Offline
Newbie
« on: January 26, 2013, 04:18:05 pm » |
Here is the code: #include "TVout.h"#include "fontALL.h"#include "schematic.h"#include "TVOlogo.h"TVout TV; int zOff = 150; int xOff = 0; int yOff = 0; int cSize = 50; int view_plane = 64; float angle = PI/60; float cube3d[8][3] = { {xOff - cSize,yOff + cSize,zOff - cSize}, {xOff + cSize,yOff + cSize,zOff - cSize}, {xOff - cSize,yOff - cSize,zOff - cSize}, {xOff + cSize,yOff - cSize,zOff - cSize}, {xOff - cSize,yOff + cSize,zOff + cSize}, {xOff + cSize,yOff + cSize,zOff + cSize}, {xOff - cSize,yOff - cSize,zOff + cSize}, {xOff + cSize,yOff - cSize,zOff + cSize} }; unsigned char cube2d[8][2]; void setup() { TV. begin(NTSC,120,96); TV.select_font(font6x8); intro(); TV. println( "I am the TVout\nlibrary running on a freeduino\n"); TV. delay(2500); TV. println( "I generate a PAL\nor NTSC composite video using\ninterrupts\n"); TV. delay(2500); TV. println( "My schematic:"); TV. delay(1500); TV.bitmap(0,0,schematic); TV. delay(10000); TV.clear_screen(); TV. println( "Lets see what\nwhat I can do"); TV. delay(2000); //fonts TV.clear_screen(); TV. println(0,0, "Multiple fonts:"); TV.select_font(font4x6); TV. println( "4x6 font FONT"); TV.select_font(font6x8); TV. println( "6x8 font FONT"); TV.select_font(font8x8); TV. println( "8x8 font FONT"); TV.select_font(font6x8); TV. delay(2000); TV.clear_screen(); TV. print(9,44, "Draw Basic Shapes"); TV. delay(2000); //circles TV.clear_screen(); TV.draw_circle(TV.hres()/2,TV.vres()/2,TV.vres()/3,WHITE); TV. delay(500); TV.draw_circle(TV.hres()/2,TV.vres()/2,TV.vres()/2,WHITE,INVERT); TV. delay(2000); //rectangles and lines TV.clear_screen(); TV.draw_rect(20,20,80,56,WHITE); TV. delay(500); TV.draw_rect(10,10,100,76,WHITE,INVERT); TV. delay(500); TV.draw_line(60,20,60,76,INVERT); TV.draw_line(20,48,100,48,INVERT); TV. delay(500); TV.draw_line(10,10,110,86,INVERT); TV.draw_line(10,86,110,10,INVERT); TV. delay(2000); //random cube forever. TV.clear_screen(); TV. print(16,40, "Random Cube"); TV. print(28,48, "Rotation"); TV. delay(2000); randomSeed( analogRead(0)); } void loop() { int rsteps = random(10,60); switch( random(6)) { case 0: for ( int i = 0; i < rsteps; i++) { zrotate(angle); printcube(); } break; case 1: for ( int i = 0; i < rsteps; i++) { zrotate(2* PI - angle); printcube(); } break; case 2: for ( int i = 0; i < rsteps; i++) { xrotate(angle); printcube(); } break; case 3: for ( int i = 0; i < rsteps; i++) { xrotate(2* PI - angle); printcube(); } break; case 4: for ( int i = 0; i < rsteps; i++) { yrotate(angle); printcube(); } break; case 5: for ( int i = 0; i < rsteps; i++) { yrotate(2* PI - angle); printcube(); } break; } } void intro() { unsigned char w,l,wb; int index; w = pgm_read_byte(TVOlogo); l = pgm_read_byte(TVOlogo+1); if (w&7) wb = w/8 + 1; else wb = w/8; index = wb*(l-1) + 2; for ( unsigned char i = 1; i < l; i++ ) { TV.bitmap((TV.hres() - w)/2,0,TVOlogo,index,w,i); index-= wb; TV. delay(50); } for ( unsigned char i = 0; i < (TV.vres() - l)/2; i++) { TV.bitmap((TV.hres() - w)/2,i,TVOlogo); TV. delay(50); } TV. delay(3000); TV.clear_screen(); } void printcube() { //calculate 2d points for( byte i = 0; i < 8; i++) { cube2d - = (unsigned char)((cube3d
- * view_plane / cube3d[2]) + (TV.hres()/2));
cube2d[1] = (unsigned char)((cube3d[1] * view_plane / cube3d[2]) + (TV.vres()/2)); } TV.delay_frame(1); TV.clear_screen(); draw_cube(); }
void zrotate(float q) { float tx,ty,temp; for(byte i = 0; i < 8; i++) { tx = cube3d ty = cube3d[1] - yOff; temp = tx * cos(q) - ty * sin(q); ty = tx * sin(q) + ty * cos(q); tx = temp; cube3d cube3d[1] = ty + yOff; } }
void yrotate(float q) { float tx,tz,temp; for(byte i = 0; i < 8; i++) { tx = cube3d tz = cube3d[2] - zOff; temp = tz * cos(q) - tx * sin(q); tx = tz * sin(q) + tx * cos(q); tz = temp; cube3d cube3d[2] = tz + zOff; } }
void xrotate(float q) { float ty,tz,temp; for(byte i = 0; i < 8; i++) { ty = cube3d[1] - yOff; tz = cube3d[2] - zOff; temp = ty * cos(q) - tz * sin(q); tz = ty * sin(q) + tz * cos(q); ty = temp; cube3d[1] = ty + yOff; cube3d[2] = tz + zOff; } }
void draw_cube() { TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[1][0],cube2d[1][1],WHITE); TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[2][0],cube2d[2][1],WHITE); TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[4][0],cube2d[4][1],WHITE); TV.draw_line(cube2d[1][0],cube2d[1][1],cube2d[5][0],cube2d[5][1],WHITE); TV.draw_line(cube2d[1][0],cube2d[1][1],cube2d[3][0],cube2d[3][1],WHITE); TV.draw_line(cube2d[2][0],cube2d[2][1],cube2d[6][0],cube2d[6][1],WHITE); TV.draw_line(cube2d[2][0],cube2d[2][1],cube2d[3][0],cube2d[3][1],WHITE); TV.draw_line(cube2d[4][0],cube2d[4][1],cube2d[6][0],cube2d[6][1],WHITE); TV.draw_line(cube2d[4][0],cube2d[4][1],cube2d[5][0],cube2d[5][1],WHITE); TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[6][0],cube2d[6][1],WHITE); TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[3][0],cube2d[3][1],WHITE); TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[5][0],cube2d[5][1],WHITE); }
I receive the following errors In file included from DemoNTSC.ino:1: /TVout.h:40:23: error: video_gen.h: No such file or directory /TVout.h:41:33: error: spec/hardware_setup.h: No such file or directory /TVout.h:42:35: error: spec/video_properties.h: No such file or directory
« Last Edit: January 26, 2013, 04:21:02 pm by jbdelutis »
Logged
Offline
Newbie
« Reply #1 on: January 26, 2013, 04:21:56 pm » |
Here is the tvout.h library code: /* Copyright (c) 2010 Myles Metzer
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. */ /* This library provides a simple method for outputting data to a tv from a frame buffer stored in sram. This implementation is done completly by interupt and will return give as much cpu time to the application as possible. */ #ifndef TVOUT_H #define TVOUT_H
#include <stdint.h> #include <avr/io.h> #include <avr/pgmspace.h> #include <avr/interrupt.h> #include <stdlib.h>
#include "video_gen.h" #include "spec/hardware_setup.h" #include "spec/video_properties.h"
// macros for readability when selecting mode. #define PAL 1 #define NTSC 0 #define _PAL 1 #define _NTSC 0
#define WHITE 1 #define BLACK 0 #define INVERT 2
#define UP 0 #define DOWN 1 #define LEFT 2 #define RIGHT 3
#define DEC 10 #define HEX 16 #define OCT 8 #define BIN 2 #define BYTE 0
// Macros for clearer usage #define clear_screen() fill(0) #define invert(color) fill(2)
Logged
Offline
Newbie
« Reply #2 on: January 26, 2013, 04:23:23 pm » |
Continued because of character limit: /* TVout.cpp contains a brief expenation of each function. */ class TVout { public: uint8_t * screen; char begin(uint8_t mode); char begin(uint8_t mode, uint8_t x, uint8_t y); void end(); //accessor functions unsigned char hres(); unsigned char vres(); char char_line(); //flow control functions void delay(unsigned int x); void delay_frame(unsigned int x); unsigned long millis(); //override setup functions void force_vscale(char sfactor); void force_outstart(uint8_t time); void force_linestart(uint8_t line); //basic rendering functions void set_pixel(uint8_t x, uint8_t y, char c); unsigned char get_pixel(uint8_t x, uint8_t y); void fill(uint8_t color); void shift(uint8_t distance, uint8_t direction); void draw_line(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1, char c); void draw_row(uint8_t line, uint16_t x0, uint16_t x1, uint8_t c); void draw_column(uint8_t row, uint16_t y0, uint16_t y1, uint8_t c); void draw_rect(uint8_t x0, uint8_t y0, uint8_t w, uint8_t h, char c, char fc = -1); void draw_circle(uint8_t x0, uint8_t y0, uint8_t radius, char c, char fc = -1); void bitmap(uint8_t x, uint8_t y, const unsigned char * bmp, uint16_t i = 0, uint8_t width = 0, uint8_t lines = 0); //hook setup functions void set_vbi_hook(void (*func)()); void set_hbi_hook(void (*func)());
//tone functions void tone(unsigned int frequency, unsigned long duration_ms); void tone(unsigned int frequency); void noTone(); //The following function definitions can be found in TVoutPrint.cpp //printing functions void print_char(uint8_t x, uint8_t y, unsigned char c); void set_cursor(uint8_t, uint8_t); void select_font(const unsigned char * f);
void write(uint8_t); void write(const char *str); void write(const uint8_t *buffer, uint8_t size);
Logged
Offline
Newbie
« Reply #3 on: January 26, 2013, 04:24:33 pm » |
Continued again because of character limit: void print(const char[]); void print(char, int = BYTE); void print(unsigned char, int = BYTE); void print(int, int = DEC); void print(unsigned int, int = DEC); void print(long, int = DEC); void print(unsigned long, int = DEC); void print(double, int = 2); void print(uint8_t, uint8_t, const char[]); void print(uint8_t, uint8_t, char, int = BYTE); void print(uint8_t, uint8_t, unsigned char, int = BYTE); void print(uint8_t, uint8_t, int, int = DEC); void print(uint8_t, uint8_t, unsigned int, int = DEC); void print(uint8_t, uint8_t, long, int = DEC); void print(uint8_t, uint8_t, unsigned long, int = DEC); void print(uint8_t, uint8_t, double, int = 2); void println(uint8_t, uint8_t, const char[]); void println(uint8_t, uint8_t, char, int = BYTE); void println(uint8_t, uint8_t, unsigned char, int = BYTE); void println(uint8_t, uint8_t, int, int = DEC); void println(uint8_t, uint8_t, unsigned int, int = DEC); void println(uint8_t, uint8_t, long, int = DEC); void println(uint8_t, uint8_t, unsigned long, int = DEC); void println(uint8_t, uint8_t, double, int = 2); void println(uint8_t, uint8_t);
void println(const char[]); void println(char, int = BYTE); void println(unsigned char, int = BYTE); void println(int, int = DEC); void println(unsigned int, int = DEC); void println(long, int = DEC); void println(unsigned long, int = DEC); void println(double, int = 2); void println(void); void printPGM(const char[]); void printPGM(uint8_t, uint8_t, const char[]); private: uint8_t cursor_x,cursor_y; const unsigned char * font; void inc_txtline(); void printNumber(unsigned long, uint8_t); void printFloat(double, uint8_t); };
static void inline sp(unsigned char x, unsigned char y, char c); #endif
Logged
East Anglia (UK)
Offline
Edison Member
May all of your blinks be without delay
« Reply #4 on: January 26, 2013, 04:28:10 pm » |
Have you got the header files that the errors refer to and, if so, where are they located ?
Logged
Offline
Newbie
« Reply #5 on: January 26, 2013, 04:30:33 pm » |
Ok I have moved the folder to libraries and get this error
TVout\TVout.cpp.o: In function `TVout::fill(unsigned char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:109: multiple definition of `TVout::fill(unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:109: first defined here TVout\TVout.cpp.o: In function `TVout::hres()': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:136: multiple definition of `TVout::hres()' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:136: first defined here TVout\TVout.cpp.o: In function `TVout::vres()': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:148: multiple definition of `TVout::vres()' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:148: first defined here TVout\TVout.cpp.o: In function `TVout::char_line()': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:158: multiple definition of `TVout::char_line()' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:158: first defined here TVout\TVout.cpp.o: In function `TVout::delay_frame(unsigned int)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:183: multiple definition of `TVout::delay_frame(unsigned int)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:183: first defined here TVout\TVout.cpp.o: In function `TVout::millis()': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:199: multiple definition of `TVout::millis()' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:199: first defined here TVout\TVout.cpp.o: In function `TVout::delay(unsigned int)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:169: multiple definition of `TVout::delay(unsigned int)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:169: first defined here TVout\TVout.cpp.o: In function `TVout::delay_frame(unsigned int)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:183: multiple definition of `TVout::force_vscale(char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:183: first defined here TVout\TVout.cpp.o: In function `TVout::delay_frame(unsigned int)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:183: multiple definition of `TVout::force_outstart(unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:183: first defined here TVout\TVout.cpp.o: In function `TVout::delay_frame(unsigned int)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:183: multiple definition of `TVout::force_linestart(unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:183: first defined here TVout\TVout.cpp.o: In function `TVout::get_pixel(unsigned char, unsigned char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:278: multiple definition of `TVout::get_pixel(unsigned char, unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:278: first defined here TVout\TVout.cpp.o: In function `TVout::bitmap(unsigned char, unsigned char, unsigned char const*, unsigned int, unsigned char, unsigned char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:605: multiple definition of `TVout::bitmap(unsigned char, unsigned char, unsigned char const*, unsigned int, unsigned char, unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:605: first defined here TVout\TVout.cpp.o: In function `TVout::shift(unsigned char, unsigned char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:669: multiple definition of `TVout::shift(unsigned char, unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:669: first defined here TVout\TVout.cpp.o: In function `TVout::set_pixel(unsigned char, unsigned char, char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:256: multiple definition of `TVout::set_pixel(unsigned char, unsigned char, char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:256: first defined here TVout\TVout.cpp.o: In function `TVout::draw_column(unsigned char, unsigned int, unsigned int, unsigned char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:441: multiple definition of `TVout::draw_column(unsigned char, unsigned int, unsigned int, unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:441: first defined here TVout\TVout.cpp.o: In function `TVout::draw_row(unsigned char, unsigned int, unsigned int, unsigned char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:387: multiple definition of `TVout::draw_row(unsigned char, unsigned int, unsigned int, unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:387: first defined here TVout\TVout.cpp.o: In function `TVout::draw_circle(unsigned char, unsigned char, unsigned char, char, char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:530: multiple definition of `TVout::draw_circle(unsigned char, unsigned char, unsigned char, char, char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:530: first defined here TVout\TVout.cpp.o: In function `TVout::draw_line(unsigned char, unsigned char, unsigned char, unsigned char, char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:301: multiple definition of `TVout::draw_line(unsigned char, unsigned char, unsigned char, unsigned char, char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:301: first defined here TVout\TVout.cpp.o: In function `TVout::draw_rect(unsigned char, unsigned char, unsigned char, unsigned char, char, char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:500: multiple definition of `TVout::draw_rect(unsigned char, unsigned char, unsigned char, unsigned char, char, char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:500: first defined here TVout\TVout.cpp.o: In function `TVout::set_vbi_hook(void (*)())': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:769: multiple definition of `TVout::set_vbi_hook(void (*)())' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:769: first defined here TVout\TVout.cpp.o: In function `TVout::set_hbi_hook(void (*)())': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:782: multiple definition of `TVout::set_hbi_hook(void (*)())' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:782: first defined here TVout\TVout.cpp.o: In function `TVout::tone(unsigned int, unsigned long)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:807: multiple definition of `TVout::tone(unsigned int, unsigned long)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:807: first defined here TVout\TVout.cpp.o: In function `TVout::tone(unsigned int)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:794: multiple definition of `TVout::tone(unsigned int)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:794: first defined here TVout\TVout.cpp.o: In function `TVout::noTone()': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:875: multiple definition of `TVout::noTone()' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:875: first defined here TVout\TVout.cpp.o: In function `TVout::end()': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:96: multiple definition of `TVout::end()' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:96: first defined here TVout\TVout.cpp.o: In function `TVout::begin(unsigned char, unsigned char, unsigned char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:74: multiple definition of `TVout::begin(unsigned char, unsigned char, unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:74: first defined here TVout\TVout.cpp.o: In function `TVout::begin(unsigned char)': C:\Users\Quick\Desktop\arduino\arduino-1.0.3\libraries\TVout/TVout.cpp:50: multiple definition of `TVout::begin(unsigned char)' TVout.cpp.o:C:\Users\Quick\AppData\Local\Temp\build7723248887771758841.tmp/TVout.cpp:50: first defined here
Logged
Offline
Newbie
« Reply #6 on: January 26, 2013, 04:39:54 pm » |
They are in libraries\TVout\examples\DemoNSTC I noticed \appdata\temp in the updated errors so would rebooting my computer help
Logged
East Anglia (UK)
Offline
Edison Member
« Reply #7 on: January 26, 2013, 05:25:15 pm » |
If I have it right, user installed libraries should be in a folder named libraries which is in the same place that your sketch folders.
libraries\TVout\examples\DemoNSTC sounds a strange place for the header files.
NOTE - there are 2 libraries folders that arise from the installation of the IDE. One is as noted above and the other is under Program Files and is where the system libraries are placed by the installation.
Logged
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #8 on: January 26, 2013, 06:08:21 pm » |
Just a heads-up. You can attach documents to a forum posting (click "Additional options"). If you have multiple files you can zip them together and attach the zip.
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #9 on: January 26, 2013, 06:14:33 pm » |
The code in the first post obviously can never compile (take a close look at "printcube" - which is why we ask for code tags, not quote tags), but try #include <TVout.h> #include <fontALL.h> #include "schematic.h" #include "TVOlogo.h"
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
