Loading...
Pages: [1]   Go Down
Author Topic: Is it possible to upload sketches over Bluetooth to an Arduino?  (Read 389 times)
The 10th Dimension
Offline Offline
Newbie
Making robots like a BAOUS!
View Profile
WWW
Hi everyone.  smiley-mr-green
I have a quick question - would it be possible for me to upload a sketch over Bluetooth onto my Arduino?
Some extra information:
I'm using a custom created board with an ATmega328 with the Arduino bootloader on it. The Bluetooth Module that I'm using is http://dx.com/p/jy-mcu-arduino-bluetooth-wireless-serial-port-module-104299.
I've connected the RX to TX and TX to RX and the power wires to the required +5V and ground. I can connect to the module using my Windows and my Mac but when it comes to uploading a program, it keeps saying that "Serial port 'COM5' already in use. Try quitting any programs that may be using it."
I'm pretty sure that no other programs are using it, so ...  smiley-confuse
Anyone have any suggestions?
Or am I just doing something really stupid?  smiley-sweat
Thanks in advance!  smiley-grin
AKdaBAOUS
Logged
Robots FTW! \(^0^)/
The 10th Dimension
Offline Offline
Newbie
View Profile
WWW
Hi again. ^___^
I have a feeling that the bluetooth module is broken because after following pretty much every tutorial out there, I can't seem to get a piece of software to detect it so I've given up on that for the time being.  smiley-sad
Just another question - how would I go about programming the ATmega328 using a wired connection? Could I simply just connect the RX and TX from a serial port in reverse to the RX and TX on the ATmega328 (i.e. RX/TX and TX/RX)? Or is there something more detailed that requires to be done?
Thanks again in advance!  smiley-lol
AKdaBAOUS
Logged
Robots FTW! \(^0^)/
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Hi again. ^___^
That would work for the data, but the Arduino IDE/AVRDUE activates the DTR control signal (through a series cap to the avr reset pin) to cause a auto-reset that starts the AVR bootloader at the correct time that AVRDUDE is expecting it to be active to start the upload process. One can use a manual reset button to reset the chip at the correct time, but the timing can be tricky for some to perform.
Lefty
AKdaBAOUS
Logged
The 10th Dimension
Offline Offline
Newbie
View Profile
WWW
Ah cool, well I'll give the timing a try and if that doesn't work then I shall attempt something different.  smiley-mr-green
Thanks!  smiley-lol
Logged
Robots FTW! \(^0^)/
Offline Offline
Brattain Member
View Profile
Thanks!  smiley-lol
The method that works pretty good for me is to press and hold the manual reset switch down and then hit upload and when you see the completed compiled sketch size displayed in the IDE then release the reset switch. May take a little practice.
Lefty
Logged
The 10th Dimension
Offline Offline
Newbie
View Profile
WWW
Thanks for the tip!  smiley-lol
AKdaBAOUS
Logged
Robots FTW! \(^0^)/
The 10th Dimension
Offline Offline
Newbie
View Profile
WWW
Ok, I've tried over 50 times and it didn't work so I officially give up - I'll now pursue another solution.  smiley-mr-green
Thanks for all the help anyway!  smiley-lol
Regards,
AKdaBAOUS
Logged
Robots FTW! \(^0^)/
British Columbia, Canada
Offline Offline
Newbie
View Profile
I'm a newbie too, and I have had quite some trouble with this exact problem.  I have not gotten my DTR reset system to work yet, but I have mastered the manual reset method.  My Bluetooth module status LED flashes slowly when ready to connect, and goes solid when connected.  The procedure I have used successfully is to press "upload sketch" on the Arduino IDE, then press and hold the reset button on my Arduino.  When I see my Bluetooth Status LED go from flashing to solid, I immediately let go of the reset button.  Works every time for me.
I hope that helps!
Logged
The 10th Dimension
Offline Offline
Newbie
View Profile
WWW
Thanks for the advice  smiley-mr-green - I'll give it a go when my new Bluetooth module arrives (turns out that there was some voltage problems and I kinda blew it up  smiley-sweat).
AKdaBAOUS
Logged
Robots FTW! \(^0^)/
Pages: [1]   Go Up
Print
Jump to:
