Loading...
Pages: [1]   Go Down
Author Topic: digitalRead stays high when using ethernet control  (Read 185 times)
Offline Offline
Newbie
View Profile
Hello,
I'm a student working on my final project and it's the first time i'm using an arduino. My project is a robot that runs automaticaly with a laser scanner and manualy with push buttons.
The auto mode and the man mode work fine when in there own documents but when combined the manual mode goes bananas.
I traced the problem to the line Ethernet.begin(mac,ip);, if i delete this line the man mode works fine but when i leave it in there are 2 digital inputs that remain high even when they are not triggert by the fysical button. These inputs are  "int voor = digitalRead(DRUKKNOPvooruit);"
and "      int rechts = digitalRead(DRUKKNOPrechts);".
Does anybody have a idea how i can fix this?
As you can see my code is in dutch so please excuse me for any typo's.
Thanks in advance,
Joris
Code:
  Serial.begin(9600);                          // snelheid van de seriële communicatie vastleggen tussen arduino en pc
  pinMode(STOPvoorwielrechts, OUTPUT);         // deze klemmen zullen een waarde uitsturen
  pinMode(STOPvoorwiellinks, OUTPUT);
  pinMode(STOPachterwiellinks, OUTPUT);
  pinMode(STOPachterwielrechts, OUTPUT);
  pinMode(ACHTERUITvoorwielrechts, OUTPUT);
  pinMode(ACHTERUITvoorwiellinks, OUTPUT);
  pinMode(ACHTERUITachterwiellinks, OUTPUT);
  pinMode(ACHTERUITachterwielrechts, OUTPUT);
  pinMode(DRUKKNOPvooruit, INPUT);
  pinMode(DRUKKNOPachteruit, INPUT);
  pinMode(DRUKKNOPlinks, INPUT);
  pinMode(DRUKKNOPrechts, INPUT);
  pinMode(schakelaar, INPUT);
  digitalWrite(STOPvoorwielrechts, HIGH);
  digitalWrite(STOPvoorwiellinks, HIGH);
  digitalWrite(STOPachterwiellinks, HIGH);
  digitalWrite(STOPachterwielrechts, HIGH);
  delay(2000);
  Serial.println("connecting...");
  retry:
  if (client.connect(server, 2111))
      Serial.println("connected");
      Serial.println("connection failed");
      goto retry;
  int manueel = digitalRead(schakelaar);
if (manueel == HIGH)
     // Serial.println( "MANUELE mode" );
      snelheid = 80;
      int achter = digitalRead(DRUKKNOPachteruit);
      int links = digitalRead(DRUKKNOPlinks);
      if(rechts == LOW && links == LOW && voor == LOW && achter == LOW)
        stilstaan();
      if(voor == HIGH)
        delay(250);
        rechtdoor();
        Serial.println( "1" );
      if(achter == HIGH)
        delay(250);
        achteruit();
      if(links == HIGH)
        delay(250);
        naarLinks();
      if(rechts == HIGH)
        delay(250);
        naarRechts();
        Serial.println( "2" );
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
What pins are you trying to read from? The Ethernet shield uses pins 4, 10, 11, 12, and 13.
Logged
Offline Offline
Newbie
View Profile
I'm working with an arduino mega 2560.
The pins i'm using are:
const int DRUKKNOPachteruit = 50;
const int DRUKKNOPlinks = 52;
const int DRUKKNOPrechts = 51;
const int schakelaar = 44;
Drukknop = pushbutton
Schakelaar = switch
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Which are the Mega's SPI pins.
Logged
Offline Offline
Newbie
View Profile
I'm affraid, I don't know what SPI pins are ?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
There is no reason to be afraid. Ignorance can be cured.
SPI is how the Arduino and the Ethernet shield (and a lot of other devices) communicate. When you have a device attached that uses SPI, you can not use those same pins for other purposes.
Logged
Offline Offline
Newbie
View Profile
Thanks I understand.
But where can I find what numbers are mine SPI pins?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
On the home page, there is a Products link. On that page, there is a picture of each board that is a link. On each of those links, there is a section that talks about SPI pins. For the Mega, it says:
Quote
SPI: 50 (MISO), 51 (MOSI), 52 (SCK), 53 (SS). These pins support SPI communication using the SPI library. The SPI pins are also broken out on the ICSP header, which is physically compatible with the Uno, Duemilanove and Diecimila.
Logged
Offline Offline
Newbie
View Profile
Thank you very much!
Now I understand why my manual program doesn't work.
Logged
Pages: [1]   Go Up
Print
Jump to:
