Quote from: cancelliere on Today at 02:12:33 PM
Since I am not uploading anything to the board, but I'm just trying to communicate to it, I haven't selected anything.
You named this thread "AtMega32L using Arduino UNO as ISP". Therefore, I assumed you had
(a) burned the ArduinoISP sketch into the UNO, and were (b) trying to burn the bootloader into
the 32L chip. If that is correct, then you need to select a target board to burn the bootloader.
If you have already burned the bootloader into the 32L chip, then you still need to select the
correct target board to upload a sketch to the 32L.
But like I said, I don't even see a target board selection for using a 32L chip. Are you sure it's a
32L, and not 328 or 32U4 or 324 or something else? Plus, looking around, I can't even find a
bootloader version for the 32L chip.
