Loading...
Pages: [1]   Go Down
Author Topic: Difference between ATMEGA32U4RC-AU & ATMEGA32U4-AU (Leonardo)  (Read 279 times)
UK
Offline Offline
Sr. Member
View Profile
Just gone to order some ATMEGA32U4 ICs from RS to make my own boards up but they have both ATMEGA32U4RC-AU & ATMEGA32U4-AU with the NON "RC" variant costing £3.66 in 10s or the "RC" ones at £3.98
When I go into the RC variant's page and click for the data sheet it brings up the same one !
So is there any difference and do I need to get a specific one?
I'm looking at messing with them to create a MIDI device and a Keyboard emulator etc to the USB is the important bit.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Check section 33 of the datasheet:
Ordering Code            Default Oscillator
ATmega16U4-AU         External XTAL
ATmega16U4RC-AU     Internal Calib. RC
6.2.1    Default Clock Source ATmega16U4 and ATmega32U4
The device is shipped with Low Power Crystal Oscillator (8.0MHz-16MHz) enabled and with the
fuse CKDIV8 programmed, resulting in 1.0MHz system clock with an 8 MHz crystal. See Table
28-5 on page 348 for an overview of the default Clock Selection Fuse setting.
6.2.2     Default Clock Source ATmega16U4RC and ATmega32U4RC
The device is shipped with Calibrated Internal RC oscillator (8.0MHz) enabled and with the fuse
CKDIV8 programmed, resulting in 1.0MHz system clock. See Table 28-5 on page 348 for an
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
UK
Offline Offline
Sr. Member
View Profile
Cheers....  So which one do I need to build my own Leonardo boards running at 16MHz?
Many thanks..
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I think either one - you are going to change the fuses to use 16 MHz external oscillator anyway, yes?
Logged
UK
Offline Offline
Sr. Member
View Profile
That was the plan yes.
Logged
Pages: [1]   Go Up
Print
Jump to:
