« on: January 25, 2013, 03:23:47 pm » |
HI there. I have a problem with trying to transmit data from sensors from my bot using a mega with a NRF24L01 (long range 1,000m ver) to my base station using an UNO with same NRF24. I "think" it has to do with sending various types of data at once like ints floats strings? Can some one with experience in sending GPS or other like sensor data kind of guide me in this? The TX sends some sort of data but it's all mucked up on the RX I do not know if it's getting messed up before (when being stuffed into the array for transmission) or after ti's being sent. Here is my (TX) Code void NrfTrans(){ //****************************Info being Sent********************** // GPS NMEA data (3 vals) // IMU Roll Pitch Yaw (3 vals) //**************put values in array?************** byte vals[6]; //**********Send IMU Roll Pitch Yaw values********** vals[0] =ToDeg(roll); //example + or - 134.987 vals[1] =ToDeg(pitch); //example + or - 134.987 vals[2] =ToDeg(yaw); // example + or - 134.987 vals[3] =flat; //example 40.111111111 vals[4] =flon; //example -40.111111111 vals[5] =Tgps.satellites(); //example 8 //************************************************** //**************finish putting values in array?************** //**************Start Transmit package************** Mirf.setTADDR((byte *)"base1"); // set name of Reciever Mirf.send(vals); // data to send Serial.println(" Sent"); while(Mirf.isSending()){ } delay(10); }
Here is my base station code (RX) #include <Mirf.h> #include <MirfHardwareSpiDriver.h> #include <MirfSpiDriver.h> #include <nRF24L01.h> #include <SPI.h> //-+-+-+>>>> NRF24 Incoming data holders<<<<<<-+-+-+ float val0; // IMU Roll float val1; // IMU Pitch float val2; // IMU Yaw float val3; // Latitude float val4; // Longitude int val5; // # of Satalites //********************************************* void setup(){ Serial.begin(57600); //**************Start Transiever (NRF24L01) config************** Serial.println("...Radio Booting..."); // print somthing once to Serial to know your up Mirf.cePin = 8; Mirf.csnPin = 9; Mirf.spi = &MirfHardwareSpi; Mirf.init(); Mirf.setRADDR((byte *)"base1"); Mirf.payload = 16 * sizeof(byte); Mirf.config(); Serial.println("...Radio UP..."); // print somthing once to Serial to know your up //**************End Transiever (NRF24L01) config************** } void loop(){ //-+-+-+>>>>Start data collection from transciever<<<<<<-+-+-+ byte data[Mirf.payload]; if(Mirf.dataReady()){ do{ Mirf.getData(data); //*********** Start array to collect pot/sensor data ********* val0 = data[0]; //IMU Roll val1 = data[1]; //IMU Pitch val2 = data[2]; //IMU Yaw val3 = data[3]; //IMU Latitude val4 = data[4]; //IMU Longitude val5 = data[5]; //IMU # of Satalites //*********** End array to collect pot/sensor data ********* //**********Start Loop to print array to Serial Monitor /* int i; for (i = 0; i < 16; i = i + 1) { Serial.println(data[i], DEC); } //*/
//**********End Loop to print array to Serial Monitor delay(10); } while(!Mirf.rxFifoEmpty()); } //++++++++ END data collection from transciever++++++++++++
Serial.print("!"); Serial.print("ANG:"); Serial.print(val0); Serial.print(","); Serial.print(val1); Serial.print(","); Serial.print(val2); Serial.println(); Serial.print("Lat: "); Serial.print(val3); Serial.print(" Long: "); Serial.print(val4); Serial.print(" SAT: "); Serial.print(val5); Serial.println();
} // end of program
UK
« Reply #1 on: January 25, 2013, 04:17:06 pm » |
You need to post ALL of your code for us to have any real chance of seeing the problem, but I suspect the problem may be that you're trying to store float values in bytes.
« Reply #2 on: January 25, 2013, 04:54:54 pm » |
tried to post the full code but the forum spit it back saying it was over the max 9500 chars. here is the TX so ill have to split it in 2 or more posts Part_01 #include <NewPing.h> #include <Arduino.h> #include <Wire.h> #include <stdio.h> #include <Mirf.h> #include <MirfHardwareSpiDriver.h> #include <MirfSpiDriver.h> #include <nRF24L01.h> #include <SPI.h> #include <TinyGPS.h> //-+-+-+>>>> START Ultrasonic Sensor section<<<<<<-+-+-+ #define TRIGGER_PIN 23 // Arduino pin tied to trigger pin on the ultrasonic sensor. #define ECHO_PIN 22 // Arduino pin tied to echo pin on the ultrasonic sensor. #define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm. //-+-+-+>>>> END Ultrasonic Sensor section<<<<<<-+-+-+ //-+-+-+>>>> START MotorDriver Vars section<<<<<<-+-+-+ #define Mspeed0 0 #define Mspeed1 100 #define Mspeed2 150 #define runs1 2 #define runs2 3 #define mDelay1 100 #define mDelay2 150 //-+-+-+>>>> END MotorDriver Vars section<<<<<<-+-+-+ //-+-+-+>>>> START GPS Vars section<<<<<<-+-+-+ #define WPT_IN_RANGE_M 1 //-+-+-+>>>> END GPS Vars section<<<<<<-+-+-+ //-+-+-+>>>> SRTART POLOLU MINIMU - 9DOF Sensor section<<<<<<-+-+-+ // LSM303 accelerometer: 8 g sensitivity // 3.8 mg/digit; 1 g = 256 #define GRAVITY 256 //this equivalent to 1G in the raw data coming from the accelerometer #define ToRad(x) ((x)*0.01745329252) // *pi/180 #define ToDeg(x) ((x)*57.2957795131) // *180/pi // L3G4200D gyro: 2000 dps full scale // 70 mdps/digit; 1 dps = 0.07 #define Gyro_Gain_X 0.07 //X axis Gyro gain #define Gyro_Gain_Y 0.07 //Y axis Gyro gain #define Gyro_Gain_Z 0.07 //Z axis Gyro gain #define Gyro_Scaled_X(x) ((x)*ToRad(Gyro_Gain_X)) //Return the scaled ADC raw data of the gyro in radians for second #define Gyro_Scaled_Y(x) ((x)*ToRad(Gyro_Gain_Y)) //Return the scaled ADC raw data of the gyro in radians for second #define Gyro_Scaled_Z(x) ((x)*ToRad(Gyro_Gain_Z)) //Return the scaled ADC raw data of the gyro in radians for second // LSM303 magnetometer calibration constants; use the Calibrate example from // the Pololu LSM303 library to find the right values for your board #define M_X_MIN -602 #define M_Y_MIN -668 #define M_Z_MIN -592 #define M_X_MAX 391 #define M_Y_MAX 422 #define M_Z_MAX 524 #define Kp_ROLLPITCH 0.02 #define Ki_ROLLPITCH 0.00002 #define Kp_YAW 1.2 #define Ki_YAW 0.00002 //OUTPUTMODE=1 will print the corrected data, //OUTPUTMODE=0 will print uncorrected data of the gyros (with drift) #define OUTPUTMODE 1 //#define PRINT_DCM 0 //Will print the whole direction cosine matrix #define PRINT_ANALOGS 0 //Will print the analog raw data #define PRINT_EULER 1 //Will print the Euler angles Roll, Pitch and Yaw #define STATUS_LED 13 //-+-+-+>>>> END POLOLU MINIMU - 9DOF Sensor section<<<<<<-+-+-+ //-+-+-+>>>> START MotorDriver Vars section<<<<<<-+-+-+ int DIR_A = 12; //L298 DIR A Digital High/Low = left/right int PWM_A = 3; //L298 PWM A Analog int ENA_A = 9; //L298 Enable A Digital Hight/low on/off int DIR_B = 13; //L298 DIR A Digital High/Low = left/right int PWM_B = 11; //L298 PWM A Analog int ENA_B = 8; //L298 Enable A Digital Hight/low on/off int oTime = 0; //-+-+-+>>>> END MotorDriver Vars section<<<<<<-+-+-+ //-+-+-+>>>> SRTART POLOLU MINIMU - 9DOF Sensor section<<<<<<-+-+-+ int SENSOR_SIGN[9] = { 1,1,1,-1,-1,-1,1,1,1}; //Correct directions x,y,z - gyro, accelerometer, magnetometer float G_Dt=0.02; // Integration time (DCM algorithm) We will run the integration loop at 50Hz if possible long timer=0; //general purpuse timer long timer_old; long timer24=0; //Second timer used to print values int AN[6]; //array that stores the gyro and accelerometer data int AN_OFFSET[6]={ 0,0,0,0,0,0}; //Array that stores the Offset of the sensors int gyro_x; int gyro_y; int gyro_z; int accel_x; int accel_y; int accel_z; int magnetom_x; int magnetom_y; int magnetom_z; float c_magnetom_x; float c_magnetom_y; float c_magnetom_z; float MAG_Heading; float Accel_Vector[3]= { 0,0,0}; //Store the acceleration in a vector float Gyro_Vector[3]= { 0,0,0};//Store the gyros turn rate in a vector float Omega_Vector[3]= { 0,0,0}; //Corrected Gyro_Vector data float Omega_P[3]= { 0,0,0};//Omega Proportional correction float Omega_I[3]= { 0,0,0};//Omega Integrator float Omega[3]= { 0,0,0}; // Euler angles float roll; float pitch; float yaw; float errorRollPitch[3]= { 0,0,0}; float errorYaw[3]= { 0,0,0}; unsigned int counter=0; byte gyro_sat=0; float DCM_Matrix[3][3]= { { 1,0,0 } ,{ 0,1,0 } ,{ 0,0,1 } }; float Update_Matrix[3][3]={ { 0,1,2 } ,{ 3,4,5 } ,{ 6,7,8 } }; //Gyros here float Temporary_Matrix[3][3]={ { 0,0,0 } ,{ 0,0,0 } ,{ 0,0,0 } }; //-+-+-+>>>> END POLOLU MINIMU - 9DOF Sensor section<<<<<<-+-+-+ //-+-+-+>>>> START Ultrasonic Sensor section<<<<<<-+-+-+ NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance. const int dangerThresh = 10; //threshold for obstacles (in cm) int leftDistance, rightDistance, centerDistance; //distances on either side //-+-+-+>>>> END Ultrasonic Sensor section<<<<<<-+-+-+ //-+-+-+>>>> Start Tac sensor contact section<<<<<<-+-+-+ int leftWiskerPin = 31; int rightWiskerPin = 30; int oldLeftWiskerValue; int oldRightWiskerValue; int numOfLeftWiskerhits = 0; int numOfRightWiskerhits = 0; int leftWiskerValue; int rightWiskerValue; //-+-+-+>>>> END Tac sensor contact section<<<<<<-+-+-+ //-+-+-+>>>> Start US PING averaging section<<<<<<-+-+-+ //------------------Avrageing----------------------------------- const int numReadings = 5; int readings[numReadings]; // the readings from the analog input int index = 0; // the index of the current reading int total = 0; // the running total int average = 0; // the average //------------------Avrageing----------------------------------- //-+-+-+>>>> END US PING averaging section<<<<<<-+-+-+ //-+-+-+>>>> START GPS INIT section<<<<<<-+-+-+ TinyGPS Tgps; float flat, flon; //-+-+-+>>>> END GPS INIT section<<<<<<-+-+-+ //-+-+-+>>>> Start VT100 INIT section<<<<<<-+-+-+ //-+-+-+>>>> END VT100 INIT section<<<<<<-+-+-+
void setup() { Serial.begin(57600); Serial2.begin(57600); //GPS INPUT (LocoSYS LS20031) //**************Start Transiever (NRF24L01) config************** Serial.println("Radio Booting ... "); // Print some stuff to serial Mirf.cePin = 48; Mirf.csnPin = 49; Mirf.spi = &MirfHardwareSpi; Mirf.init(); Mirf.setRADDR((byte *)"robot"); Mirf.payload = 16 * sizeof(byte); Mirf.config(); Serial.println("Radio UP ... "); // Print some stuff to serial //**************End Transiever (NRF24L01) config************** //-+-+-+>>>> Start Tac sensor contact section<<<<<<-+-+-+ pinMode(leftWiskerPin, INPUT); pinMode(rightWiskerPin, INPUT); digitalWrite(leftWiskerPin, HIGH); digitalWrite(rightWiskerPin, HIGH); //-+-+-+>>>> END Tac sensor contact section<<<<<<-+-+-+ //-+-+-+>>>> START MotorDriver Vars section<<<<<<-+-+-+ pinMode(DIR_A, OUTPUT); pinMode(PWM_A, OUTPUT); pinMode(ENA_A, OUTPUT); pinMode(DIR_B, OUTPUT); pinMode(PWM_B, OUTPUT); pinMode(ENA_B, OUTPUT); //-+-+-+>>>> START MotorDriver Vars section<<<<<<-+-+-+ //-+-+-+>>>> Start US PING averaging section<<<<<<-+-+-+ for (int thisReading = 0; thisReading < numReadings; thisReading++) readings[thisReading] = 0; //-+-+-+>>>> END US PING averaging section<<<<<<-+-+-+ //-+-+-+>>>> Start VT100 INIT section<<<<<<-+-+-+ Serial.print(BYB); Serial.println(CLR); //-+-+-+>>>> END VT100 INIT section<<<<<<-+-+-+ //-+-+-+>>>> START POLOLU MINIMU - 9DOF Sensor section<<<<<<-+-+-+ Serial.println("IMU INIT ... "); // Print some stuff to serial I2C_Init(); delay(1500); Accel_Init(); Compass_Init(); Gyro_Init(); delay(20); for(int i=0;i<32;i++) // We take some readings... { Read_Gyro(); Read_Accel(); for(int y=0; y<6; y++) // Cumulate values AN_OFFSET[y] += AN[y]; delay(20); } for(int y=0; y<6; y++) AN_OFFSET[y] = AN_OFFSET[y]/32; AN_OFFSET[5]-=GRAVITY*SENSOR_SIGN[5]; for(int y=0; y<6; y++) delay(2000); timer=millis(); delay(20); counter=0; Serial.println("IMU Stream active ... "); // Print some stuff to serial //-+-+-+>>>> END POLOLU MINIMU - 9DOF Sensor section<<<<<<-+-+-+ }
« Last Edit: January 25, 2013, 08:01:08 pm by Cyric »
« Reply #3 on: January 25, 2013, 04:55:49 pm » |
Part_02 void loop() { unsigned int distanceFwd = averagePing(); if (distanceFwd > dangerThresh){ MoveForward(Mspeed1,runs2,mDelay1); WiskerCheck(); } else{ PingScan(distanceFwd); WiskerCheck(); } TgpsOut(); MinImu9(); NrfTrans(); WiskerCheck(); } //-+-+-+>>>> Start Nrf24L01 Transmitter Section<<<<<<-+-+-+ void NrfTrans(){ //****************************Info being Sent********************** // Ultrasonic Vals (1 val) // GPS NMEA data (? vals) // IMU Roll Pitch Yaw (3 vals) // Wisker hits (2vals) //**************put values in array?************** byte vals[6]; //**********Send IMU Roll Pitch Yaw values********** vals[0] =ToDeg(roll); vals[1] =ToDeg(pitch); vals[2] =ToDeg(yaw); vals[3] =flat; vals[4] =flon; vals[5] =Tgps.satellites(); //************************************************** //**************finish puting values in array?************** //**************Start Transmit package************** Mirf.setTADDR((byte *)"base1"); // set name of Reciever Mirf.send(vals); // data to send Serial.println(" Sent"); while(Mirf.isSending()){ } delay(10); } //-+-+-+>>>> End Nrf24L01 Transmitter Section<<<<<<-+-+-+ float TgpsOut() { bool newData = false; unsigned long chars; unsigned short sentences, failed; // For one second we parse GPS data and report some key values for (unsigned long start = millis(); millis() - start < 100;) { while (Serial2.available()) { char c = Serial2.read(); // Serial.write(c); // uncomment this line if you want to see the GPS data flowing if (Tgps.encode(c)) // Did a new valid sentence come in? newData = true; } }
if (newData) { // float flat, flon; unsigned long age; Tgps.f_get_position(&flat, &flon, &age); /* Serial.print("LAT="); Serial.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6); Serial.print(" LON="); Serial.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6); Serial.print(" SAT="); Serial.print(Tgps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : Tgps.satellites()); Serial.print(" PREC="); Serial.print(Tgps.hdop() == TinyGPS::GPS_INVALID_HDOP ? 0 : Tgps.hdop()); */ return flat,flon; } /* Tgps.stats(&chars, &sentences, &failed); Serial.print(" CHARS="); Serial.print(chars); Serial.print(" SENTENCES="); Serial.print(sentences); Serial.print(" CSUM ERR="); Serial.println(failed); */ } //-+-+-+>>>> START Sensor readings section<<<<<<-+-+-+ unsigned int ping(){ WiskerCheck(); delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings. unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS). return uS / US_ROUNDTRIP_CM; } unsigned int averagePing(){ total= total - readings[index]; // subtract the last reading: readings[index] = ping(); // read from the sensor: total= total + readings[index]; // add the reading to the total: index = index + 1; // advance to the next position in the array: if (index >= numReadings) // if we're at the end of the array... index = 0; // ...wrap around to the beginning: average = total / numReadings; // calculate the average: delay(1); // delay in between reads for stability return average; // send it as ASCII digits } unsigned int PingScan(unsigned int Fwddist){ if (Fwddist <= dangerThresh){ centerDistance = averagePing(); if (centerDistance <= dangerThresh){ MoveBackward(Mspeed2,runs2,mDelay2); MoveLeft(Mspeed1,runs1,mDelay1); WiskerCheck(); } else{ return 0; }
} } void WiskerCheck(){ int Tcount = 5; oldLeftWiskerValue = leftWiskerValue; oldRightWiskerValue = rightWiskerValue; leftWiskerValue = digitalRead(leftWiskerPin); rightWiskerValue = digitalRead(rightWiskerPin); if((leftWiskerValue == LOW) && (oldLeftWiskerValue == HIGH)) { MoveStop(Mspeed0,runs1,mDelay1); for (int LwiskT =0; LwiskT < Tcount; LwiskT++){ MoveBackward(Mspeed2,runs2,mDelay2); MoveRight(Mspeed2,runs2,mDelay2); } return; } if((rightWiskerValue == LOW) && (oldRightWiskerValue == HIGH)) { MoveStop(Mspeed0,runs1,mDelay1); for (int LwiskT =0; LwiskT < Tcount; LwiskT++){ MoveBackward(Mspeed2,runs2,mDelay2); MoveLeft(Mspeed2,runs2,mDelay2); } return; } else{ //Serial.println("=>WiskerCheck: else triggered<="); return; } return; } //-+-+-+>>>>START POLOLU MINIMU - 9DOF Sensor section<<<<<<-+-+-+ void MinImu9() //PoloLU MINIMU -9DOF {
if((millis()-timer)>=20) // Main loop runs at 50Hz { counter++; timer_old = timer; timer=millis(); if (timer>timer_old) G_Dt = (timer-timer_old)/1000.0; // Real time of loop run. We use this on the DCM algorithm (gyro integration time) else G_Dt = 0; // *** DCM algorithm // Data adquisition Read_Gyro(); // This read gyro data Read_Accel(); // Read I2C accelerometer if (counter > 5) // Read compass data at 10Hz... (5 loop runs) { counter=0; Read_Compass(); // Read I2C magnetometer Compass_Heading(); // Calculate magnetic heading } // Calculations... Matrix_update(); Normalize(); Drift_correction(); Euler_angles(); // *** // VTprintdata(); // printdata(); } } //-+-+-+>>>> END POLOLU MINIMU - 9DOF Sensor section<<<<<<-+-+-+ //-+-+-+>>>> END Sensor readings section<<<<<<-+-+-+
//-+-+-+>>>> Motor Driver section<<<<<<-+-+-+ void MoveLeft(int SPD, int mTime, int mDelay) { //int oTime = 0; while (oTime < mTime){ digitalWrite(ENA_A, LOW); digitalWrite(DIR_A, HIGH); analogWrite(PWM_A, SPD); digitalWrite(ENA_B, LOW); digitalWrite(DIR_B, LOW); analogWrite(PWM_B, SPD); delay(mDelay1); oTime++; } }
void MoveRight(int SPD, int mTime, int mDelay) { // int oTime = 0; while (oTime < mTime){ digitalWrite(ENA_A, LOW); digitalWrite(DIR_A, LOW); analogWrite(PWM_A, SPD); digitalWrite(ENA_B, LOW); digitalWrite(DIR_B, HIGH); analogWrite(PWM_B, SPD); delay(mDelay); oTime++; } } void MoveForward(int SPD, int mTime,int mDelay) { // int oTime = 0; while (oTime < mTime){ digitalWrite(ENA_A, LOW); digitalWrite(DIR_A, HIGH); analogWrite(PWM_A, SPD); digitalWrite(ENA_B, LOW); digitalWrite(DIR_B, HIGH); analogWrite(PWM_B, SPD); //move forward delay(mDelay); oTime++; } } void MoveBackward(int SPD, int mTime,int mDelay) { // int oTime = 0; while (oTime < mTime){ digitalWrite(ENA_A, LOW); digitalWrite(DIR_A, LOW); analogWrite(PWM_A, SPD); digitalWrite(ENA_B, LOW); digitalWrite(DIR_B, LOW); analogWrite(PWM_B, SPD); delay(mDelay); oTime++; } } void MoveStop(int SPD, int mTime,int mDelay) { // int oTime = 0; while (oTime < mTime){ digitalWrite(ENA_A, HIGH); digitalWrite(DIR_A, HIGH); analogWrite(PWM_A, SPD); digitalWrite(ENA_B, HIGH); digitalWrite(DIR_B, HIGH); analogWrite(PWM_B, SPD); delay(mDelay); oTime++; } } //-+-+-+>>>> Motor Driver section<<<<<<-+-+-+
Seattle, WA USA
Seattle, WA USA
« Reply #4 on: January 25, 2013, 06:56:02 pm » |
String OFF = "\033[0m"; String BOLD = "\033[1m"; String CLR = "\e[2J"; String CLRl = "\e[2K"; String BYB = "\e[1;33;40m"; What a waste. #define ToRad(x) ((x)*0.01745329252) // *pi/180 #define ToDeg(x) ((x)*57.2957795131) // *180/pi float flat, flon;
byte vals[6]; //**********Send IMU Roll Pitch Yaw values********** vals[0] =ToDeg(roll); vals[1] =ToDeg(pitch); vals[2] =ToDeg(yaw); vals[3] =flat; vals[4] =flon; You don't have a clue about variable types, do you? You can't store floating point data in 8 bit, integer variables. And, this is quite novel: return flat,flon; Completely wrong, but you get points for inventiveness.
« Reply #5 on: January 25, 2013, 08:20:18 pm » |
i use the ESC codes for VT100 term output, i took them out because i know most of you use the generic arduino ide serial monitor. They now have been removed. as for the return well i am still quite learning i just learned last week how to pass arguments to external functions so still need lots of work learning how to get them out. i am still shopping in the noob section i think. as for trying to stuff floats into byte array yea i know it would not work but it showed what i need to accomplish. if i had a nickle for every float to byte, f to b array converter i have looked at in the past 4 days i would be able to buy a starbucks coffee. i am thinking type casting is where i need to look? or i have seen some typedef union stuff. so to answer your question NO i do not know much about var types and i am not that experienced with programing on any level. but i keep plugging away at it and learning as i go. so i will say sorry now for being bad at programming and if that is not welcome here let me know. so any ideas on fixes for the return flat,flon and ANY help on the float to byte method would be fantastic.
« Reply #6 on: January 25, 2013, 08:44:30 pm » |
Well if you want to pass a bunch of different data types, I suggest you define a struct with your data and then a union to an array of bytes.
Find a C textbook and read the section about structs and unions.
And then read about how functions work.
And then read about data types.
« Reply #7 on: January 26, 2013, 01:39:31 am » |
WOW thanks i got your post a couple min after to made and and just got it to work. here is what i did TX side union imur_t { byte Uroll[4]; float froll; }imur; imur.froll = ToDeg(roll); byte vals[4]; vals[0] = imur.Uroll[0]; vals[1] = imur.Uroll[1]; vals[2] = imur.Uroll[2]; vals[3] = imur.Uroll[3];
then i push vals out like before in the Nrf function and i did the reverse on the other side like this RX side union imur_t { byte Uroll[4]; float froll; }imur; imur.Uroll[0] = data[0]; imur.Uroll[1] = data[1]; imur.Uroll[2] = data[2]; imur.Uroll[3] = data[3];
and then printed it out and boom there it was. -0.03 or 1.37 etc what ever the roll on the IMU was it sent it across. WOOT!. yes i am excited cos that %100 my own work. took over WELL over 100 tries the past few hours. it's now 1:33am here time for bedZ. now the big question is there better why than this because i have roll pitch yaw just on the imu and then i have the GPS sentences and the ultrasonic stuffs to do along with others. do i have to create... ( brain fart, cant i just make a function and send it transmit var in the type of a float and have it return the bytes and send them auto to the nrf?) like f2bconv(Sensor1()); and sen 1 being in form of a float be chopped and passed to Mirf.send? sorry it is real late here and i am not "good" at this fresh in the morning much less now lol. ill translate this in the morning!  ( i hope)
Seattle, WA USA
Seattle, WA USA
« Reply #8 on: January 26, 2013, 08:46:54 am » |
The function to send an array of bytes can send the bytes from any memory location. Define a struct. Store the data in an instance of the struct. Call the function to send the data with the struct instance and the size of the struct.
That function does not want a struct? Lie to it. Tell it that the struct is really a collection of bytes, using a cast - (byte *). Use the sizeof() function to get the number of bytes to send.
« Reply #9 on: January 26, 2013, 11:20:20 am » |
like this but with structs? i did this last night before i went to bed. TX float Tflo2byte(float inflo){
union flow2byte_t { byte outbyte[4]; float infloat; } flow2byte; flow2byte.infloat = inflo; byte output[4]; output[0] = flow2byte.outbyte[0]; output[1] = flow2byte.outbyte[1]; output[2] = flow2byte.outbyte[2]; output[3] = flow2byte.outbyte[3];
Mirf.setTADDR((byte *)"base1"); // set name of Reciever Mirf.send(output); // data to send while(Mirf.isSending()){ } delay(10); }
Rx side in main loop byte data[Mirf.payload]; if(Mirf.dataReady()){ do{ Mirf.getData(data); byte2flo(data); // send to byte to float converter delay(10); } while(!Mirf.rxFifoEmpty()); }
external to loop void byte2flo(byte data[]){ //*********** Start convertion from byte to float ********* union byte2flo_t { byte outbyte[4]; float outfloat; } byte2flo; byte2flo.outbyte[0]= data[0]; byte2flo.outbyte[1]= data[1]; byte2flo.outbyte[2]= data[2]; byte2flo.outbyte[3]= data[3]; Serial.println(byte2flo.outfloat); //*********** END convertion from byte to float ********* }
works but this is the output 0.38 -1.28 -12.58 now i have to "collect" the data and store it so i can turn that into something along the lines !IMU:0.38,-1.28,-12.58: (!) start of line (  end of line for external programs like processing or python. point me in the general direction i need to do this? like some kind of scanning routine that watches the incoming data or something. ill go check out structs now. thanks for the input PaulS and michinyon i appreciate this a lot.
« Reply #10 on: January 26, 2013, 12:45:54 pm » |
this does not compile i know. just wanted to know if i am heading in the right direction typedef struct{ float roll; float pitch; float yaw; }floatImu; floatImu inImu[2]; inImu[0].roll = ToDeg(roll); inImu[0].pitch = ToDeg(pitch); inImu[0].yaw = ToDeg(yaw); inImu[1] = (floatImu){roll,pitch,yaw}; outD = inImu[1]; Mirf.setTADDR((byte *)"base1"); // set name of Reciever Mirf.send(outD); // data to send while(Mirf.isSending()){ } delay(10);
Seattle, WA USA
Seattle, WA USA
« Reply #11 on: January 26, 2013, 01:26:29 pm » |
just wanted to know if i am heading in the right direction You are not headed in the wrong direction. It isn't clear why you have two instances of the struct, or what roll, pitch, and yaw are, or what outD is.
« Reply #12 on: January 26, 2013, 01:57:34 pm » |
eep! 2? my understanding of stucts must be way off then here is what i understood it to be RPYtransmit(ToDeg(roll),ToDeg(pitch),ToDeg(yaw));
void RPYtransmit(float inRoll, float inPitch, float inYaw){ //recieve current vals for ToDeg(roll),ToDeg(pitch),ToDeg(yaw) typedef struct { float roll; // place for roll value here float pitch;// place for pitch value here float yaw; // place for yaw value here }RPYT_type; // lable the struct
RPYT_type imuArray[2]; // create an array to hold roll,pitch,yaw for transmission
imuArray[0].roll = inRoll; // give float roll in RPYT_type value from incoming function argument inRoll imuArray[0].pitch = inPitch;// give float pitch in RPYT_type value from incoming function argument inPitch imuArray[0].yaw = inYaw;// give float yaw in RPYT_type value from incoming function argument inYaw imuArray[1] = (RPYT_type) {inRoll,inPitch,inYaw}; // combine inRoll,inPitch,inYaw from RPYT_type into imuArray position 2 (0 being first position in array)
Mirf.setTADDR((byte *)"base1"); // set name of Receiver Mirf.send(imuArray[2]); // figure out how to access and transmit second array segment containing inRoll,inPitch,inYaw while(Mirf.isSending()){ } delay(10); }
Seattle, WA USA
Seattle, WA USA
« Reply #13 on: January 26, 2013, 02:14:35 pm » |
RPYT_type imuArray[2]; // create an array to hold roll,pitch,yaw for transmission This is creating an array of structs. The question is why? Why 2? Each instance of the struct can hold roll, pitch, AND yaw. You do not heed three instances of the struct to hold the three values. And, you certainly don't need two instance for three values.
« Reply #14 on: January 26, 2013, 03:04:15 pm » |
ahh ok think im starting to see now void RPYtransmit(float inRoll, float inPitch, float inYaw){ //recieve current vals for ToDeg(roll),ToDeg(pitch),ToDeg(yaw) typedef struct { float roll; // place roll value here float pitch;// place pitch value here float yaw; // place yaw value here }RPYT_type; // lable the struct
RPYT_type imuVal = {inRoll,inPitch,inYaw}; // give float roll in RPYT_type value from incoming function argumet inRoll Serial.println(""); Serial.print(imuVal.roll); Serial.print(" , "); Serial.print(imuVal.pitch); Serial.print(" , "); Serial.print(imuVal.yaw); Serial.println(""); }
so how do i trick Mirf.send(); into thinking this is once piece of data?
