Topic: continuous rotation servo won't stop (Read 2891 times) previous topic - next topic
giedow
Jan 26, 2013, 12:44 pm Last Edit: Jan 26, 2013, 02:13 pm by giedow Reason: 1
hello everyone,
I am trying to make a line following robot. I use continuous rotation servos, the problem is that the servos won't stop turning once started.
This is because the code doesn't check the sensor output after the first time.
Thanks a lot!
I used this sensor: http://dx.com/p/arduino-line-hunting-sensor-module-118057
and these servos: http://www.ebay.com/itm/clear-up-Spring-RC-SM-S4306R-360-Degree-Continuous-Rotation-Robot-Servo-SMS4306R-/350696583715?pt=US_Character_Radio_Control_Toys&hash=item51a7253223
#include <Servo.h>
 int sensorpin = 3;
 int speed0 = 91;
 int speed1 = 61;
 int speed2 = 111;
 int speed3 = 71;
Servo leftwheel;
Servo rightwheel;
leftwheel.attach(8);
rightwheel.attach(9);
 while(sensorpin == HIGH){
 leftwheel.write(speed1);
 rightwheel.write(speed2);
 while(sensorpin != HIGH){
 leftwheel.write(speed3);
 rightwheel.write(speed3);
I already tried: continue, goto, return, break, while, if, if else, swith case
AWOL
#1
Jan 26, 2013, 01:01 pm Last Edit: Jan 26, 2013, 02:03 pm by AWOL Reason: 1
The usual advice is to use the writeMicroseconds method on the Servo objects to find the stop point, but it may drift with load or battery state.
giedow
How would you write that in the code?
And thank you!
UKHeliBob
Where did you get these numbers ?
  int speed0 = 91;
  int speed1 = 61;
  int speed2 = 111;
  int speed3 = 71;
Your comments say that the servos will be stopped with the speed value set to speed1, speed2 or speed3.  It is very unlikely that they are all true bearing in mind the range of values this implies (61, 111 and 71)
AWOL
http://arduino.cc/en/Reference/ServoWriteMicroseconds
johncc
  int sensorpin = 3;
sensorpin is the pin number, to get its current value you need to use something like
if ( digitalRead(sensorpin)==HIGH)
http://arduino.cc/en/Reference/digitalRead
http://arduino.cc/en/Tutorial/Button
Cheers,
John
giedow
I got these numbers just by trying without the sensor, my mistake(I copy/pasted that and forgot to delete the text)
giedow
Thanks AWOL and johncc
I got it to work
#include <Servo.h>
  int sensorpin = 3;
  int speed0 = 91;
  int speed1 = 61;
  int speed2 = 111;
  int speed3 = 71;
Servo leftwheel;
Servo rightwheel;
    pinMode(3,INPUT);
leftwheel.writeMicroseconds(50);
rightwheel.writeMicroseconds(50);
  if ( digitalRead(sensorpin)!=HIGH){
  else if ( digitalRead(sensorpin)==HIGH){
johncc
PaulS
Considering that digitalRead() can only return HIGH or LOW, if the value is not HIGH, is there any possible way that the value can be anything other than LOW?
If you come to the correct conclusion that there is not, then explain why you need to test for HIGH.
The if/else if(/else) construct is used to test multiple conditions when there could be more than two. The if/else construct is preferred when there are only 2 possible conditions (as in the case of digitalRead).
giedow
