Loading...
Pages: [1]   Go Down
Author Topic: frequency counter for Atmega2560  (Read 372 times)
Offline Offline
Newbie
View Profile
Hi , Nick Gammon
first thanks for your tutorial on this link http://www.gammon.com.au/forum/?id=11504 it is very useful, tutorial
I want to use the code on "Frequency Counter sketch for Atmega2560" on your tutorial,  when I tested the code it is counting either  odd numbers or even numbers , I tested using sigal generator,
what I wanted is to count numbers for example:
 starting from:  80, 81, 82, 83, 84, 85, and so on
but the code is counting for example. 80, 82, 84, 86, 88, 90  and so on it is jumping over a one number
if I start for example  81,  it continued as  83, 85, 87, 89, 91
can you please help me by  telling what I have to change in your code to count - like . 60,61,62,63, 64,65,66,67,68,69,70  continued like that not jumping any number?
thanks
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Yes, well that was on the Atmega328P. Perhaps if you post the code you used we can see what you did and compare it to the datasheet.
Logged
Offline Offline
Newbie
View Profile
Hi, Nick Gammon
thanks for quick reply
I am using Amega2560 - seeeduino,the code is yours:  the code is working perfectly,when I tested, the problem is jumping over one number.
here is the code:
Code:
// Timer and Counter example for Mega2560
// Author: Nick Gammon
// Date: 24th April 2012
// input on pin D47 (T5)
// these are checked for in the main program
volatile unsigned long timerCounts;
volatile boolean counterReady;
// internal to counting routine
unsigned long overflowCount;
unsigned int timerTicks;
unsigned int timerPeriod;
void startCounting (unsigned int ms)
  counterReady = false;         // time not up yet
  timerPeriod = ms;             // how many 1 mS counts to do
  timerTicks = 0;               // reset interrupt counter
  overflowCount = 0;            // no overflows yet
  // reset Timer 2 and Timer 5
  TCCR2A = 0;
  TCCR2B = 0;
  TCCR5A = 0;
  TCCR5B = 0;
  // Timer 5 - counts events on pin D47
  TIMSK5 = _BV (TOIE1);   // interrupt on Timer 5 overflow
  // Timer 2 - gives us our 1 mS counting interval
  // 16 MHz clock (62.5 nS per tick) - prescaled by 128
  //  counter increments every 8 uS.
  // So we count 125 of them, giving exactly 1000 uS (1 mS)
  TCCR2A = _BV (WGM21) ;   // CTC mode
  OCR2A  = 124;            // count up to 125  (zero relative!!!!)
  // Timer 2 - interrupt on match (ie. every 1 mS)
  TIMSK2 = _BV (OCIE2A);   // enable Timer2 Interrupt
  TCNT2 = 0;
  TCNT5 = 0;      // Both counters to zero
  // Reset prescalers
  GTCCR = _BV (PSRASY);        // reset prescaler now
  // start Timer 2
  TCCR2B =  _BV (CS20) | _BV (CS22) ;  // prescaler of 128
  // start Timer 5
  // External clock source on T4 pin (D47). Clock on rising edge.
  TCCR5B =  _BV (CS50) | _BV (CS51) | _BV (CS52);
}  // end of startCounting
ISR (TIMER5_OVF_vect)
  ++overflowCount;               // count number of Counter1 overflows
}  // end of TIMER5_OVF_vect
//  Timer2 Interrupt Service is invoked by hardware Timer 2 every 1ms = 1000 Hz
//  16Mhz / 128 / 125 = 1000 Hz
ISR (TIMER2_COMPA_vect)
  // grab counter value before it changes any more
  unsigned int timer5CounterValue;
  timer5CounterValue = TCNT5;  // see datasheet, (accessing 16-bit registers)
  // see if we have reached timing period
  if (++timerTicks < timerPeriod)
    return;  // not yet
  // if just missed an overflow
  if (TIFR5 & TOV5)
    overflowCount++;
  // end of gate time, measurement ready
  TCCR5A = 0;    // stop timer 5
  TCCR5B = 0;
  TCCR2A = 0;    // stop timer 2
  TCCR2B = 0;
  TIMSK2 = 0;    // disable Timer2 Interrupt
  TIMSK5 = 0;    // disable Timer5 Interrupt
  // calculate total count
  timerCounts = (overflowCount << 16) + timer5CounterValue;  // each overflow is 65536 more
  counterReady = true;              // set global flag for end count period
}  // end of TIMER2_COMPA_vect
void setup () {
  Serial.println("Frequency Counter");
} // end of setup
void loop () {
  // stop Timer 0 interrupts from throwing the count out
  byte oldTCCR0A = TCCR0A;
  byte oldTCCR0B = TCCR0B;
  TCCR0A = 0;    // stop timer 0
  TCCR0B = 0;
  startCounting (500);  // how many mS to count for
  while (!counterReady)
     { }  // loop until count over
  // adjust counts by counting interval to give frequency in Hz
  float frq = (timerCounts *  1000.0) / timerPeriod;
  // restart timer 0
  TCCR0A = oldTCCR0A;
  TCCR0B = oldTCCR0B;
  Serial.print ("Frequency: ");
  Serial.println ((unsigned long) frq);
  // let serial stuff finish
  delay(200);
}   // end of loop
what I have to modify this code so it can count .. 1,2, 3, 4, 5, 6, 7, 8, instead of 1 , 3, 5, 7, 9 or 2, 4, 6, 8, 10 using signal generator.
thanks
« Last Edit: January 27, 2013, 05:38:48 am by Ducaqabe » Logged
Offline Offline
Edison Member
View Profile
Code:
Would this have anything to do with your trouble?
Change the gate time.
Logged
Offline Offline
Newbie
View Profile
hi  dhenry
thanks for helping.
I am not in the lab, I don't have signal generator my selv, I will test  after 1 hour, so instead of this
Code:
shall I increase or decrease the counting number , I will test soon, but my problem is the code is counting either odd numbers or even numbers, and I want to count both,  like this way. 90, 91, 92, 93, 94,95,96 ....... and so on
Logged
Offline Offline
Edison Member
View Profile
My telling you what to do doesn't help you, if you don't understand why you are observing what you are observing.
The original code isn't well documented but the following may help you understand what is happening:
Code:
Once you figure out the problem, the solution is right there.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
Why are you expecting the count to go up anyway? What frequency are you putting into it?
Putting in 1 KHz square wave I get this:
Code:
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
Frequency: 1000
I don't see why it would increase by odd or even numbers. It is supposed to be giving you the frequency of counts per second, with the gate time (that dhenry mentioned) being the sample period.
Quote
Which way, dhenry? Provide reasons for your answer.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I have repeatedly asked you to post code to demonstrate some of the things you claim you have done, dhenry. If you were to do so, we could see how properly-written and documented code looks like.
Logged
Pages: [1]   Go Up
Print
Jump to:
