Topic: Capsense instrument problem! (Read 1 time) previous topic - next topic
caskes
Hey guys,
For an assignment on my university i have to make a creative instrument. I want to make a capsense instrument with 3 wires but i have a problem with it. Everytime i touch one of the wires, a tone should be played. But when i touch a wire the tone keeps playing, even when i am not touching it anymore. Can someone help me??
here is my code:
#include <CapSense.h>
CapSense   cs_4_2 = CapSense(4,2);        // 10M resistor between pins 4 & 2, pin 2 is sensor pin, add a wire and or foil if desired
CapSense   cs_4_6 = CapSense(4,6);        // 10M resistor between pins 4 & 6, pin 6 is sensor pin, add a wire and or foil
CapSense   cs_4_8 = CapSense(4,8);        // 10M resistor between pins 4 & 8, pin 8 is sensor pin, add a wire and or foil
int tone1 = 120;
int tone2 = 140;
int tone3 = 160;
  cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1 - just as an example
  pinMode(11, OUTPUT);
  long start = millis();
  long total1 =  cs_4_2.capSense(30);
  long total2 =  cs_4_6.capSense(30);
  long total3 =  cs_4_8.capSense(30);
  Serial.print(millis() - start);        // check on performance in milliseconds
  Serial.print("\t");                    // tab character for debug windown spacing
  Serial.print(total1);                  // print sensor output 1
  Serial.print("\t");
  Serial.print(total2);                  // print sensor output 2
  Serial.print("\t");
  Serial.println(total3);                // print sensor output 3
    delay(10);                             // arbitrary delay to limit data to serial port
  if(total1>300)    analogWrite(11,tone1); else digitalWrite(tone1, LOW);
  if(total2>300)    analogWrite(11,tone2); else digitalWrite(tone2, LOW);
  if(total3>300)    analogWrite(11,tone3); else digitalWrite(tone3, LOW);
PaulS
Code: [Select]
tone1, tone2, and tone3 are not pin numbers.
caskes
What can i use instead, then?
sorry, i am just a beginner  :~
PaulS
Quote
You used a pin number in the analogWrite() call. Why not use that same pin number in the digitalWrite() call?
caskes
I tried that too by writing this piece of code:
  if(total1>300)    analogWrite(11,tone1); else analogWrite(11, LOW);
  if(total2>300)    analogWrite(11,tone2); else analogWrite(1, LOW);
  if(total3>300)    analogWrite(11,tone3); else analogWrite(11, LOW);
but then it only plays the last if-statement :s
PaulS
Actually, I don't understand what you are doing. analogWrite() takes a pin number and a value between 0 and 255. You don't even call analogWrite() unless the value is greater than 300.
What is connected to pin 11?
caskes
you are right, i changed the analogWrites to digitalwrites, but the problem is still there. Connected to pin 11 is a Piezo buzzer which should play the 3 tones comming from the 3 wires. But it only plays the tone from the last if statement. Do you have any idea how to solve this?
ash901226
how does the value between 0 to 255 make tone?
are you using the tone function from arduino if so you cant make the arduino simultaniously turn on all three tone...
its have a limit of only one tone at a time and must be followed by a notone b2 the next one can be activated.
caskes
I am not using the tone from the library, i just assigned a 3 different values to them. But i think the problem might be in the if statements since i say: digitalWrite(11, LOW); maybe this turns the speaker off for the first two statements. I dont what i can use instead
ash901226
the do the long way around use a truth table 3 input 1 output
total 1   total 2   total 3        output tone
   0           0          0
   0           0          1
   0           1          0
   0           1          1
   1           0          0
   1           0          1
   1           1          0
   1           1          1
fill in the output tone that you want it to sound
consider that 1 is when totalX is higher then 300
that is if you want it to give only one sound
if you want it to sound in a sequential way use the blink without delay to change between tone 1 to tone 2 to tone 3
