unsigned int g_ctPulse = 0;
volatile unsigned int g_arPulse[MAX_IR_PULSE];
volatile unsigned int g_irCode = 0;
volatile unsigned int g_irTemp = 0;
volatile unsigned int g_ctCode = 0;
LedMatrix ledDisplay = LedMatrix(5, 6, 7, 16, 16);
// This is a bitmap for a sprite
// The first two bytes specify width and height of
// sprite and the rest are bitmaps for sprite
byte g_sprite[6] =
0x03, // width
0x04, // height
0b10110000,
0b01001000,
0b01000100,
0b10100010,
volatile unsigned char g_x = 0;
volatile unsigned char g_y = 0;
void isr_ir()
g_tkPulse = TCNT1;
TCNT1 = 0;
if (g_tkPulse > TICK_IR_BREAK)
g_ctPulse = 0;
else if (g_ctPulse < MAX_IR_PULSE)
g_arPulse[g_ctPulse] = g_tkPulse;
g_ctPulse++;
if (g_ctPulse == 16)
g_irTemp = 0;
for(int i=0; i<g_ctPulse; i++)
if (g_arPulse[i] > TICK_IR_ONE_MIN && g_arPulse[i] < TICK_IR_ONE_MAX)
g_irTemp |= 1;
g_irTemp = g_irTemp << 1;
if (g_irTemp == g_irCode)
if (g_ctCode < MAX_IR_REPEAT)
g_ctCode++;
g_ctCode = 1;
g_irCode = g_irTemp;
TCCR1A = 0b00000000;
TCCR1B = 0b00000011;    // Clk*64 = 4uS
TCCR1C = 0b00000000;
pinMode(PIN_IR, INPUT);
attachInterrupt(0, isr_ir, FALLING);
ledDisplay.init(8);
ledDisplay.blank();
ledDisplay.sprite(g_x, g_y, (const char *)g_sprite, 6, GRAPHIC_DRAW_SRC);
ledDisplay.update();
if (g_ctCode == MAX_IR_REPEAT)
//Serial.print("Code = ");
//Serial.println(g_irCode, HEX);
ledDisplay.sprite(g_x, g_y, (const char *)g_sprite, 6, GRAPHIC_DRAW_XOR);
switch(g_irCode)
case IR_CODE_LEFT:
case IR_CODE_LEFTARROW:
if (g_x)
g_x--;
break;
case IR_CODE_RIGHT:
case IR_CODE_RIGHTARROW:
if (g_x < ledDisplay.getWidth()-3)
g_x++;
break;
case IR_CODE_UP:
case IR_CODE_UPARROW:
if (g_y)
g_y--;
break;
case IR_CODE_DOWN:
case IR_CODE_DOWNARROW:
if (g_y < ledDisplay.getHeight()-4)
g_y++;
break;
case IR_CODE_UPLEFT:
if (g_y)
g_y--;
if (g_x)
g_x--;
break;
case IR_CODE_UPRIGHT:
if (g_y)
g_y--;
g_x++;
break;
case IR_CODE_DOWNLEFT:
g_y++;
if (g_x)
g_x--;
break;
case IR_CODE_DOWNRIGHT:
g_y++;
g_x++;
break;
Serial.println(g_x, DEC);
g_irCode = 0;
g_ctCode = 0;
As you can see in code, the -3 and -4 at width and height part is stopping the sprite, but it can go over the edge,  of course, out of edge part of sprite will be clipped.
LedMatrix library is available on github . . .
https://github.com/mjkzz/LedMatrix
