Loading...
Pages: [1]   Go Down
Author Topic: serial event in subroutine dont work?  (Read 389 times)
0
Offline Offline
Newbie
Arduino is fun
View Profile
WWW
i see and tested some nice code http://atlas-scientific.com/_files/code/Arduino-sample-code-EZ-COM-MEGA.pdf
Code:
String inputstring = "";                                                       //a string to hold incoming data from the PC
String sensorstring3 = "";                                                      //a string to hold the data
boolean input_stringcomplete = false;                                          //have we received all the data from the PC
boolean sensor_stringcomplete3 = false;                                         //have we received all the data
  void setup(){        //set up the hardware
     Serial.begin(115200);                                                      //set baud rate for the hardware serial port_0
     Serial3.begin(38400);                                                     //set baud rate for software serial port_3
     inputstring.reserve(5);                                                   //set aside some bytes for receiving data from the PC
     sensorstring3.reserve(30);                                                 //set aside some bytes for receiving data
   void serialEvent() {                                                         //if the hardware serial port_0 receives a char
               char inchar = (char)Serial.read();                               //get the char we just received
               inputstring += inchar;                                           //add it to the input String
               if(inchar == '\r') {input_stringcomplete = true;}                //if the incoming character is a <CR>, set the flag
  void serialEvent3(){                                                          //if the hardware serial port_3 receives a char
              char inchar = (char)Serial3.read();                               //get the char we just received
              //sensorstring3 += inchar;                                        //kll add it to the input String
              if(inchar == '\r') {sensor_stringcomplete3 = true;}               //if the incoming character is a <CR>, set the flag
              else {  sensorstring3 += inchar; }                                //kll
 void loop(){        //here we go....
  if (input_stringcomplete){                                                   //if a string from the PC has been received fully
      Serial3.print(inputstring);                                              //send that string
      inputstring = "";                                                        //clear the string:
      input_stringcomplete = false;                                            //reset the flag used to tell if we have received a completed string from the PC
 if (sensor_stringcomplete3){                                                   //if a string has been received fully
      Serial.println(sensorstring3);                                            //send that string to the PC's serial monitor
      sensorstring3 = "";                                                       //clear the string:
      sensor_stringcomplete3 = false;                                           //reset the flag used to tell if we have received a completed string
like for a terminal emulation ...
but when i tried to use the event in a code
like question and answers in a subroutine it did not work.
can you pls try that following code and tell me what you think?
Code:
KLL serial event test
     inputstring.reserve(5);                                                   //set aside some bytes for receiving data from the PC KLL but seems to work also for longer strings??
               inputstring += inchar;               //add it to the inputString
               Serial.print(" S0: ");
               Serial.println(inchar,HEX);
  void askquestion() {
      Serial.println("Question: do you love me? ");
      int var = 0;
      while(var < 20){  // do something repetitive times
                   delay(200);
                   var++;  Serial.print(".");
                       Serial.print(" askquestion loop got: ");
                       Serial.print(inputstring);                                               //send that string back
                       input_stringcomplete = false;                                            //reset the flage used to tell if we have recived a completed string from the PC
                      } // end while
                    Serial.println(" timeout ");
                    } // ask question
  if (input_stringcomplete){                                                   //if a string from the PC has been recived in its entierty
      Serial.print(" main loop got: "); Serial.println(inputstring);
  askquestion();
looks like a character is only catched in a main loop, ( and only one per loop).
so question - answer will never work?
any ideas what i do wrong?
« Last Edit: January 27, 2013, 12:42:46 am by kllsamui » Logged
0
Offline Offline
Newbie
Arduino is fun
View Profile
WWW
found info
http://arduino.cc/en/Tutorial/SerialEvent
  SerialEvent occurs whenever a new data comes in the
 hardware serial RX.  This routine is run between each
 time loop() runs, so using delay inside loop can delay
 response.  Multiple bytes of data may be available.
so its correct what i see and this function is of limited use.
Logged
East Anglia (UK)
Online Online
Edison Member
May all of your blinks be without delay
View Profile
What are you expecting your code to do ?
What does it actually do ?
Where is the call to serialEvent() ?
« Last Edit: January 27, 2013, 07:11:21 am by UKHeliBob » Logged
0
Offline Offline
Newbie
Arduino is fun
View Profile
WWW
for a sub menu like operation i need several "questions AND answers" via serial link ( USB, operator ).
means i must stay inside a sub routine without going back to main loop inbetween,
or i would loose the reference, what answer is for what question.
the serialEvent is a interrupt routine, so not to be called here, ( only filled with functionality )
and it works perfect in a main loop structure like in the first example.
code example 2 is to show where the problem is only. pls try it.
it does not get anything from the serial line as long it is in the subroutine.
Code:
.................... timeout
 S0: 79
 S0: 65
 S0: 73
 S0: D
 main loop got: yes
so instead of using this serialEvent interrupt function i must go back to the usual Serial.available()...
« Last Edit: January 27, 2013, 08:06:58 am by kllsamui » Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
1. Its a function there are no routines (sub or other wise) in C/C++
2. Never use the String class with Arduino (there's a fault in it)
3.
Quote
Completely wrong! See the blink without delay example and Finite State Machines in in the playground
4. Quit playing with serial event!
Mark
Logged
East Anglia (UK)
Online Online
Edison Member
View Profile
Your serialAvailable() function is only removing one character from the input buffer each time it is called and it is only called at the end of loop().  However, askQuestion() blocks loop() from running again until the delay of 4 seconds is over, by which time it is too late for serialAvailable() to get another character and add it to the string, and this includes the CR, so the input never finishes before the 4 seconds is up and even then only has one character in it.
If I were you I would leave serialEvent() alone.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
...by which time, the Serial input buffer could have overflowed 720 times, and you would never know.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The serialEvent() functions are called at the end of loop(), if there is serial data on the specific port. The user does not need to code a call to the serialEvent() functions.
Logged
0
Offline Offline
Newbie
Arduino is fun
View Profile
WWW
thanks for all the input:
i see : NOT USE STREAM, NOT USE EVENT.
@holmes4 / Mark
Quote
3. Completely wrong! See the blink without delay example and Finite State Machines in in the playground
i understand that delay is bad, i try without, but the job:
ask a question " pls. give a setpoint; default 12.46: "
 - i must wait for operator input,
 - but check also on a timeout,
 - check if the number provided is good,
 - use a default number if not
 + and do something with that input
_____ while all this i can not go back to the main loop ( i think)
        as much i hate to block all other jobs in main loop
     thats why i started testing about the serialEvent.
and regarding this i do not understand your answer? you have seen code what can do that?
Logged
0
Offline Offline
Newbie
Arduino is fun
View Profile
WWW
pls find here ( attached ZIP ) my first working example, what combines all 3 ways to deal with serial input:
input check NO WAIT for a operator menu system ( by one character )
( what still allow the main loop to run 1000000 / 16sec. )
input question .. answer
for string / and number int/real with default number / type WAIT with time out
stream by serialEvent for sensor input from T3 (MEGA)
connected sensor: http://atlas-scientific.com/product_pages/sensors/ec-sensor.html
looks like:
Code:
KLL serial menu
 adjust terminal to AUTOSCROLL, Carriage Return, 115200
 hit [space] [ENTER] to get MENU list
 MENU:
 [space] this list
 [d] enable diagnostic
 [t] enable timecheck
 [n] test number input
 __________sensor ___________________
 [c] send measure command to sensor T3
 [e] send measure stop command to sensor T3
 [i] send ref info command to sensor T3
 select:
 sensor on T3 command I<CR>
E,V3.0,4/12
 sensor on T3 command C<CR>
2045,1104,0
2178,1176,0
2000,1080,0
 debug ON
 T3: 32 T3: 30 T3: 30 T3: 30 T3: 2C T3: 31 T3: 30 T3: 38 T3: 30 T3: 2C T3: 30 T3: D2000,1080,0
 T3: 32 T3: 30 T3: 32 T3: 32 T3: 2C T3: 31 T3: 30 T3: 39 T3: 32 T3: 2C T3: 30 T3: D2022,1092,0
 debug OFF
1978,1068,0
2022,1092,0
 sensor on T3 command E<CR>
 Question numberinput, default 98.7654:
 int: -3456 real: -3456.79
 Question numberinput, default 98.7654:  no number input, use default!
 int: 98 real: 98.77
« Last Edit: January 28, 2013, 08:12:17 am by kllsamui » Logged
Pages: [1]   Go Up
Print
Jump to:
