Loading...
Pages: [1]   Go Down
Author Topic: 2 leds one comparator output  (Read 206 times)
Offline Offline
Jr. Member
View Profile
I would like to know if it is possible to control two leds separately using a single comparator output. ie above a certain voltage a  green led is on and a red is off, below a certain voltage, the green led is off and the red is on.
Thank you in advance
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
Yes, if the comparator has an open collector output 1.
> > >  1 Like an LM339, for example.
« Last Edit: January 27, 2013, 11:22:40 am by Runaway Pancake » Logged
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Eugene, Oregon
Offline Offline
Sr. Member
View Profile
WWW
I am totally unfamiliar with a comparator, but i am familir with charlieplexing, you could charlieplex 2 LEDs, and reverse polarity to switch LEDs.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Where is this variable voltage coming from?
If it is the analogWrite command be aware that this does not output a variable voltage but a pulse width modulated signal. You need a filter to make that an analogue voltage.
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
Logged
Pages: [1]   Go Up
Print
Jump to:
