Loading...
Pages: [1]   Go Down
Author Topic: HC-SR04 ultrasonic sensor + Arduino Mega = not working  (Read 401 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
i just got a ultrasonic sensor...it is a 4 pin (vcc/trig/echo/grnd) model...here is the code:
Code:
 HC-SR04 Ping distance sensor]
 VCC to arduino 5v GND to arduino GND
 Echo to Arduino pin 13 Trig to Arduino pin 12
 More info at: http://goo.gl/kJ8Gl
#define trigPin 12
#define echoPin 13
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  int duration, distance;
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(1000);
  digitalWrite(trigPin, LOW);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  if (distance >= 200 || distance <= 0){
    Serial.println("Out of range");
  else {
    Serial.print(distance);
    Serial.println(" cm");
here is what i get from the serial
Code:
4 cm
4 cm
4 cm
4 cm
5 cm
4 cm
4 cm
5 cm
4 cm
4 cm
when i remove the echo pin just to see what happens, just says out of range w/o any delays...i have it wired up just like u would think
US Sen     Arduino
VCC --> 5v
Gnd --> Gnd
Trig --> 12
Echo --> 13
nothing more i can give u other than i am using the original arduino mega
Logged
Toledo, OH
Offline Offline
Sr. Member
View Profile
WWW
Code:
#define trigPin 12
#define echoPin 13
  else {
Code:
4 cm
4 cm
4 cm
4 cm
5 cm
4 cm
4 cm
5 cm
4 cm
4 cm
US Sen     Arduino
VCC --> 5v
Gnd --> Gnd
Trig --> 12
Echo --> 13
Step 1, throw that code out.
Step 2, use the NewPing library (it includes sample code).
Step 3, make sure there's nothing in front of the sensor (wires or anything as the smallest thing can cause an echo).
Setp 4, enjoy!
If you run into problems, contact the author at the thread linked above.  He's more than happy to help diagnose your problem.
Tim
Logged
Arduino Uno - Teensy 2.0 - Teensy 3.0 - Raspberry Pi Model B w/512MB RAM
My libraries: NewPing library - LCDBitmap library - toneAC library - NewTone library
Pages: [1]   Go Up
Print
Jump to:
