Topic: Retry 10 sec later if network fail to connect to router (Read 830 times) previous topic - next topic
smallpoul
Sorry if this question have already been ask but i didn't find the awnser. The problem is that if we lost the electricity, the router take more time to boot then the arduino so it fail to make a connection and i need to do a manual reset for it. Is therr a way or a command to reset the arduino if network fail to initialyse?
Thanks in advance
Mike
PeterH
Better to check for successful initialisation and retry until it succeeds.
I only provide help via the forum - please do not contact me for private consultancy.
PaulS
How to test for successful connection depends on whether you are using an Ethernet shield or a WiFi shield.
smallpoul
I use the ethernetshiel. I use the
ethernet.begin(mac, ip); in the void setup. And i use
if(ethernet.begin(mac) == o) could i put there a reset sketche and if so, how to??
Thanks
UKHeliBob
No need to reset the Arduino.  If the connection fails just keep trying until it succeeds as has been suggested.
smallpoul
I know what you mean but it's in the void setup, how could you loop it in the void setup? Could i initialise the ethernet from the void loop??
UKHeliBob
PaulS
Just like you would "loop it" in the loop() function.
while(Ethernet.begin(mac, IP) == 0)
   // do nothing
