Author Topic: Question about how to physically connect servos to an Arduino  (Read 411 times)
I want to purchase an Arduino and use it as a way to power and control a handful of linear servos. I've never added hardware to an Arduino before, but I have programmed an Arduino(-compatible) before. When I look at the connectors for linear servos (e.g., http://www.horizonhobby.com/products/1-9-gram-linear-long-throw-bb-servo-SPMAS2000LBB) they don't seem to be the same as the connector type (I think they use "JST-SHR connector type") on the headers of an Arduino board. How to I solve this hardware issue? Is there some sort of converter cable available or do I have to make my own solution? I see something here called Tinkerkit which apparently would solve my cabling problem but from what I can see there's a hard limit of 6 Tinkerkit servos and I was hoping to go a bit higher than 6. But I can settle for 6 if there's no other solution.
Seattle, WA USA
Seattle, WA USA
With a pair of wire cutters. Cut the connector off. You'll need to do that to connect power to it, anyway. The Arduino won't power it.
Your gonna want to power your servos separately from the arduino board.  Duane B has a good write up on how to do that.
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
He also has a write up on controlling up to 12 servos
http://rcarduino.blogspot.com/2012/01/can-i-control-more-than-x-servos-with.html
You can also find servo shields if you want to control more servos.  Here is an example
http://www.renbotics.com/servoshield2.php
The advice to cut off your servo wire connector is probably (wrong). I simply use hookup wire stuck in the servo connector pin hole and the arduino pin hole to connect the servo signal wire. Do the same on the servo connector to connect to an external power source.
Moderator edit: Insult removed. (Nick Gammon)
« Last Edit: January 25, 2013, 03:43:00 pm by Nick Gammon » Logged
put in key search words,
Thanks for all the interesting advice. One question... do I really need to use an external power source if my software will be controlling only a single servo at a time? I didn't mention that, but I will be powering only one servo at any given time. Perhaps the reason people think I need an external power supply is that they assumed I was going to move all the motors at once.
Apparently one of the links does address my last question. Sorry, I'll read the links thoroughly before asking any follow up questions.
Boston area, metrowest
Online Online
Or get a screw terminal breakout shield
Couple of options:
http://www.ruggedcircuits.com/html/quick_shield.html
http://www.ruggedcircuits.com/html/aussie_shield.html
Or a Mega screw shield if you have a bigger board
http://www.crossroadsfencing.com/BobuinoRev17/
Left Coast, CA (USA)
Measurement changes behavior
  Well the burden is on you to 'prove' to yourself that even just one of your servos can be powered properly from an arduino board. Current draw will be effected by the mechanical load placed on the servo, the maximum travel movements you issue and of course the current requirements of your specific servos. Servos use motors, motors draw lots of current. The arduino is excellent at controlling servos but very poor at powering them.
 We see so many posts from beginners about their servo based project having their boards go into unpredictably reset conditions and other maladies. So unless you can actually measure the worst case current consumption for all the external stuff you wire to your arduino board and can be sure it all stays below 400 ma or so, you are just delaying the successful completion of your project. Better to plan on adequately power management from the start rather then have to deal with all the rework otherwise bound to be required.
Lefty
Johannesburg UTC+2
As Lefty says:
Engineering is often about a solution being "elegant" not merely functional. To me, separating the plant from the control is "elegant". Engineering's also about "best practices", and there is no doubt from what this forum's gurus say, that powering a motor from the Arduino is not best practice, even if it can provide the current.
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Melbourne, Australia
Shannon Member
Lua rocks!
Here's an analogy ...
Some (Windows) computers have a power outlet on the back. The intention is/was that you could plug your monitor into that, and save having to use up two power points on your desk.
Now you might be tempted to think: "ah, power!" and hook up your toaster, room heater, or electric drill to it.
But that exceeds what it is designed for, and the intention of such outlets is not to be a general "power supply".
So, it may work (powering the servos from the Arduino). It may work reliably. But quite possibly not.
How are you going to power your board?
I've not read the links.... so apologies to the author if I'm repeating.... but I'd buy some sockets and make an interface board/loom. Why? Because I can then easily swap devices, which aids testing, speeds repairs etc, and if I have a faulty unit, I can return it under warranty. For testing, there is hook-up wire.
JST = Japan Solderless Terminal
You need to know the pin centres, 1mm, 1.2mm, 1.25mm etc.  - check out the JST site, you will probably find specs & connector part numbers there or you may be directed to a distributor.
For whom does the clock pulse? It pulses for you!
Online Online
Digikey carries JST connectors.
Thanks for the awesome information. I hope this helps others besides myself.
