Loading...
Pages: [1]   Go Down
Author Topic: How to dispense laundry soap  (Read 1861 times)
South East USA
Offline Offline
God Member
View Profile
A neat little project idea I've had is a little module with a three buttons (small, regular, and extra large loads), that automatically dispenses the correct amount of liquid laundry soap into the washing machine.  (it's a front loader with a lid/flap on the top that you open and pour the liquid soap in as the water runs through it).
Any ideas on how to somewhat accurately measure the detergent out?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
A lot of Rube Goldberg-ish things come to mind smiley-cool
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Peoples Republic of Cantabrigia
Offline Offline
God Member
Arduino happiness
View Profile
WWW
In commercial laundry applications such systems are very common, using large containers of detergent, fabric softener, etc. Think small low volume, high pressure pump and either a timer, # of piston pulses, etc determine how much detergent gets dispensed. It's open-loop control but good enough given that the clothes washer can determine how much detergent it needs from analyzing the load in it and the program selected.
« Last Edit: July 24, 2012, 03:34:59 pm by Constantin » Logged
USA
Offline Offline
God Member
View Profile
If you do actually use some sort of low pressure pumping system a liquid flow meter, like this one, might be useful.  The linked meter sends a pulse after ~2.25 ml, and least for fluids like water.  For more viscous fluids like laundry soap you may need to characterize it.  In any case, while not extremely accurate or precise, it should be sufficient for the task at hand.  There might be others even better suited, I just don't know of any off-hand.
Logged
South East USA
Offline Offline
God Member
View Profile
I use one of these to automatically measure the water into my coffe pot.  Doubt it would be accurate enough for just a quarter cup of high viscosity detergent.
Logged
USA
Offline Offline
God Member
View Profile
Ok, but it might be worthwhile to see if there are similar flow meters intended for measurement of viscous fluids.  I'm sure the have been in exisitence for quite a while, the real question would be is if any available that are affordable for a hobbyist-type budget.  One possible lead would be looking for the parts used in automatic hand soap dispensors.
Logged
South East USA
Offline Offline
God Member
View Profile
http://www.amazon.com/Brushless-Submersible-Water-Ideal-cooling/dp/B0051HI3OM/ref=pd_bxgy_sg_img_c
I got one of these to try...  An electric hand soap despensor would be good to check out alright!
Logged
Offline Offline
God Member
Arduino happiness
View Profile
WWW
My guess is that those type of units rely on a diaphragm pump of some kind. They are usually a bit more expensive than the volute-pumps used for water and other low-viscosity liquids. Making them last a long time in contact with detergents, bleaches, and so on may be a challenge. Good luck!
Logged
San Francisco
Offline Offline
Newbie
Arduino rocks
View Profile
Another method would be to have your machine mechanically press the pump (with a cam or a solenoid) on a standard liquid soap dispenser, like this one:
http://www.foodservicewarehouse.com/thunder-group/plsd377/p366978.aspx
Could vary quantity by number of pumps, timing, etc.
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
A peristaltic pump would be the proper method. They are also kinda crazy expensive, but making one from scratch should be pretty doable with a small, high torque motor (those $5 stepper motors or an RC servo).
Logged
Offline Offline
Newbie
View Profile
Look into finding a dosing pump. I use them to keep proper levels of calcium, alk in my aquarium automatically, they are quite accurate.
Logged
Offline Offline
Newbie
View Profile
Pre-measured containers with open/closed valves, and a float valve to stop pump when full.....
i don't think you would even need a micro controller for that....
« Last Edit: October 07, 2012, 04:58:36 pm by itsthedanyole » Logged
Offline Offline
Newbie
View Profile
I saw your post and wanted to know if you have had any luck dispensing the soap. I have been in touch with the sullivan pump company (they make fuel pumps for the RC hobby industry. They recommended the S752 fuel pump, though they did caution some uncertainty with laundry detergents with bleach.
Please let me know. I plan to make the same circuit, but doubling it to also dispense fabric softener.
I know the pump works even with thick fluid (I tried with my costco laundry detergent. It takes about 20 seconds to get to the middle line at 12V
If you have a sketch, I could use it to save me a lot of trial and error programming.
Thanks
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
Don't know about the dishwashing soap, but.... do you have any info or site describing your coffeepot setup?
New over here on the Home Automation board...
Cheers,
John
Logged
Pages: [1]   Go Up
Print
Jump to:
