Loading...
Pages: [1]   Go Down
Author Topic: MAX7219 madness  (Read 277 times)
Offline Offline
Newbie
View Profile
I try to drive a LED display with MAX7219 and Arduino. I use LTC-2727G common cathode 7-segment/4-digit display, which is previously successfully multiplexed with Arduino. But this time i need more free pins, and  i selected MAX7219 for driving the display.
The problem is, that if i run the MAX7219 7-segment example from LedControl library, all digits show "8", all segments light up, and nothing happens.
I can see that the MAX is writing characters to the first digit (but only there), because the first digit lights up sometimes brighter as the others.
What can cause this? I tried different values for Rset, but nohing changed.
My first thought was a shortage, but for all the 4 digits? Noooo smiley-grin MAX7219 is brand new...  Communication is OK...
Has anybody seen anything like that? Any help would be appreciated...
Logged
Sydney
Offline Offline
God Member
Big things come in large packages
View Profile
WWW
Would be helpful to have a circuit and the sketch.
Have you wired the segments and digit selections the right way round?
Logged
Offline Offline
Newbie
View Profile
I will upload the circuit, but i think it is mostly OK. (3 wires to MAX, and from that, wires to the LTC2727...)
It is possible that it is miswired, but i will check only tomorrow (and, miswired? for all the 4 digita? smiley and all segments are lighting? :S ). Sketch is uploaded from LedControl library's example, without changes (except pin definitions).
Schematic and PCB :
Link : http://kepz.atw.hu/1.png
http://kepz.atw.hu/2.png
I had to use lots of wires, due to small pcb size smiley-sad
(It is a desk clock with a thermometer, very simple.)
« Last Edit: January 26, 2013, 05:00:27 pm by ColT » Logged
Sydney
Offline Offline
God Member
View Profile
WWW
Usually worth trying the really obvious things first.
Logged
Offline Offline
Newbie
View Profile
I added scematic adn PCB to the first entry.
I took a short measure, and there is 5V on every digit outputs on the MAX...
« Last Edit: January 26, 2013, 05:21:32 pm by ColT » Logged
Offline Offline
Newbie
View Profile
OK guys, sorry for dumb questions! Error was a miswiring, the Max's Dig4 output was wired to the Adruino's A5, which i used for DIN to the MAX. So it haven't got any data received smiley-grin I think the error happened during the toner transfer, which after i have corrected the wires, whose were not transferred correctly.
Now it is working fine, thanks smiley
« Last Edit: January 27, 2013, 03:23:20 am by ColT » Logged
Pages: [1]   Go Up
Print
Jump to:
