Pages: [1] 2   Go Down
Author Topic: Arduino Compiler doesn't compile a particular sketch.  (Read 850 times)
Don't eat yellow snow.
Hi
I'm relatively new to everything here, but I've been spending a lot of time developing some sketches, and, until now, everything's been working fine.
For some reason the attached sketch cannot finish compiling. The little progress bar only gets to about 20%, and the compiler gives an error that starts with "Exception in thread "Thread-4256" java.lang.StackOverflowError", and is followed by hundreds of lines starting with "at java.util.regex.Pattern$".
It looks like this:
   at java.util.regex.Pattern$CharProperty.match(Pattern.java:3344)
   at java.util.regex.Pattern$Branch.match(Pattern.java:4114)
   at java.util.regex.Pattern$GroupHead.match(Pattern.java:4168)
   at java.util.regex.Pattern$Loop.match(Pattern.java:4295)
   at java.util.regex.Pattern$GroupTail.match(Pattern.java:4227)
   at java.util.regex.Pattern$BranchConn.match(Pattern.java:4078)
   at java.util.regex.Pattern$CharProperty.match(Pattern.java:3345)
... and it goes on and on and.
Please take a look and see if I'm missing something. I lack experience smiley-fat
Please note: a lot of the code is copied from previous sketches.
Oh, and it's still a work in progress, not a polished piece of machinery
Thanks, and forgive the newbie tendencies smiley-razz
Get Bitlash: http://bitlash.net
Nicely written code.
The compiler barfs here too, in the same way.  Smells like an interesting bug.
I think it would be a good thing to open an issue at:
    https://github.com/arduino/Arduino/issues
-br
Cool, I'll do that.
Thanks
as written in the issue, the IDE bug is triggered by a code bug in the two line:
#include // required to send and receive AT commands from the GPRS Shield
#include // required for I2C communication with the RTC
those include are just wrong
edit: removing include doesn't solve the problem. possible duplicate: http://code.google.com/p/arduino/issues/detail?id=962
« Last Edit: January 25, 2013, 08:26:16 am by lesto » Logged
my Arduino code: https://github.com/lestofante/arduinoSketch
sei nuovo? non sai da dove partire? leggi qui: http://playground.arduino.cc/Italiano/Newbie
Hold on a minute.  The includes are not wrong in the attachment to this forum thread.  They _look_ wrong in the github issue because they contain angle brackets which github markdown doesn't like.
If you re-test using the code enclosure above I believe you will see some of the most unusual output you've ever seen come out of the IDE.  At least it was for me.
Best,
-br
i think the error is in the process where that .ino is secretly translated into a .cpp adding some code (main etc..), but your (and others) code break some regex somewhere... also the stack is unuseful to anderstand where this happen, so i'm downloading arduino's source, adding a lot of system.out.println("until here all good"); and find out where this happen, and work out a solution.  But i'm at work and this weekend i'll have no time for this, so i hope to solve it soon.
Thanks, appreciate it smiley
If you comment out line 117, it compiles.
Something about this code:
  temp[ 25 ] = '\"';
You may be able to get going again by using a different means to assign the ascii quote character to temp[25]...
-br
Ok, so I kind of started over, and compiled the sketch after every action I took, to check where the problem started. I didn't solve the mystery, but I might have learnt something new.
Before I can explain what exactly happened, the reader needs to understand how I'm structuring this program.
I have two separate sketches I copy from: one that contains all the code necessary for control over the onboard real time clock (RTC), and one containing all the code necessary for control over the GPRS Shield I'm using.
My main objective is to log the times the Shield receives calls, and use the Shield to send data via text message at a predetermined time.
For this I simply need to combine my two aforementioned sketches, and add a few bits and bobs.
So everything I'm doing kind of happens in two halves: GPRS and RTC.
For my own sanity's sake, I keep the two devices' code separate.
Also, the function gprsListen() is the only GPRS function called directly from void loop(), and it's location actually made a difference, see below.
In the first sketch I attached, the order of all the parts were as follows:
  includes for both devices
  #defines for RTC
  variable declarations for GPRS
  variable declarations for RTC
  GPRS functions (including the function gprsListen)
  RTC functions
  setup
  loop (calls the gprsListen() function and updates the time)
The above structure made the compiler go all stupid. Now for the new structure (attached file):
  #includes for both devices
  #defines for RTC
  RTC functions
  GPRS functions
  setup
  gprsListen()
Ok, so there are 2 major changes, and 1 very weird thing:
  change 1: I had to swap the GPRS and RTC function bundles
  change 2: I had to put the gprsListen() function somewhere below setup. Anywhere above setup, and the compiler goes all stupid again.
  Very weird thing: In void setup() there is a Serial.println(""); indicated with a comment. If you comment it out, the sketch still compiles. If you delete the command, or only the quotes, the compiler goes all stupid with the same error.
Remember, effectively there is almost no difference between the sketches. They contain all the same functions and variables, I just pasted them in different places.
I don't know what any of this means, maybe you guys do.
Thanks so far
thanks billroy
So in the original sketch I changed " temp[ 25 ] = '\"'; " to " temp[ 25 ] = char(34); "
It compiles now, and should work, but I'd still like to know what the problem was (is?). Technically there is nothing wrong with the way it was.
i've spoken smiley-razz, we will see.
btw if you don't know what is a regex: http://en.wikipedia.org/wiki/Regular_expression
Seattle, WA USA
Seattle, WA USA
The \" construct is not how to embed a double quote in a string. You use two double quotes, instead. On line 117, using '\"' to describe what to store in the array element is wrong. It should be '"' (a single quote, a double quote, and a single quote). One line 114, the \" needs to be changed to "" (Two double quotes). That will result in the line ending with three double quotes and a semicolon. Then, the code compiles.
There is no bug that needs to be dealt with in the IDE.
Ok, I understand now. The only thing that puzzles me is that I copied the code from another sketch, and that sketch worked just fine. I'll go read up on this stuff on my own time. Thanks everybody smiley
#include <stdio.h>
int main(void *args[]){
  char c= '\"';
  printf("%c", c);
  c='"';
  printf("%c", c);
  return 0;
work perfectly with gcc (GCC) 4.7.2 .
Also this is a STACK OVERFLOW from java, not an error or a warning from the compiler. So the IDE is broken, it is not a big problem because it can be worked-around, but there still a big fault in the IDE; also this bug is duplicate: http://code.google.com/p/arduino/issues/detail?id=962
Problem part of code:
const char progdata[] PROGMEM =
":100000000EC015C014C013C012C011C010C00FC064\
:100010000EC00DC00CC00BC00AC009C008C011241E\
:100020001FBECFE5D2E0DEBFCDBF02D02AC0E8CFF1\
:100030000F931F93DF93CF9300D0CDB7DEB787E345\
:1000400090E021E0FC01208388E390E021E0FC01C6\
:10005000208388E390E028E330E0F901308121E05B\
:100060002327FC0120838FEF9FEF9A838983898167\
:100070009A818C01C8010197F1F78C011A830983D9\
:06008000E8CFF894FFCF69\
:00000001FF";
Fixed by changing to:
":100000000EC015C014C013C012C011C010C00FC064"
":100010000EC00DC00CC00BC00AC009C008C011241E"
":100020001FBECFE5D2E0DEBFCDBF02D02AC0E8CFF1"
":100030000F931F93DF93CF9300D0CDB7DEB787E345"
":1000400090E021E0FC01208388E390E021E0FC01C6"
":10005000208388E390E028E330E0F901308121E05B"
":100060002327FC0120838FEF9FEF9A838983898167"
":100070009A818C01C8010197F1F78C011A830983D9"
":06008000E8CFF894FFCF69"
":00000001FF";
as you see this IS a bug, as the multiline is legitimate.
I don't say that the ide/compiler should permit this, but at least give a good error and not a "stack overflow"
Pages: [1] 2   Go Up
